SCREEN STARTED DIFF COLORS, RASTER DARKENED, SCREEN SHRUNK, BUT AUDIO OK , THEN EVERYTHING QUIT . HAPPENED OVER A 2 WK PERIOD TOOK TO A SHOP , THEY SAID T-CON BOARD BAD , WANTED 400 TO FIX , UNIT ONLY COST 500. 2 YRS OLD , GOT UNIT BACK
  • joebriggs May 19, 2011
    THE MODEL IS A 32" SAMSUNG LED LNS3241DX/XAA
    I AM THINKING MORE ITS THE POWER SUPPLY BN96-03057A
    BECAUSE OF THE SHRINKING SCREEN THEN NOTHING ?
    THANKS ,JOE
  • 19,396 Answers
Hi.
LCD TVs do not have convergence circuit. If display shrunk then it is likely the T-Con board. The other option is a defective PSU that caused the whole TV to malfunction and shut down.
Note: If the technician has opened and tested the TV, and he found the T-con board is faulty, then the TV is not worth repairing. The below is in case the technician did not test the TV.
When you go to a repairer they always give you a quote on the most expensive fault. The only other option to get a quote is having TV tested. If it is PSU, then repair will be below $200 (DIY below $100 if you know how to test).
The problem with the T-Con board is that with most TV models the T-Con board is not sold as separate part, but as one single part integrated with the display panel. Because of this reason when problem is T-con board, the TV is not worth repairing.
About the PSU, the LCD power board is quite difficult to test for a person without technical training. Sometimes it is however possible to spot bulged or melting capacitors or burnt areas.
A PSU for an LCD TV is usually below $100. The part must be tested before replacement.
If TV has already been tested and the tech found a defective T-Con, then replacing the PSU will unlikely help (PSU is the first part we test).
I can be more specific on parts' price if you give me the TV make and model number.
Regards.
Ginko
Posted on May 18, 2011
  • Ginko
    Ginko May 19, 2011
    Hi.
    As far as I know the SAMSUNG LNS3241DX/XAA is not a LED model, but an LCD model using back-light system.
    Sometimes it is possible to see that the PSU is damaged at a glance. More commonly the PSU must be tested.
    Proper testing consists in checking the power cord and its soldering joints to PSU in main power connector ; testing the Zener near the AC connection; testing components in AC section of PSU. Testing components and tracking voltage in the DC-DC section of PSU; replacing defective components; testing voltages out.
    In their service documentation Samsung suggests to replace PSU straight away without testing. This was because the simple PSU used in this model was relatively cheap (less than $50)
    PSU part number is BN96-03057A.
    Unfortunately the PSU is out of stock almost everywhere.
    The cheap options are all sold out :
    BN96-03057A BN96-03775A PSLF201501B Samsung Power Supply
    $39.99 - RetechTV.com
    BN96-03057A POWER SUPPLY PSLF201501B
    $38.00 - DiscountTVParts.com
    Samsung BN96-03057A Power Supply
    $49.00 Shopjimmy
    The following merchant has the part in stock, but it is more expensive:
    If that is not available use the substitute part: BN96-03775A. According to Encompass (one of the bigger sellers), part is compatible. Part is also out of stock almost everywhere. Here last one in stock from one seller.
    Use parts numbers in Google to explore more options. The PSU for this models are all gone. That means that they fail quite often.
    Regards.
    Ginko
Hi, I had a problem with my Sony CRT television.
The faint background lines are vertical flyback lines. Start your diagnosis by turning the brightness and contrast controls to minimum and view the screen in a darkened room. If you can now see a raster with horizontal lines visible then it is likely that the tubes A1 screen voltage is excessive. The screen voltage is usually within the range of 400v to 600v. Adjustment for this is often part of the flyback transformer. Check all high value resistors
in the screen and focus circuitry. Some of these reistors may be
built into the flyback transformer. As the picture gets brighter the beam current increases, this will eventually cause the X ray protection circuits to trigger shuting off the set. A fault in the video drive circuits to the cathodes of the tube will cause similar symptoms but usualy results in a predominance of one colour, ie
bright red, blue or green raster with flyback lines.
Oct 20, 2013 | Sony KP-53HS10 TV
My problem started out pretty confusing. One day I turned my lap top on and the screen, after about five to ten seconds of being on, went black. I could see things loading up sort of but the screen was too...
Darkened screen as you describe indicates a failing inverter. You can test this easily by plugging the laptop into an external monitor, if this works ok, then the inverter needs replaced, If it does not work, the problem is with the graphics chip / motherboard
Jan 18, 2011 | Dell Inspiron 8000 Notebook
My screen has shrunk to the middle of the screen. i have tried the horozontal screen size and theres no difference. this is happening on windows xp
Simple test: unplug all the cables from the monitor, start it alone and launch the settings window of the monitor. If the image is also shrunk there then the monitor is defective, about to die.
Take it to repair shop as fast as you can, otherwise it will fail for good and it will be unfixable.
Nov 12, 2010 | Computers & Internet
Polaroid tda-03211c - While I was using it as a PC monitor, it suddenly showed a few thin colored lines on the bottom fourth of the screen and then went to a black screen. I can see light on the screen,...
Look at the venting grill to see if you can see any whit lights inside behind the LCD panel, you may have to do this in the darken room, if you do see the light then at least the back light inverter is still working (inveter board failure is the common problem, same for the power supply, then the problem can be in the LCD driver board not working, or power supply is bad. Please post what you find.
Nov 15, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
Dead
dude i dont know if this will help you or not but the same thing happened to mine and im an electrician, so i took it apart and screwed around with it and everything seemed to be cool so i took it to a tv repair shop and they fixed it and it only cost me $65.00. he told me that the power supply motherboard burned out for good.
Nov 14, 2007 | Memorex MT2206 TV
Everything in picture on television are green
The basic colors in the TV is RGB & each color has a diff amplitude & frequenc. It seems that the IC controlling the RED & BLUE has lost some of it's capabilities due to lower voltage supplied/regulated by the chip, which generally happens after quite long period of usage. However this seems an inherent fault with visio & most of the early sets do not have this problem sorted out at the manufacturing level & is a problem for most of TV's which are unpredictable & could occur in a month or year. If still under warranty, pressurize your dealer/distributor/service center to sort it pronto or ........... face the consequence..........sodeep
Sep 23, 2007 | Televison & Video
Sony trinitron 32 in. pip no video, (raster, with audio)
What you have described there is a classic example of the jungle IC failure. Ic301 Sony p/n 8-752-101-04. A pic with no color, and lines or grainy texture in the picture. Not a project you want to tackle if you don't have the proper soldering equipment or skills. And not a costly one at a good repair shop.. Only real hurdle is getting that heavy monster into the shop. To answer your question, yes what you described there is raster. Even the salt & pepper looking screen with no real decernable image is described as raster. In fact any image generated on the CRT is raster. And yes, these sets are prone to solder joint problems, usually ring cracking in circuits that generate the most heat.
May 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
DARK HORIZON AREA AT TOP OF SCREEN
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Jun 07, 2006 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
