Question about RCA DRC8335
VCR portion not working found Damaged Components
I had the same problem with my DRC8335. The 470uF 16 V capacitor in C226 was blown. I changed it and the unit worked for about 2 hours and then began to continually restart itself. I found that the 220 uF 16 V capacitors in C209 and C210 where also damaged and the C226 Cap was bad again. I changed out all the Electrolytic Caps in the power supply and the DVD recorder works great. The question that I have is this, the VCR part does not work I found a Heat Damaged resistor and diode on the upper right side of the VCR PC board (by the power supply board). The location of the components are “RU83” and “DU83”. I was wondering if you happen to know the values for these two components so that I may changed them out? Thanks for you help in advance.
  • toroden Dec 15, 2008
    I replaced the C226 capacitor and now the DVD works but the VCR still does not. Has anyone identified the other parts that need to be replaced for the VCR. Thanks.
  • Mike Adams
    Mike Adams May 11, 2010
    EERepair. In addition to the usual #C226 capacitor failure, I further identified two other PS caps running excessively hot, which I've replaced. Specifically caps #C216 and #C218 both of which are 1000µf. The former having a 16 volt rating and latter 10 volt, as installed at the factory. After upgrading both to a 35 working-voltage rating they're no longer even noticably warm.
    Beyond the faulty power-supply capacitors I further discovered zener diode #DU83 on the VCR PCB was red hot, just as in your case! For this reason, I've temporarily taken it out-of-circuit so it won't load-down the power-supply, until it's been replaced.
    At this moment, I'm not sure yet myself what DU83's voltage rating is. It's so tiny in size you couldn't possibly read any of its identification markings (assuming there are any) without the aid of a powerful magnifying glass! I checked all the Service Manual sites, but none have one for the DRC8335. So I'll proceed by using my DMM to measure the source DC voltage on it's pads and let you know, once I've determined what DU83's correct value should be.
    Unlike your situation, my VCR board's RU83 (51ohm 1/2 watt 5% tolerance) resistor didn't fry and appears to be in good shape. So I'm able to provide 1/2 of what you asked and needed to know. Hopefully I'll have DU83's value determined in another day or so, once I have more time to resolve the question.
    Questions:
    Have you discovered any further information regarding DU83 since your August 14th post?
    Other than DU83 and RU83, were there any other damaged components on the VCR PCB which had to be replaced?
    I'm hoping once I've determined DU83's value and solder-in a replacement, this much alone will completely restore the VCR deck functionality. But obviously there could be further components involved, as a consequence of DU83's thermal-runaway breakdown.
    I noticed one of the transistors immediately below DU83 felt suspiciously warm, if not bordering on hot. But it was literally laying on top of the overheating DU83. Once I repositioned the transistor away, it seemed to cool down quite considerably. Obviously I won't be able to make any further determinations until I've first replaced DU83.
    Please email me directly if so inclined and you have time. It'd be the quickest way to contact me. mikeadams110@yahoo.com
Ya rca needs to recall all rca drc8335[tape decks]
I unpluged power to deck [jumper p/s to deck]
use a other vhs deck pluged in avi port
Posted on Aug 17, 2008
LG 42" Plasma no picture but has sound
Before replacing a blown fuse, always check for short circuit in an analogue multimeter. Otherwise, you are likely to cause more damage to the board.
Aug 02, 2012 | Televison & Video
SONY DHR-1000NP : Problem : No power Already replaced some components in shielded part of power supply : Replaced big capacitors (1500 and 2200 and 680 mico farad) R115 and FET Q101 will always...
I have just fixed one of these. The problem was C104 inside the metal shielded section of the PSU. It's a 2.2uF 50V capacitor. Sony used an 85degC version rather than a 105degC (which I've used). Fortunately, no other components were damaged.
Feb 17, 2011 | Sony DHR-1000 DVHS VCR
Hi; my friends blew the power supply board on this desk; will I be able to change individual components or have to fork out 160 euros for a new board? I think I could cope with changing components if...
It is likely one of the amps have blown as well as the power supply. The pwoer supply wipes out about $30 of components when it goes. If the fuse had been replaced after initial failure this results in more damage. For the power supply, typically the two IGBT's are wiped out and the four transistors driving them as well as the regulator chip and one or more of the gate speedup diodes which are surface mounted. Sometimes the surge limit resistors which are ceramic pacakged are blown. The hardest part is removing the heatsinks with the IGBT's on them. You DO need a desoldering station to work on this.
Usually you will find damage to the rearmost amp in the amplifier module. An arc beween layers of the multilayer circuit board causes inital failure. Three MOSFET transistors are blown and a Zener plus the board is charred and this cancer has to be ground away and re-insulated and circuit traces replaced by jumpers. Sometime the .03 ohm metering resistor on the bottom is fried... when that happens, two small surface mounted transistors are blown as well. All in all $50 of components are damaged typically.
Oct 31, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
My curtis DRC8335 IS STUCK ON HELLO - WHAT SHOULD i DO - I TRIED SWITCHING IT OFF - SWITCHED IT ON - STILL STUCK ON HELLO
There's a blown capacitor in your machine (when you open it up, the capacitors are the little things that look like pop cans). If you are good with a soldering iron (or know somebody who is), they should be able to replace the blown capacitor with a minimum of fuss. I believe the board location is C226.
Feb 11, 2010 | RCA DRC8335
The machine has HELLO but will not start up. if i hold the on/standbye for a few seconds, the time will appear and then back to hello when I press play. All I did was put a tape in which I can not now...
Hello everyone having problems with there RCA DRC8335. If you are getting the HELLO sign and nothing else(which i was too).
First you have to find the blown capacitor. All the capacitors should have a flat top. If you find one that is not flat and if gets hot to the touch when your vhs/dvd player has power you found your source. Next unplug your dvd/vhs player and take out the blown capacitor. Do not waste your money tring to get it fix by a so call pro. The parts you need is less than .55 cents(lol). Now the capacitor that you take out should have a code number(mine was c226) which is located in the same area as the blown part. Measure the capacitor and call for your part number 1-800-344-4539 Digi-key.com will find the part you need(only if u know what part u need)
1.find the blown capacitor
2.remove it
3.get the number below the blown capacitor
4. measure it.
5.call for your part number
6.put your hard earn dollar(not dollars) to work
7.and you can say Thanks Maximilian Moore for saving me money
Jan 31, 2010 | RCA DRC8335
My combo DVD/VCR DRC8335 will only display HELLO and not respond to the remote or buttons on the face. I have tried the troubleshooting portion of the manual and need help.
I have an rca drc8335 vcr/dvd player that is locked. I have the code to unlock it, but don't know where to post the code. Can you help me?
Dec 12, 2009 | RCA DRC8300N DVD Recorder/VCR
Ok...I just replaced the .0087uf 2000vdc capacitor that had burned out and the TV came on and worked for about 30 minutes. Now it shuts off and turns itself back on 3 times then it stays off and you cant...
Check for any capacitors that havnt blown but may be very leaky and unable to retain charge, often found surrounding the blown components. Also check the power suply circuitry for any shorted components that may have faulted causing the capacitor to burn out. Good Luck.
Nov 25, 2009 | RCA HD52W59 HDTV Projection Television
RCA dvd/vhs DRC8335 stuck on HELLO
December 27, 2008 received by email from Ann M.
Just like John H, my problem was also capacitor C226, but in my case overheating wasn't the give-away here. Instead, I noticed the bottom of the capacitor appeared melted a little and the top looked like it was slightly bulged. I removed the damaged capacitor and replaced it with a new one rated at 35 volts and now my DRC8335 is working perfectly again!
It worked it cost me 4 hours on hold with the Republic of the Philippines. Being told the new Unit sent had a 90 day warranty. It did they were right after 90 days it stopped working. The part was a Radio Shack 272-1030.
Jul 04, 2009 | RCA DRC8335
Unit Lockup
This fix is for those of you with knowledge of electronic repair......
The problem is a bad electrolytic capacitor on in the power supply board. The cap is a 470uf 16v (number C226 on the power supply board). Replace it with a 470uf with a rating of 25v to 50v and it should restore the power fucntion to normal. I have fixed six units this way so far. Hope this helps you all out!
Retro
Feb 23, 2008 | RCA DRC8335
Vcr repair
If you have a voltmeter and some tech savvy, you could check the output voltages (voltages which run the VCR circuitry, motors, etc.). You should find a +5 volt, +12 to 14 volt, possibly a -35 volt (for the display if it has one). If these are missing, then the unit will be utterly dead. Check the fuse: If blown, check associated circuitry on the primary (line voltage) side. The fuse almost always poofs for a reason, and until the bad components are found, it will blow again, perhaps causing more component damage. The switching transistor may be shorted, plus nearby resistors/diodes/capacitors poofed/shorted/defective. In many VCRs I've worked on, a capacitor on the primary side will fail, and cause a dead condition, sometimes causing the noted transistor to short. A thorough check is highly suggested. It isn't fun to install new parts, only to have them poofed by a yet remaining problem somewhere. Common failures on the secondary side (where the voltages noted above are rectified, filtered), are the electrolytic capacitors. Common values here are 1000MFD/16 volt, 1500MFD/10Volt, 2200MFD/10volt or close. Many of the older VCRs pre-90's developed this problem.
Sep 18, 2007 | Televison & Video
RCA DRC8335 Logo
598 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
