Question about Aprilaire 600 Humidifier
The light is blinking to change water panel. should i wait til the beginning of winter or do it now beginning of summer?
    Genius:
  • Aprilaire Master
  • 1,033 Answers
Hello, i would wait untill fall when thebheatingnseason will begin. Most likey you will be using your ac soon anyway.
Posted on May 18, 2011
Both hi and lo light flashing, unit will not go on (used twice)
I have 3 exact units of the SWM5750DN-WM also and after cleaning them and put away for the summer (used in Winter 2016), and taking them out now (Oct 2017) for use, and all 3 are blinking green lights! The manual doesn't even list the blinking lights as a troubleshooting info... This sounds like a common occurrence so you'd think Sunbeam should have that readily available!
Anybody have a solution? I can't believe they are this fragile??
Feb 20, 2013 | Sunbeam Warm Mist Humidifier, SWM5750DN-WM
My carrier humidifier has a hose which drains into the laundry sink and a lot of water is coming out. Should this happen in winter? I thought water should only come out in the summer?
The humidifier should run in winter, however if the windows are fogged up it means the humidistat is set too high. Try lowerimg the setting on tue humidistat.
Jan 03, 2013 | Carrier SBP Humidifier
How to change from summer to winter
Can you give a little more info? Usually depending on where you live, people use de-humidifiers in the summer and humidifiers in the winter. If you need a humidifier year around, there should be nothing you need to do uther than filter cleaning and checking the water valve and cleaning the pan of mineral deposits. Depending on your water, you might need to pour a cup of limeaway in your pan and let it run for a couple hours. Then drain it, flush it, and let it keep running.
Sep 28, 2010 | Aprilaire 600 Humidifier
Indicator says " change water panel"
Go to www.aprilaire.com and order the water panel for your type of humidifier . The model # should be located on the humidifier. the box you get from them will have directions on how to change. you will then need to turnyour dial on the humidistat to TEST until the green light BLINKS, this will reset the panel reminder timer.
Jan 20, 2010 | Aprilaire 700 Humidifier
Change water pad but change water panel light is on
Turn the control knob to the
“Test/Reset” position until the “Change
Water Panel” light blinks to reset the
water panel change indicator timer.
(Blower must be operating and furnace
calling for heat.) Be sure to turn the
control knob back to the prior setting when finished
Oct 27, 2009 | Aprilaire 700 Humidifier
Aprilaire 600 - change water panel light stays on
Turn the control knob to the test/reset position untill the change water panel light blinks to reset the change panel timer. Make shure the furnace is running calling for heat.Turn control knob to prior setting after resetting timer. Hope this helps.
Feb 16, 2008 | Aprilaire 600 Humidifier
Aprilaire 600 Humidifier Logo
126 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
