SOURCE: Bluetooth Notebook 5000 Mouse will not connect.
You may just need to re-PAIR it. You need to press and hold the Pairing button until you get a solid blue light then it is in pairing mode, you can then discover it on your laptop and complete the pairing.
SOURCE: how do I use bluetooth
First you have to "Pair" the bluetooth and the phone. Then make sure that the bluetooth function of the phone is turned on before you turn on the bluetooth.
SOURCE: HAICOM HI-408BT Bluetooth receiver will
That is a major malfunction of the unit. I believe this unit has a reset button on it, or can be reset from a menu. Try that, does it at least acquire satellites after that? If not there is something major going on.
Let me know,
Tim
SOURCE: v470 logitech bluetooth mouse has
you
might have to uninstall the mouse and its drivers then restart your computer
then reinstall the mouse and its drivers
click
start right click on my computer select properties device manager control
scroll to mice and pointing devices you might see a yellow question mark? right
update driver
click
start control panel mouse you should see 4 tabs buttons,pointers,pointer
options and hardware under hardware you have options to troubleshoot also you
can select properties under driver you will have the options update
driver,rollback driver or uninstall in xp
click
update driver in
make sure the battery is good
((has full charge))also you might test the usb device for the mouse is inserted
correctly into the usb port (if applicable)
Windows
7
hope this helps
SOURCE: Cannot establish blue tooth connection to ipad
try to turn on BT on iPad while Logitech is blinking (which means it in pairing mode and can be discovered). If that doesn't help I'd suggest to remove batteries from Logitech for 3-5 minutes then put them back.
