Question about Kirby Vacuums
My techdrive will not work my wheels - Kirby Vacuums
My Sentria is possessed......when we put it in drive......it goes backwards!!!! Help???
I saw videos it may be the transmission because it makes your kirby easy to push. It is working backwards so it may be the gears. This video will work for any Kirby that has TechDrive
Aug 17, 2014 | Vacuums
Broken techdrive
Your Transmission fork has becime disconnected. You need to pull the transmission and make sure that it is installed correctly, Check the following and pay attention to picture number 17. I had the exact same problem which occurred because I dropped the Kirby hard after lugging it down the stairs, it is a very easy fix and I am a banker, not a repair guy. Good Luck! http://www.goodvac.com/kb_results.asp?ID=16
Nov 27, 2011 | Kirby Ultimate G Bagged Upright Vacuum
The lever came off (drive/neutral)
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Kirby g5 techdrive n/d pedal came off will not stay on
The pedal will need to be replaced. A shift mechanism pressed on the end of the shaft has come off and cannot be re-installed. The drive unit must be removed from the machine, and the pedal assembly and shift cam can then be replaced. This may not be a do-it-yourself repair, as a good deal of disassembly is required.
Feb 04, 2011 | Kirby G5 Bagged Upright Vacuum
The TechDrive Pedal on my Kirby G6 fell out of the back of my vacuum cleaner. I removed the screws from the metal plate one the bottom to try to see if something had come a loose. Can you send me a diagram...
This requires removal of the transmission assembly and replacement of the pedal assembly - it cannot be repaired. The handle and upper motor shell must be remove to access the transmission assemby. There are two screws in front, and two under the plastic switch plate.
Jan 18, 2011 | Kirby G6 Bagged Upright Vacuum
The techdrive of my Kirby Vac fell off why and how do I fix it. I am an electrician.
The pedal assembly must be replaced, as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items.
Jan 05, 2011 | Kirby Ultimate G Bagged Upright Vacuum
TechDrive power assist fell off
See if THIS helps.
Not sure how far you went disassembling the unit so here are a few more useful articles that you may want to see:
How to connect wires
How to get the transmission installed.
Rocky
May 30, 2009 | Kirby G5 Bagged Upright Vacuum
The headlight on my Kirby doesn't work!
A few problems exist in this situation.
A. Is the bulb you put in a genuine kirby part?
If not it is probally not the correct anperage.
B. Are the little medal pieces on the end lined up correctly? If not adjust and retry.
C. The socket the bulb fits into is bad. In that case call 1-800-948-1358 mon.-fri. 9am-6pm est
sat.9am-2pm est and ask for josh or buck to order the socket.
Apr 16, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G5 Techdrive pedal
Kirby N/D pedal is an assembly that can not just come out. So I would say that it is most likely broken. See THIS ITEM and if the part that was left on the floor is just a part of what you see in the picture then it is broken.
It is possible to assemble it back together but usually it falls apart again fairly quick and it is hard to get the angle at which pedal must be reassembled. We usually do not mess with it.
Good Luck
Aug 08, 2008 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
