The system has detected a problem with one or more IDE/SATA hard disks
    Guru:
  • 1,705 Answers
You have a hard drive problem.
If it won't boot because of this problem, then the hard drive with your operating system may have failed. If it offers several boot options, then choose safe mode and the use the scan disk programme (set out below for XP, other o/s slightly different) to try and resolve the problems.
Your hard drive is probably split into 2 partitions a large one for general use, a smaller one for backups and support data.
Try going to Start - All Programmes - Accessories - System tools - Scan Disk for both partitions
Posted on May 18, 2011
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 12, 2011 | HP Compaq 6720s Notebook
I have a Soltek SL-K8AV2-R1L with one 160 gb sata harddisk (with XP on it), a 40 gb IDE harddisk on IDE channel 0, and two DVD/CD-drives on IDE channel 1. Tried to reinstall XP but XP setup did not...
Welcome to Fixya. The first thing you need to check is if the SATA Hard Disk is detected in Bios. In the system information you will see there the list of the drives including the DVD and the IDE hard drive. You can also check the Boot Sequence or Priority if it is there. Please let me know if you find the SATA hard disk on the list.
Thanks
Apr 15, 2011 | Soltek SL-K8AV2-R1L Motherboard
Want to install a second sata hard drive, new drive not auto detecting, bios only identifies ide drives
HI popsrowe
Your problem is most likely the SATA data and power cables. for tips on the two cables. the system should detect the SATA hard disk automatically,
( you only need, setting the hard disk support as a second hard disk to the system in the bios setup )
regards
Jan 15, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
I attached a sata hard disk in addition to the existing ide hard disk drive in my pt800ce-a motherboard. But the system cannot detect the said sata hard disk. what should i do?
If your existing system is IDE motherboard your new SATA drive will not work as it will have compatibility issue, also the MB will not support it.
The same goes for RAMs, 2 uncompatible RAMs will make the PC slow down or keep shutting down....
I guess you have used an adaptor to connect a SATA disk/cable to the IDE MB, check that, it may be the issue also.
Regards
pls leave a feedback and reply
Nov 11, 2010 | EliteGroup PT800CE-A Motherboard
Sir my problem is that my SATA hard disk not detected by system. Also when i detect the SATA/IDE hard disk system hang, and nothing happen. But that time keyboard not hang. My SATA ports work...
Each PATA device (disk-drive or CD/DVD) drive has some small jumpers.
For the two devices connected via the one ribbon-cable,
set the jumpers on one device to the MA(ster) setting,
and set the other device to the SL(ave) setting.
Or, set both devices on the one cable to the C(able)S(elect) setting.
When properly set, both devices will be quickly and properly detected.
Be sure that your BIOS SETUP has been configured to allow SATA devices,
i.e., not set to "disabled" mode.
Nov 05, 2010 | Intel D915GAV Motherboard
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
Ive built my first pc and all went well until the message no hard drive detected comes on all parts are new so any help would be great in fixing this thanks dave
Verify that the hard disk is connected on both data and power cables and is receiving power (it hums at startup); also that the proper EIDE or SATA slot on the motherboard is used, and properly jumpered (e.g. a SATA 2 disk on a SATA 1 configured port is likely to malfunction).
Check that the BIOS is configured to autodetect the hard disk type, and is using the appropriate adapter (EIDE or SATA port), without RAID options or such.
In a pinch, try also ignoring the motherboard labels (e.g., plug the hard disk on the fourth SATA port instead of the first -- the mobo numbering is not always the "logical" one, even if it usually should be.
Jul 02, 2010 | Computers & Internet
Computers & Internet Logo
351 people viewed this question
David Payne
David Payne
