Question about Boating
I have a boat that has a 90 hp johnson outboard on it and when the previous owner had it the oil injection went out so now you have to mix gas. i took it out yesterday and it doesn't want to idle and it doesnt like low rpms it does great in high rpms. also when you shut it off and start it you have to rev it a while before you can get it into drive wwithout it dying. he said one of the rings might be bad or something from the oil injection going out. would this be my problem like could oil/gas be getting where it shouldnt be?
  • 677 Answers
Ok.Get a compression test done.That will solve the rings debate.If you premix the fuel,it has to be at 50/1.If the comp test is within 10% of each cyl,all should be ok.Hope this helps
Posted on May 20, 2011
  • caleb swenson May 23, 2011
    50/1 is what i run i was wondering if i ran some seafoam in the fuel if that might help clean it out and run better since it sat for two years outside in MN without being winterized or anything.
  • thomasnee May 23, 2011
    The carby's may need a good clean and throw in a new set of spark plugs.Get the water pump done.When they have sat for that long it WILL need it.Better than cooking the motor.
Do you mix the gas or just straight gas, where do you check oil
that old oil is to be mixed into the fuel 1 pint per 6 gallons of gas . only other oil is the gearcase lube
May 15, 2016 | Boating
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
http://www.cottagetips.com/tips/boat-motor-gas-to-oil-ratios
Apr 15, 2016 | Boating
What type and weight of oil for johnson 28 horse outboard boat moter
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Jun 29, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
What type of petrol is needed for a yamaha outboard motor horsepower 8?
reg unleaded gas.
You haven't specified as to its year of manufacture, so if its older, as in a 2 stroke, it'll be a mix of gas and outboard oil.
If its a newer model, a 4 stroke, it'll be injected(Gas and oil seperate)
If you are totally unsure, Consult your owners manual and if you have none, then any Yamaha dealer can use the serial # off the motor to establish any specs on it for you.
Happy boating.
Oct 04, 2009 | Boating
1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Jul 16, 2009 | Sport & Outdoor - Others
Johnson 1998 175 hp motor seems to be in safe mode
U CAN DISCONNECT THE OIL RESOVIOR SWITCH THAT TAKE IT OUT OF SAFE MODE BUT IM LEANING TOWARD THE POWER PACK
Jul 12, 2009 | Light Outboard Motor Boat Bass Fishing...
Are the 1988 Johnson vro oil injection system dependable?
the older ones are dependable but they all exspecly being that old its better to be safe than sorry its if it were mine i would mix the gas thats what i tell all my coust the 90 thr 1999 omc vro were terrible the fill the carbs full of oil so i would just mix it that way u know its right just use good oil and that engine will last a very long time good luck
Jul 07, 2009 | Boating
Hi. Just a quick one: I just bought a 1996 Johnson J35QLED. Do I have to mix oil & gas?
Is there a place under the cowling to put outboard motor oil if not mix 50 to 1 to be safe if will not hurt the motor to add oil to the gas,but if you dont you will burn up the motor. Jim OMC REtired Mech
Jul 03, 2009 | Boating
Boating Logo
97 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
