Question about Dryers
Dryer Noise Dryer has a squealing sound that comes and goes while tumbling. The squealing can get very loud. Maytag Dryer MDE508DAYW
  • fldgb Dec 30, 2008
    I have a 3 year old Maytag dryer (model MDET236AYW) that started making a squeaking noise a couple of months ago. Yesterday, it started making a very loud noise, like medal on medal, while tumbling. This comes and goes. The belt is fine. Any suggestions?
  • 594 Answers
You need to have you belt replaced. Over time the belt will strech.
this causes the dryer to still spin but the belt will sometimes loose the grasp of the drum and cause the belt to spin only.
This happens because over time with heavy loads of towles and jeans pull down on the drum as it is being loaded. Than when in cycle the jeans will drop from the top to the bottom pulling aginst it even more..
Posted on Aug 14, 2008
Hi. My Neptune dryer was not sounding as I remembered it. A higher pitch than usual while it was drying clothes. Then I noticed it was reluctant to start when pushing the "start" button, with...
burning smell is because the drum is not rolling and the motor is trying to turn, hopefully it did not damage the motor: more then likely it the drum rollers/glides, might want to check the idler arm here is a website that will help. depending on fast you need your dryer a good and cheap place to buy parts is on eBay, of course they can be purchased locally, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 10, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune dryer increasingly loud.
Sounds like you need new drum rollers installed, when they get old they squeak,squeal, and make loud bumping noises.
Sep 25, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Screaming Maytag dryer
You're probably correct that it's bearings/bushings.
Take the front off by first popping the top. Lubricate all moving parts (mostly bushings/rollers/pulleys on shafts) including the motor shaft/bearings.
Don't get oil in belt path (like on a pulley where the belt will ride) or on the belt.
This should solve the problem.
Use something akin to 3-IN-1 Machine Oil.
Charlie
Aug 27, 2009 | Dryers
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
What is the noise coming from my dryer?
Good Afternoon,
If the shipper has insurance they should replace the dryer. No?
Mar 27, 2009 | Whirlpool LER5636P Electric Dryer
I have a Maytag Dryer MDE9806AYW Intelli Dry SQUEALS
Yes its worth repairing, it sounds like a simple fix, could be pulley, or seal replacement but for the price of some machine oil, or part, well worth it. The intelli dry pulls apart from front, with the door and top is hinged. A little time consumeing but I think still worth it.
Feb 04, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
433 people viewed this question
Top Dryers Experts
