Question about Car Audio & Video
My car smoke and consume oil - Car Audio & Video
  • yadayada
    yadayada May 18, 2011
    Make and model and year and what engine?
  • 38 Answers
Hmm most likely you will need to get it on a patch for smoking and drinking it's more of being strong and staying away from the old grandpa juice. Kiddn aside most likely piston rings as the car gets older the ability of the piston rings to seal properly fades so there is residual oil than enters the combustion chamber and there it burns most likely you are also feeling a lack of power due to the compression reduction most likely it means depending on how bad it is a rebuild of an engine.
Posted on May 19, 2011
Vrod consume oil
Do you see blue smoke from the exhaust? If you don't then your not burning oil your loosing it. In your oil bag there is a vent hole, are you filling oil too full?
Aug 07, 2014 | Harley Davidson VRSCDX Night Rod Special...
Plugged drainback holes
Please could you elaborate the details with respect to the mileage of the car. Have you changed the oil recently? has the car smoking or consume more oil recently? if yes to both you might need a overhauling of the engine and should be estimated. Dont forget to check if the exhaust also if clogged and so smoking.
Jun 06, 2012 | 1998 Ford Taurus
My car is smoking blue smoke
Blue smoke out of the exhaust is indicative of either worn piston rings or valve guides. Either of which will require extensive work to fix. Oil is basically slipping past the rings or guides and into the combustion chamber, where it is being burned and expelled as blue smoke out of the exhaust.
Keep an eye on your oil consumption. A newer model BMW like yours should be consuming less than half a quart of oil every 3-5k miles. If it is consuming more than this then it needs to be diagnosed as either the piston rings or valve guides and repaired, typically by a shop for a job this big on a late model BMW.
May 06, 2011 | 2003 BMW 3 Series
Whenever I start the car it smokes than after warming up it stops smoking.
The key is how much smoke? Does the smoke have a smell to it. Are you consuming any fluids, like coolant, or oil?
Tons White smoke that is sweet smelling is usually coolant getting into the combustion chamber.
Less white smoke, especially if other cars are doing it, is normal. For every gallon of gas that you burn, you generate a gallon (GALLON) of water. so this water usually evaporates, but sometimes not. It has little or no smell.
If the smoke is bluish white, that is oil, but usually your converter would fill with oil, and cause error codes, or loss of power. This smell is distinct, but not necessarily sweet.... After the converter heats up, it may be able to burn off the oil and the smoke stops.
What are you consuming, fluid wise, will direct where you go next.
Jan 27, 2011 | 1995 Lexus LS 400
Loosing oil, no spots or puddles on ground, no smoke from exhaust
A very common issue with the 1.9L engine is oil consumption. You may not see alot of blue smoke out of the exaust but it is very typical for this engine to consume oil without any visible leaks.
Jun 10, 2010 | 2000 Saturn SL
88 sup alot of bolt ons 14psi blowing blue/gray smoke in low rpm range and when i hit it, an if i let it idle for a bit then go it leaves a clowed, no pcv system, open ex. valves sound good thinking rings...
blue smoke is from coolant. check your coolant levels because it could be the head gasket.
what about oil? is it consuming oil (if yes, its most likely is consuming coolant too)
if not consuming anyting, it will be the valve seals (located inside the engine)
Aug 14, 2009 | 1995 Toyota Supra
Mazda mx5 smoking problem
Please provide more details for analysis like:
- what is the mileage on your car?
- is it smoking continously or only intermittently? How much smoke is it?
- what colour is the smoke? bluish or sooty?
- does it smoke when engine is cold or hot?
- is your car losing power?
- is your car consuming motor oil and at what rate?
- has the engine ever been overheated?
- is there an engine MIL ( malfunction indicator light ) code flashing on your dash? If it has, then you need to get the workshop to run a scan of the engine's computer to find out what the possible faults are.
- by the way, is your mx-5 fitted with a rotary engine or the common 4-stroke piston engine?
Jul 07, 2009 | Mazda MAZDA5 Cars & Trucks
Blue smoke
it is a piston ring problem. your car consume more engine oil than normal right? .
Jun 15, 2009 | 2006 Fiat Strada
Saab 93 2001 - kicks out white smoke when started then drives ok until it gets to certain temp then starts miss firing and kicking out smoke
is car consuming any antefreeze? does the temp fluctuate? on worst case, you could be looking at poss. headgasket problem white smoke is usually antifreeze. black smoke is fuel, and gray smoke is oil
Nov 30, 2008 | Saab 9 Cars & Trucks
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
