Question about Garden
Briggs & Stratton Intek 6hp mower engine (121682-0122-E1) runs at high rpm after pulling the head to fix a cross-threaded spark plug. Governor linkage and carb look fine, but obviously something is wrong. I did loosen the bolt connecting the governor linkage to the shaft going into the crankcase. Does the shaft need to be in a particular position when the linkage is tightened up again?
  • 5,603 Answers
Yes, in a word. You can riobably rotate the position and find the correct by trial and error. You might be able to feel the roughly correct position by throttling the engine down and feel the action of the shaft.
Posted on May 18, 2011
I have a Briggs & Stratton 10 HP engine, model 220707 that I could use some help with the governor spring on?.
Should see a bracket with holes in it .and a small throttle bracket that has a hook shape the spring locks on to it.
May 20, 2014 | Briggs & Stratton Briggs Stratton Intek V...
What is the high speed rpm setting for a intek 22hp vtwin?
Generally 3,600 rpm is the high speed setting for many of these type of engines.
Mar 03, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Back firing, load engine noise, engine skip
Could use more info but here are some things u can check--Plug wire grounding to block, old spark plug--check head bolts for correct torque--carb adjustment or jet plugged-governor linkage not hooked up or improper adjustment of governor--if these are good then it could be internal--bad valves and valve adjustment--timing gears
Jul 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
228 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
