Question about Lexmark C912 Led Printer
I have a lexmark c912. One day I noticed the colors weren't lining up properly. Shortly after that, there appeared a color distortion in the lower right corner. It was as if the magneta wasn't printing. If I printed many copies some would be ok and some would have the corner printing incorrectly. I called a friend who repairs copy machines, we don't have lexmark representative here. He came and cleaned it and played with the settings and voila it was printing fine. However he says he doesn't know what he did to make it print right. This lasted about 2 weeks and then the color misalignment reappeared. My friend told me that after cleaning it he set all the print settings to (color, callibration, etc.) to automatic, but I don't find this automatic option. I have been looking for the calibration settings and all I find is the manual settings (ex. "Cyan +6"). Also, I am not sure that if I calibrate it that the corner color problem will be ok. I looked online and several suggested the transfer unit be replaced. I have purchased another (second hand) but I would prefer to know more before I just start replacing parts. If anybody has an idea what could be wrong and what I could/should do I would be very grateful. Sincerely, george
    New Friend:
    Problem Solver:
  • 16 Answers
The proper color alignment is in the Config settings. This should only be done a certified tech. Can really screw things up bad if you don't know what you're doing. I am a Lexmark Tech.
Posted on Mar 20, 2017
  • 1601 Answers
SOURCE: White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Posted on Nov 14, 2007
SOURCE: lexmark X1195
I re-cleaned cups and wiper between cups with syringe and meth. spirits. Also realised that the cartridges that I had tried that hadn't printed could have melted the jets, so found an old one , filled it right up, then withdrew at least 2cc with refill kit tools. Prints fine now.
There was a lot of sticky ink residue on the wiper (what I assume the strip between the two rest cups is) that could have blocked jets.
Posted on Mar 15, 2008
  • 2794 Answers
SOURCE: My Lexmark X75 PrinTrio Won't Print Color
Go into the control panel. Select printers. Move the mouse over to the printer icon. Press the right mouse button. Select properties. Select printing preferences. This is where it changes my mfg but make sure that print in grey scale isn't checked off or any other settings in the finish section that would disable you from printing in color.
If that doesn't work, it could be the contact points going to the cartridge on your printer. It could be the ribbon cable. If these are the case you should take it into a shop to specifically pinpoint what the problem is.
Posted on Jun 21, 2008
SOURCE: white lines, starts printing 1/4 of page down
due i have also same problem..but the problem is that there was a slot of toner which is broken thats why its come.the main problem is that we cant by the slot have to by the total toner!!damn
Posted on Apr 08, 2010
  • 1087 Answers
SOURCE: Lexmark c532n prints smudges on page
The problem could be caused by the photoconductor units. Try to swap the affected photoconductor units (like swap the magenta with black and cyan with yellow). If problem still occurs, then the photoconductors need replacement. I suggest you contact Lexmark Technical Support for assistance. Thanks
Posted on Jul 26, 2010
Testimonial: "Thanks a lot. I just swapped the photoconductor units and now the smudges are black and yellow. I'll order a new unit. Your advice was very helpful."
Cracked Iphone 4 screen with distorted messed up colors.
Hi Connor,
Since the iphone is dropped from 4 feet, there would have been a physical damage to the display. If the phone is still under warranty or Apple care protection, you could take the iphone to Verizon store and replace the internal display. If the iphone is out of warranty, they might charge you for replacing the display for the phone. :-)
May 02, 2013 | Apple Iphone 4g Cdma 16gb Verizon
I've installed color cartridge but it won't print in color
Try to re-insert the color cartridge into the printer and make sure it is properly seated in the cartridge carrier.
If that doesn't help, try to clean the print nozzles. Please follow the steps below:
1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
Oct 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
New cartridge. test page printed just blue and black. typed some text using basic primary and secondary colors and colors weren't accurate and a blue line was printed through the text.
Unfortunately you have forgotten to say what your machine is?
Pls give us the make and model and we will know whether you have an inkjet or laser/Led printer.
May 30, 2011 | Office Equipment & Supplies
Lexmark C912 not reporting toner properly
print the status page make sure the revision level in the lower right corner is greater than 803.04 if its not go to lexmark to update the code if it is greater than. press the right arrow until reset toner Lvl appears in the display press select. use the right arrow to scroll through the colors to be reset. when you get tot the color you want to reset hit select it should give a brief message resseting toner then move to the next one. when finished you will need to power the machine down and back on again before the changes will take effect.
Nov 20, 2009 | Lexmark C912 Led Printer
994 Service Density Sensor Error Lexmark C912 Color Laserjet
What the error means:
The 994 Density Error indicates that the printer's system card has encountered an unrecoverable error.
What to do:
This error normally requires a service call. However, on certain rare occasions, such as a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 994 Density Error message to appear. In such cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to check.
Step Action
1 Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the page prints, the printer is functioning correctly.
2 If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to 'Contacting Lexmark' below.
Contacting Lexmark
When calling for service you will need to know your printer model type and serial number. If you need help locating this nformation, click here.
Call them while you're near the printer in case the technician asks you to perform a task involving the printer.
Jun 15, 2009 | Lexmark C912 Led Printer
Color distortion with HP 2300 scanner
Hp scanner 2300c
while scanning a blue or red line appears on scanned imajes
Mar 17, 2009 | HP ScanJet 2300C Flatbed Scanner
C912 horizontal lines in print
change your magenta led it sounds like that may be faulty big job if not theat then its a new rip baord which is under the cover
Mar 12, 2008 | Lexmark C912 Led Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Lexmark C912 Led Printer Logo
118 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
