The date on my daughters 5712 keeps going back to default as soon as the computer is switched off is there anything i can do to correct this. Have done sstem restore.
    Sergeant:
  • 212 Answers
It's very likely you need to change the CMOS battery. it will be inside the computer, connected to the motherboard. You will have to open up the casing to reveal it. You can take out the battery and find a replacement at usually any radio shack...they are pretty standard lithium battery. Similar to these: http://img.diytrade.com/cdimg/650073/5025574/1/1199521448/CR1625.jpg
just match the type and replace it in the same direction as the existing one is. It's a pretty easy swap, getting to it is the toughest part.
Good Luck.
Posted on May 18, 2011
    Guru:
  • 1,705 Answers
Yes, the CMOS battery has given up the ghost. They can last for years but can also go any time after about 3.
They're a fairly standard affair. A coin shaped battery about an inch in diameter.
Normally on a laptop, they're got at via lifting the keyboard. Best to consult your user manual
Now I'm not sure who makes a 5712 laptop, so if you've lost your user manual, you should be able to download one from your laptop manufacturers website, follow links for support and downloads.
To give you some idea of what needs to be done, its fairly easy, go you youtube, and search for CMOS battery replacement. There's loads of short movies showing you how to go about it.
  • 812 Answers
This happens because the battery on the motherboard has gone flat. So when the mains power is off the battery is not backing up the motherboard data which includes the date and time.
You had best take it to pc world as its an advent and they will fit it as it requires a strip down.
    Top Expert:
  • Computers & ... Master
  • 76,164 Answers
The CMOS button battery is defective, this battery backs up the date circuit so you don't loose the date when power is off. Open the case and replace the button battery which is located on the main circuit board of the PC.
Toshiba PSLC8U-03701Q factory restore
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to
hope this helps you
Mar 18, 2012 | Toshiba Satellite L305D Notebook
My mini acer won't let me open up anything, how do i reset it?
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart also click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Apr 14, 2011 | Computers & Internet
Date keeps resetting to 27.03.2011 I have tried unplugging,changing the date and going back to factory default and reinstalling but nothing seems to correct the problem therefore unable to use timer
Most DVR's don't have back up battery for holding setup data like your Computer. That means that you can never unplug or switch off the power supply completely. The clock runs off the mains supply so any interruption will make it revert back to factory settings.In other words you have to put it in standby mode when not in use to retain recording schedule / clock time etc.
Apr 10, 2011 | Daewoo Televison & Video
I did an update for my sylvania smartbook and now it wont do anything. i want to restore it back to its original settings.
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer
hope this helps
Mar 22, 2011 | Computers & Internet
It has a blue screen doesnot do anything
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
or
Hope this helps don't forget to vote
Feb 23, 2011 | Computers & Internet
My daughter used my wife's laptop and somehow acquired this extremely persistent malware that tries to get you to buy some antivirus proxp software for $60... I bought the PC on Amazon and I don't have a...
Alternate:
or
Feb 14, 2011 | Computers & Internet
Computer freezes when I sign onto my accont
To resolve this issue, shutdown the computer and Restart it, as soon as it restarts keep on tapping F8 key, now select, "Last Good Known Configuration" and hit "Enter" key. It should take care of the issue. If not, then boot the computer to "Safemode", to do so, restart the computer and as soon as it restarts keep on tapping F8 key, now select "Safemode" from the Advance boot menu. If it is booting to Safemode, then perform a system restore to previous date. If nothing happens, then you have to perfomr a full system restore.You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and Regards,
Anil.B.R
Aug 15, 2010 | Acer Audio Players & Recorders
My daughter has an Acer laptop running XP. The
Hi i'm Rain.
Follow the instructions below to resolve the issue.
  1. Click start.
  2. Click All Programs.
  3. Click Accessories.
  4. Click System Tools.
  5. Click System Restore.
Now Keep the default Settings { Restore my computer to an earlier state} and click next.
Now select a date that you know for sure is before the problem accured. Click next an allow the restore to correct the problem. The system will reboot after the restoration . Now a restoration complete notice will appear.
Click Next or Ok to continue to desktop. Your icons should all be back in place .
Nov 30, 2009 | Computers & Internet
Pc keep on going back to default setting when shut down
Sorry but I must ask if you are correctly saving your bios settings at the end. Please make sure you are hitting the correct keys to save and exit.
What BIOS do you have? Then I can tell you which keys to save your new setting.
Jul 20, 2009 | Computers & Internet
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Jan 21, 2009 | Polaroid i830 Digital Camera
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
