Question about Canon A3300 IS Digital Camera
I have a new Canon A3300 IS and a new SanDisk SDHC 4 GB memory card. It's worked fine for a few days, and now suddenly, I get a "Memory card error" message, and the camera won't work. I tried reformatting the memory card, but the camera refuses to do it. What happened? I assume I need a new memory card, but I'm afraid that the problem will occur again.
  • dembart May 18, 2011
    Unfortunately, that didn't work. Windows refuses to format the memory card.
    In addition, since the card failure occurred unexpectedly and all of a sudden -- I didn't do anything that might have caused it -- I'm not sure whether it's the card that's faulty or the Canon A3300 camera itself. If it's the camera, I've got a real problem.
    Thanks for your help.
    Right. It's the card that's no good. But my question is what caused the card to fail suddenly? If the camera did something to it, then it's likely to do the same thing to a new card, too. In that case, I want to return the new camera for a refund.
  • 4,889 Answers
Insert the card into a card reader and format it on the computer. See if that works. Format using FAT32 as its more reliable than the FAT it uses by default. If the camera supports FAT32 you can expect it to last atleast a year before you need to format it again
Posted on May 18, 2011
  • eagle338
    eagle338 May 18, 2011
    If windows cannot format it , then its definitely the card. Damn sure. A new card should work just fine!
  • eagle338
    Some cards arrive with factory defects and are likely to go bad as it happened to me once . I do not think it will happen again . Also if the Card is the one that you got with the cam there is warranty on that too
Canon Power Shot SD450 Digital Elph camera started to say "no memory card" when there is Sandisk 2GB in there? What can i do?
2 things the memory card and the recovery of your files.
Your camera was produced in 2005 and in those days only MMC and SD cards could be used. A few years later the SDHC came and 2011 SDXC came. devices are downward compatible. So newer cameras can use also SD cards. But older cameras can't use newer memory cards. Even a SDHC can't be used in your camera. And although I managed to buy a 4GB SD card a few years ago, now they only produce SDHC and SDXC cards. Yes be aware a 1 GB or 2 GB card now ar most of the time SDHC.
Check your card, when it says SDHC, don't try to us it, it won't work.
Then the photos from your parents. It looks we never have taken enough pictures.
When you have old memory cards, please don't use them till you checked if there are still "deleted" pictures on them.
Deleted is most of the time just clearing the pointers to the files. The files in most cases stay on the card.
Try to download some software from this site:
Memory Card Data Recovery
Then run the software, when you have a memory card in a memory card reader and see if it can find "deleted" pictures. Be aware when you use a card with "deleted" pictures, the space that came free, will be used to put new pictures there. SO don't use the cards till you did recover everything to the computer.
There are more free recover program's. I have one form Sandisk, I got it for free with a sands memory card. Login on that site to and see if they still have free program's for Sandisk users.
Success
Feb 19, 2015 | Canon Cameras
I have a Canon PowerShot A540 Digital Camera I got a new memory card it is a sandisk SDHC 8 GB but I am getting a memory card error message.... What can I do?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problemlisted here.
Oct 01, 2011 | Canon PowerShot A540 Digital Camera
I bought a brand new Sandisk 4GB memory card for my Canon PowerShot A520. The camera registers my other memory card just fine, but this card says Memory Card Error. I checked for locked position, and it is...
The 4 GB memory card is not compatible with the camera. It's a SDHC card (high capacity) and the A520 only supports SD cards. (The difference between the SD and the SDHC is similar to that of single layer and dual layer optical discs. Not all drives can handle both formats.)
Documentation for the camera is here: http://usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a520#BrochuresAndManuals .
I wish that I had better news for you.
Jul 30, 2011 | Cameras
Hello I currently have a 2 GB memory card in my canon SD 1000, camera i want to upgrade to 4GB memory card, what is the best brand or type? Will 4GB SDHC memory card work with my canon camera? ...
The Canon SD1000 will work with SDHC cards, up to 32GB in size. Stick with any of the major brands and you won't have problems.
The HP 7350 will NOT work with SDHC cards, limited to SD cards 2GB and smaller.
Mar 26, 2011 | HP PhotoSmart 7350 InkJet Printer
I have a SanDisk SDHC Card class 4 4 gb and it won't work in my Canon Power shot SD630, I get a memory error that says card is locked, however card is not locked, what camera canI use this card in?
The SD630 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
Your SDHC card can be used in any camera that accepts SDHC cards.
Feb 03, 2011 | SanDisk 4GB Secure Digital High Capacity...
I have one canon camera, presently i am using sandisk 1GB memory card without any hassel. recently i purchased one Sandisk 4GB memory card. after putting this new memory card into the camera, I m always...
A 4GB memory card will be an SDHC type. SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 22, 2010 | Cameras
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
I want to upgrade the memory card of my Canon PowerShot A570is. What memory card should I buy? The last that I had was a SanDisk 1.0 GB.
The camera supports SDHC memory cards, so any SDHC card should work.  If you shoot video the cards with the faster write speeds are better.  The SanDisk 4GB or 8GB cards should work well.
Apr 26, 2009 | Canon Cameras
Sandisk memory card
Has this card EVER worked with your camera? Since you didn't mention the model number of the Canon, it's possible that you have a compatiblity issue here. Most 4GB SD cards these days are actually SDHC cards, which store memory differently (in sectors, like a hard disc drive, rather than bytes, like your main memory). All SDHC compatible cameras also support SD cards, but cameras sold before the SDHC standard was created will not support SDHC memory cards.
There's a chance that Canon has a firmware upgrade to solve this. You would have to look on the Canon USA web site for this, based on the model number of your camera.
Jan 20, 2008 | Cameras
Canon A3300 IS Digital Camera Logo
88 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
