My wife has a 2003 Ford Expedition. The air blows but not cold. The fuses, relays and switches have been checked and they are all good. Took the truck to my mechanic and they stated that the clutch was burnt out, therefore a compressor and clutch was needed. A new compressor was put on but still the clutch is not working. Overall, there is no fire to the clutch to get it to click on. I have kids and they ride with my wife from school. It's hot and they need cool air. What can I do if anything without taking it to a mechanic?
    Sergeant:
    Champion:
  • 426 Answers
HAVE YOU HAD THE AC COOL LENT CHECKED
Posted on May 18, 2011
2014 Ford Expedition AC Blowing through the floor vents even when HVAC controls are set for dash only.
Look for a vacuum line off or something stopping vacuum-operated doors from being able to open and/or close doors in or under the dash, or near the floor.
Apr 24, 2017 | Ford Cars & Trucks
2004 ford expedition fuse box diagram. looking for any fuses that have to do with starter?
In the central junction box, 30A FUSE 101 applies to the starter relay; 30A FUSE 102 applies to the ignition switch.
Mar 07, 2015 | 2004 Ford Expedition
Is there a fuse or relay for the heater in my 2002 ford expedition
No hot air is due to low coolant, or even poor coolant flow. The engine heats up the coolant, and it passed through your heater core, and the heater blower motor pushes air through the heater core to warm up the air. If your "fan"is working, but the air is cold, make sure your coolant level is good.
Dec 08, 2011 | 2002 Ford Expedition
My husband needs to know if there is a fuse that could fail and make the rear air conditioner blow hot air.
no....This is the rear A/C & heater actuator blend door malf/broken. This is very common on expeditions and I encountered the same issue in my 2006 expy. This door switches from hot to cold vents, once stuck only hot air will blow. Also, is there any thumping or tapping noises from the right rear panel (this is where the rear a/c unit is)???
May 05, 2010 | 2003 Ford Expedition
Heater blows cold air on my 2000 Ford Expedition
Have had the same problem 2000 ford expedition. got it working good now
Mar 03, 2010 | 2000 Ford Expedition
Front A/C won't blow, rear works fine. 2002 Expedition
Check the fuses for the blower motor and check power to the front switch to the blower.
Jul 20, 2009 | 2001 Ford Expedition
1995 ford explorer
blower relay or resistor bad.also the AC and HEATER control switch could be bad.
Jun 29, 2009 | 1997 Ford Explorer AWD
Front heater only blows warm air when engine is at a high rpm. rear heater blows cold air all the time. replaced thermastat and coolant
It could be a couple of things.
1) Check the fuses to make sure they are good.
2) It could be the relay switches, that happens occasionally a mechanic will need to look for that problem though.
3) The blower motor could be on the fritz. depending on its location a mechanic might need to do this also.
I hope this helps out.
Feb 13, 2009 | 2003 Ford Excursion
2003 ford expedition
If you have check the fuses it is possibly a relay in the main fuse panel.
hope this helps
Nov 06, 2008 | 2003 Ford Expedition
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
