Question about SpeakerCraft Audio Players & Recorders
It won't turn on. The fuse still looks ok. BB1235
  • yadayada
    yadayada May 18, 2011
    Look ok, did you you test it with an ohm meter?
4 Suggested Answers
  • 14 Answers
SOURCE: ac won't turn on heater ok all fusees an relays ok 2000 silverado
When you hit the button, does the light come on? If so, and there is no cold air try a freon charge kit with dye in it. These kits are relativly inexpesive and come with yellow glassed and a UV flashlight. Fill the freon and let it run for a couple days. Then using the glasses and flashlight in a dim area, look for splashes of green. THen you can get the oring or what ever is leaking, change it, then have a pro evacuate and re-charge the system.
Posted on Jun 02, 2012
emissionwiz
  • 75822 Answers
SOURCE: no turn signal, hatch won't release, no horn, fuse ok
Are you sure you don't have a low battery? have it tested first then check for other problems if the battery tests ok.
Posted on Sep 04, 2012
  • 57 Answers
SOURCE: power door locks won't work and the instrument pnnel lights won't turn on. I replaced blown fuse a 20mp one in position 14 I believe. worked ok till I tried to lock the doors, the fuse blew
Hello. Try looking at the black earth that goes from the drivers door and into the A frame which is covered in a rubber sheath. The wire can break after opening and shutting the door over several years and as it's normally the thicker wire is more prone to break. Also check the other wires visually for any chaffing and tugging on each wire. If more electrical parts start failing, air con blowers etc it will be an earth. Hope this helps
Posted on Nov 03, 2012
Power door locks won't work and the instrument pnnel lights won't turn on. I replaced blown fuse a 20mp one in position 14 I believe. worked ok till I tried to lock the doors, the fuse blew
Nov 03, 2012 | 2002 Dodge Neon
Toyota 4 Runner park lights won't turn off
faulty connection ,or check all your fuses from box,check fog lights fuse 1st,
Oct 29, 2012 | Toyota Cars & Trucks
Won't turn on
Check the fuse in the plug. If that's ok then the fuse on the board might of gone. & if that's ok as well then the trancformer has gone bang.
Sep 10, 2012 | Technics SL-BD22 Turntable
No turn signal, hatch won't release, no horn, fuse ok
Sep 03, 2012 | 1996 Chevrolet Blazer
Our 2002 alero won't turn over /start with key but starts by jumping. Test shows battery and fuses OK
Look for a light that says SECURITY or ANTITHEFT on the dash. This light could cause this problem. Explained on this link.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 18, 2011 | Cars & Trucks
My headlights won't turn on, the yellow driving lights turn on but the headlamps won't. Also the lever that controls bright lights doesn't work but the turn signal and cruise control does.
First check the headlight relay by changing it with one of the same number in the fuse panel.If it checks out ok then you have a faulty headlight switch.
Nov 03, 2011 | 1994 Chevrolet Caprice Classic
The radio won't turn on in my 2000 nissan maxima.
could be as simplet as blown fuse for radio. i would start there. look at your "audio" fuse in the fuse box. if thats ok, then you have something elses goin on, but start with fuse check.
Sep 04, 2011 | 2000 Nissan Maxima
Low beams dont turn on........... bulbs check ok...................fuses under hood ok.............need help
{: ) I wonder how you checked the fuses and the bulbs. Did you check also the HDM fuse 15amp and the HDM relay both at the underhood fuseblock? Turn on the low beam and check for 12v at the LO beam fuses. If there is voltage at the fuses but the low beam ok bulbs won't light, then there's a wiring issue from your fuseblock going to the bulbs.
But if no voltages on the LO fuses when the low beam is switched on, then the problem could be on the HDM fuse or relay, the headlamp switch, the BCM, or even the fuseblock.
Jul 02, 2011 | 2006 GMC Envoy
My SpeakerCraft BB1235 was the only device in my house that stopped working after an electrical storm. I checked the fuse in the back, but it is not blown. I also opened the case, but there was nothing...
I can't really say what failed in your unit, but as far as electrical storms go, it could be just about anything, so i can only suggest some possibilities:
- ANY of the components sensitive to static electricity (fet transistors, cmos ICs) may have recieved a fatal voltage spike
- in general, ALL of the semiconductors are to be regarded as sensitive to static electricity even if some of them may be able to sustain quite some spiking, so bipolar transistors, diodes or diode bridges, voltage regulators, optocouplers and ICs of any kind are also on the list of possible fatalities.
- other components that may have been damaged are the low voltage capacitors, sometimes they will blow up, sometimes there will be a very tiny crack or a burn spot which is very difficult to notice, and sometimes it will be only internal damage so it is impossible to track it down without measuring or scoping the circuit
- it is ok to check for any internal fuses (standard type, auto recover type or semiconductor type) and see if they are ok
- also see if there are protection varistors near the main power input and check them out, sometimes they may fail
Hope it turns out to be some minor damage.
regards
Triarcuate
Sep 29, 2009 | SpeakerCraft BB1235 12-Channel Amplifier
Top SpeakerCraft Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
James Oliver
Level 1 Expert
Electro Med Services...
Are you a SpeakerCraft Audio Player and Recorder Expert? Answer questions, earn points and help others
