Question about Frigidaire FRT17B3A Top Freezer Refrigerator
My freezer is no longer freezing food- why? - Frigidaire FRT17B3A Top Freezer Refrigerator
  • Frigidaire Master
  • 8,220 Answers
I looked up your model. This is a self defrosting model which features a fan motor for the compressor and the evaporator. If either of them 2 fans is out then the freezer won't work well. That is the first thing I would check. If only one of the fans is gone out then replace that fan and rock on. If Both fans and compressor are not working then hunt down the timer. It may be stuck in defrost mode. The timer is nestled up behind the cold control and light bulb inside the nice little console in the fresh food compartment. Look under the console for a hole about the size of a dime. Inside that hole a timer advance. Use a flat blade screwdriver to advance the timer till you hear the compressor and fans come on. If the timer is fine the next thing to look for is ice buildup inside the evaporation compartment. If you see that then the defrost heater and termination thermostat needs to be replaced.
If both fans operate ok but the compressor is not working then I would remove and inspect the compressor relay for wear. The cold control would be the next thing to take a look at. If it is open the compressor and fans will not run but the inside light will work.
My freezer is no longer freezing food- why? - themobilian_2360.jpgthemobilian_2361My freezer is no longer freezing food- why? - themobilian_2362.jpg><img src=
Posted on May 18, 2011
  • Dan Webster
    Dan Webster May 18, 2011
    If all them things check good let me know and I will tell you what to look for next.
Can i defrost a piece of beef cook it slice it then refreeze it
Yes you can. If it is roast beef you might want to freeze it in beef gravy. Make sure it is sealed real good and use freezer plastic bags or if you have a food sealing device to vaccumm seal it. Deep Freeze meats cooked or uncooked last longer in a Deep Freezer as well!
Oct 13, 2014 | Refrigerators
Why does the red light on my VF70 freeze r stay on all the time?
Warning light (red)
If the temperature warning light ? lights up, it indicates that the temperature within the freezer has reached a level where the safe food storage is no longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to a safe level for the storage of frozen food.
Dado
May 05, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
My fridge keeps freezing food
Hi Karen, this is JK. I hate to hear that you are having concerns with your refrigerator freezing. There could be various reasons why this is happening. There could be a faulty defrost thermostat or the vent from the freezer has been blocked and is forcing air into the refrigeration section. If we may suggest checking to make sure that items in the freezer are clear from the vents or walls in the freezer. If this is not an issue, it may be more of a technical issue and a Professional Service Provider would be able to better diagnose the issue. Hope this helps!
Apr 14, 2014 | Frigidaire Refrigerators
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Red Alarm Indicator Light
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
De Dietrich fridge freezer temperature
thermosyat in fridge posibly stuck
Aug 04, 2012 | De Dietrich Refrigerators
Got three lights on my whirlpool super chest freezer green red and orange. Orange one you can push in and this illuminates it. what is itn for?
This is a super freeze button, it is for when you get a lot of frozen food and put it in you can push the super freeze button and it bypasses the thermostat and runs the freezer constant to freeze the food quicker.
Apr 18, 2011 | Whirlpool Freezers
The center bar section between the two doors is extremely hot. Freezer is cool, but not longer freezing food. Ice maker is no longer working.
PULL THE REFRIGERATOR OUT AND REMOVE THE BACK PANNEL.ITS PROBEBLY VERY DUSTY A;SO CHECK THE FAN IT MAY BE STUCK.TURN IT TOGET IT RUNNING. WATCH IT FOR A COUPLE OF DAYS IF IT STOPS AGAIN YOU NEED TO REPLACE IT.GOOD LUCK!
ERIC
Jan 23, 2010 | Amana Freezers
Freezing problem
HI thanks for your question. try turning the thermostat to a lower, number. and clean all the coils at the back by the compressor. it might be all you have to do/ thanks the appliance doc. please rate my answer. thanks.
Oct 12, 2008 | Amana ATB1935HR Top Freezer Refrigerator
Freezer not freezing food even at highest setting
If the unit is running continuously and not maintaining the temperature cold enough the system may have a leak. If it is NOT running continuously the problem could be in the temperature control.
May 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Frigidaire FRT17B3A Top Freezer Refrigerator Logo
187 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
