Question about Panasonic TOUGHBOOK CF-18 Tablet PC
We have a tough book cf18 and the touch screen has gone haywire! the arrow on the screen moves but not in sync with the touch screen or the track pad. it seems to have a life of it's own, or is detached from each other making it almost impossible to drive. You can move the arrow using the touch pad but it is not moving correctly and is very jumpy and is always a distance away from where you are touching.
  • 3 more comments
  • bowmanfarmin May 19, 2011
    tried both your suggestions but it still isnt functioning correctly. it is as though the screen on the actual computer is larger than the touchscreen input area. we find it almost impossible to select any option that is less than an inch and a half from the edge of the screen. if you drag the tapper across the screen the mouse pointer follows but is always an inch and half behind which means that you cannot select anything near the edge of the screen, which is where most of the control buttons are!! when you run out of screen to drag across the mouse pointer jumps and returns to the middle of the screen forcing you to start again. the touch pad has the same effect. I have tried recalibrating the touch screen but cannot complete that task because i cannot tap on the red crosses near the edge because it doesnt think i am any where near here. The problem has been getting progressivley worse over time - yet sometimes still chooses to work ok. what should i try next????
    the usb mouse worked perfectly for about half a minute than refused to respond - it moved randomly across the screen whenever it was moved.
    thankyou for your help. I have ordered a refurbished CF18 to replace this one. If I remove the hard drive from my current machine and put it into the newly refurbished machine - will this fix my problems? the programme that we need is installed on our machine by a company in perth and we are not able to intall it ourselves without sending the machine away - which we dont have time to do - so we are hoping that by exchanging the hard drive into the new machine we should be able to get going again? also - is there any other place i can find the model number of the cf18 - i can no longer read the number on the sticker on the back of the machine?
    thankyou - i am awaiting the arrival of a new refurbished tough book and will clone the hard drive when it arrives. hopefully this will solve my problems and we can get on with the seeding job. thankyou for your assistance.
    President:
  • 1,216 Answers
Sounds as if the diver has corrupted, right click my computer icon>properties>hardware tab>device manager> and look down list for touchpad, click the + sign to reveal your touchpad(normally Synaptics), right click and uninstal or delete.
Restart notebook and the driver will reinstall and normal use should resume
if not proceed next
If u are having Synaptics Driver....then
check that Tapping is enabled...
follow steps to know that:
Open Control Panel..
Now Open Mouse
Now click on tab "Device Settings"
then Click on "Settings"
a new window popups
Click on "Tapping" which is listed on the corner of the window
Now after clicking on it...on the right...check that there is "Tapping Enabled or not"
if not...click on that White box...
and Apply
then ok
Done :)
Posted on May 18, 2011
  • 1 more comment
  • Aviral Saxena
    Aviral Saxena May 19, 2011
    in that case you must plug in a usb mouse and see if it is working.
    try collaborating again
  • Aviral Saxena
    if your mouse failed to respond , i am afraid there is a bad news for you
    While it's unlikely, there is a chance the touchpad's connection to the motherboard may have broken, perhaps due to heating malfunctions or other internal problems. The connection to the motherboard is delicate. If the computer has been worked on recently, it's possible the technician forgot to reconnect the touchpad.
    If the touchpad driver works properly but the touchpad still does not function, the connection may have failed. Checking and repairing the connection requires the computer be partially disassembled. It is not a repair to be undertaken by an unskilled technician. If a motherboard problem will require its replacement, it may be more expensive than the computer's value warrants.and as per my experience i suspect a motherboard fault.
    Sorry for such a bad news.
  • Aviral Saxena
    you may do so.
    ...but i found wonders for your problem
    If you upgrade or replace normal hard disk, disk
    cloning software
    will easily complete the operating. If you want to
    replace your operating system hard disk, chances are the new one will
    be both faster and larger than your original disk. Since you can have
    multiple drives in your system, it makes sense to keep operating system
    on the fastest drive, since its speed will make the most difference in
    that configuration. But the trouble is, the system cannot just be copied
    over from your old drive to the new one. There are essential files and
    applications will not be created on the new disk if you try this. What
    should we do now?
    Of course you can choose to reinstall operating system on the new
    hard disk drive, which means reinstalling all your software and redoing
    your personal configurations all over again. The programs installed on
    the old hard disk will not work on the new system installation because
    the registry. No matter which system you use, Windows 7/Vista/2000/XP or
    Windows Server 2008/2003/2000, run any installed programs needs
    necessary information, but the brand new operating system will not
    contain it to make them work.
    Don't worry! EASEUS Todo
    Backup
    - powerful backup &
    recovery software
    can clone operating system disk to new hard disk
    drive without system and applications reinstallation.
    Steps to upgrade system hard disk drive
    If you want to move your Windows operating system to new hard disk
    drive which is replacing your old one without needing to reinstall
    system, software and any settings. Do as the following says.
    • Launch EASEUS Todo Backup and click Clone.
    • Select Disk clone.
    • Select source disk you want to clone.
    • Select the destination disk. You can also tick "Sector by sector
      clone" option to do sector-by-sector clone, it can clone all sectors
      from source disk to destination disk.
    • Preview your source disk and destination disk after cloning.
    • Click Proceed to clone the disk.
    After finish the operations above, shut down the computer and
    then replace source hard disk with the destination hard disk.
    i believe it can't get better than this so if i helped you please accept this solution.
    Thanks
Transfer books from Kindle to iPad
You are able to move the books to computer, and then sync ebooks to iPad with iTunes. When the Kindle users connect their Kindle tablets to computer with the USB cable, their computers will recognize their Kindle tablets as external hard drives. Then the users can copy and paste the ebooks from Kindle to computer easily. After that, the users are able to sync the books from computer to iPad with iTunes.
This is easy to be done. But when users begin to sync their iPad with iTunes, they may come up with the sync problems of iTunes. The problem may come up when users sync ebooks from iTunes to iPad. During the sync, iTunes will erase all the non-purchased items in your iPad mini. If you are new to iOS devices, you will probably lose files during the sync with iTunes, so you'd better close the auto sync and manually sync the ebooks to your iPad mini with iTunes. The following tutorial will be helpful if you aren't sure about how to accomplish the task:
  1. Start iTunes and go to "Edit > Preference > Devices", and check "Prevent iPods, iPhones and iPads from syncing automatically".
  2. Plug iPad into computer via USB cable, and the software will recognize your iPad and display the iPad icon at the upper right corner.
  3. Click the iPad icon and choose "Books" in the summary panel. Choose the books you want to sync to iPad in the list below, and click "Apply" to start.
How to Transfer Ebooks from Kindle to iPad mini
Sep 29, 2015 | Tablets & eReaders
Have downloaded e-books from the library, but can't delete them from my Nook.
For some books, downloaded from your PC, the only way to delete them is to attach the Nook Simple Touch to your PC and open the Nook Simple Touch on the PC. (For a PC, open the computer icon and look for the Nook icon and click on that.) From your PC you can delete files from the Nook Simple Touch or move them off the Nook Simple Touch to your PC.
IF you have a MAC or if my advice doesn't work, you should contact the Nook support. It is at the Nook website. Click on Nook and look for Nook support.
Jul 30, 2015 | Barnes & Noble NOOK Simple Touch eReader -...
Why doesn't my Coby Kyros MID7047-4 display the text of my kindle books?
Try deleting your current books and then re-syncing. Your files seem to be corrupted during download.
Jun 03, 2014 | Coby Kyros MID7047 4 GB Tablet - 7" -...
Why does my Coby Kyros MID 7047 not show text of my kindle books? I just bought the Coby MID7047. I downloaded the Kindle app. It installed, synced and downloaded my kindle library. But when I open
Coby sent this to me asking for my solution, But I'm the one who asked the question in the first place and I still haven't found or gotten a solution.
Jim
How do you find the sim card phone number on cf18 panasonic tough book
Hi
Go to the phone book click the option and select the sim contact. you get your sim contact.
Jun 01, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Hello i have a panasonic cf18 toughbook that it need to change its windows xp all,after change of it there is a problem left, and it is :all of its facilities such as touch screen,modem,bluetooth...dont...
you should find those drivers on the panasonic support site---if not, go to driverguide.com---
there are 1,000's of free drivers you can download for free.
Oct 14, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
My pen for my computer won't work
I think the pen has gone bad on you, since your screen can still detect your hand and the track pad. I would think the pen is faulty. Try another pen cause I think your original is bad, if it was the touch feature that wasn't working I would say its a driver problem but that feature still works with the exception of the pen. Get another pen.
May 31, 2009 | Dell Latitude XT Laptop Computer Tablet...
Panasonic touchbook cf18
When I touch the touch pad my screen display goes off. it comes on sometimes by itself or when touch pad is touched. I have connected the toughbook to an external dispaly and can work no problems. help
Oct 22, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
836 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Mike
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
