Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
The service light is lit on my Krystal Clear Saltwater System Model CS81110, but I don't find anywhere in my owner's manual that tells what this means or what I should do.
thepool
  • 78 Answers
SOURCE: low water flow
Low water flow is generally and indication that the filter is dirty / clogged. Remove the filter cartridge and see if the light goes out. Replace the filter if required.
Posted on Apr 22, 2010
  • 2841 Answers
SOURCE: Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
Posted on May 30, 2010
Testimonial: "Thank you so much for taking the time and answering my question, I helped me a great deal. THANK YOU!!!!"
  • 297 Answers
SOURCE: I have a saltwater pool The pump we're using is
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?lst_docsea=2009&source=intexstore&gid=2&lid=8738
You should not blindly ad salt
you need a salt test strip that reads in #'s not color
get your water to 3000ppm any lower than 2800ppm and you will not generate enough chlorine
any higher than 3500 and you could get cloudy water and trigger high salt reading not to mention the bad taste
continue what you are doing in addition add 1 gl of liquid chlorine to shock the pool with cleaning your cartridge out every 4-6 hours
once it starts clearing up start using a non foaming algaecide every 5-7 days just use the directions on the botttle Since you already have an algae problem, even though it will be clearing up you should go for the maximum dose the first time
As for OUR pump/filter/salt combo it is a piece of ****
I do not know your gl of water but here is a generic set
a pool needs turned over 3-4 times minimum in a day
so if you have a 5000gl pool and our filter at 2000gl ph you need to run it at least 7 1/2 hours at bare minimum
I now run mine 24/7 I generate chlorine over night and filter during the day even when being used
also you should check the front of your motor where the hose goes in this catches debris and hair that the skimmer lets in
with these pumps you need all of the flow you can get
speaking of flow we do not get enough of it so it is very important to use the pool every day if you are not then at least brush it every few days once you are green free
another thing to do is once you get the pool back to swimable
Have your best swimmer get in and clean under the seems with a toothbrush inside the pool
in the liner you should have 2 seems in the floor and one around the bottom between floor and side
you now will have a build up of algae in these seems that will not completely go away with shocking since it is protected by being wedged under the seem
Physically lift and scrub
any more questions let me know
please remember to rate this help
Posted on Jul 21, 2010
SOURCE: My Krystal Clear Deluxe Saltwater
chlorine light does not come on, but there isn't any alarm codes.
Posted on Jul 03, 2011
briones93
  • 119 Answers
SOURCE: i looking for the Intex
Here's the link!
Click on the American flag next to your model number and a PDF of your manual will download.
Please take the time to rate and write a comment.. Thanks and Enjoy!!!
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?hid_windowname=null&lst_docsea=2011&source=intexstore&gid=2&lid=14313&hid_windowname=null
Posted on Aug 07, 2011
Why is my saltwater pool turning green?
balance the water with chlorine super shock it once in balance your chlorinator should maintain a chlorine reading if you have a heavy bather load you must shock manually
Jul 29, 2014 | Intex Krystal Clear Saltwater System Pool...
How do you reset the RCD/GFCI on Krystal Clear Salt Water System CS8100
Mine is located in the power cord, near the plug end, built into the power cord itself. If not there, then consult your owner's manual or look on the Intex website for the manual.
Jun 30, 2014 | Intex Krystal Clear Saltwater System...
My Krystal Clear Deluxe Saltwater System Model 8110 is not turning on
My pump works, but it wont turn to chlorine, so it then turns the water green, i looked everywhere and cannot find a solution, anyone that can help that would be great.
Apr 23, 2011 | Intex Automatic Salt Water System for ...
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
May 30, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
629 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
