Question about Ibanez S5470 Prestige Electric Guitar
Had my guitar PLEK'd because we found out the frets were defective from the company, this was supposed to fix the problem of high action, still cant get the action low without it buzzing
The truss rod adjustment has a lot to do with how low you can get your action. Learning how to adjust your truse rod your self is important to keeping your guitar in good playing condition. It is not that hard, if you study. There is much info on the web, learn first - but do learn. I think all guitar players should be able to do a complete setup. Even if you decide to hire it out. Setups must be refreshed doing it once and thinking thats it, is not enough. I check mine after about 6 or less string changes.setups arn't permenentt. As you pointed out frets can also cause a lot of problems Being plek'd should have fixed your fret problems. It should be in the set up where your action is adjusted.
Posted on Feb 02, 2012
  • Ibanez Master
  • 5,603 Answers
Take it in for setup. Likely the truss rod or the bridge is out of adjustment. Wrong strings can also cause the problem. There are YouTube videos on guitar setup... I would NOT attempt truss rod adjustment yourself.
Posted on May 18, 2011
BC Rich Warlock Frets catch high E string
It sounds lie the frets aren't seated correctly. This will need to go to a professional repairman. It's too easy to mess your guitar up if it's done wrong.
Jan 23, 2014 | B.C. Rich Music
High action martin java mahogany 00x1
To lower the action on an acoustic guitar:
Usually just the saddle needs reducing.
1. Remove strings (or you may be able to just loosen them). Remove saddle, sand down the bottom a little at a time. Restring and check action.
The action can be set as low as poss without any fret buzzing or note choking on all strings and on all frets.
2. Repeat 1
If the action remains too high then there are other techniques.
Later ...
Jan 09, 2014 | Martin Guitars 00X1 Java Mahogany Guitar...
MY EPIPHONE ACOUSTIC BUZZES ON 11TH FRET AND SOUNDS SAME NOTE ON 12TH FRET
This means the 12th fret is a bit too high. If you are not familiar with adjusting frets take it to any local guitar shop for repair.
Nov 13, 2013 | Epiphone DR-100 Dreadnought Natural...
Hi, Just received the last WD10 SCE guitar from Washburn but string action beginning at the 12th fret is very high for me (near 3mm ending at 3,5 mm for 20th fret). Don't know how to adjust string...
You need to get a luthier to help out but basically, with the allen key, adjust the neck to give you a 2.5mm gap between the bottom E and the fret board on the 12th fret.
Dec 24, 2017 | Washburn WD10 Series WD10SCELH Acoustic...
When I bend a note on the high E string past 19th fret there is a high almost feedback like sound almost immediatly after bending and the note cuts out, what's going on?
Check the height of your action on that string. It is possibly vibrating against the frets higher up. Try setting it slightly higher.
Dec 16, 2010 | Ibanez RG350DX Guitar Artic White
High action even though neck is straight. I have also messed with the bridge saddles and not much has changed except it gives fret buzz when i lower the saddles just a little bit. Is high action a common...
Sounds like you need to get it intonated. Take it to your local guitar shop tell them your problem and where you'd like your strings to sit or that straight neck of yours won't be like that for long.
Good Luck, Cody J
Dec 14, 2010 | Ibanez ATK300 Electric Bass
Buzzing of strings in frets up to fifth fret; seems that the bridge may be low but it's not. Also, too there is more gain in high strings than the fifth and sixth
Sounds like a warped neck, if the bridge isn't low what else would cause the strings to buzz.? With the gain problem perhaps the neck is twisted as
well as bowed. Epiphone are proving to be quite popular but they are built to a price and for beginners they are usually a good choice. Unfortunately some fakes of different guitars are sold on ebay and they often make better tennis rackets than a musical instrument. Unless you changed them the guitar usually has a cheaper Humbucker pickup. Check it's fitting anf make sure there are no loose parts or wiring sitting against the soundboard on the inside.
Try looking down the neck of the guitar and seeif you notice any warp or bend. Overtightening the strings can cause the opposite warp and the strings end up further from the frets. Also try some measuring. The distance between the any string and the fretboard starting at the nut and working down to the bottom of the fretboard. These measurements should be consistant
Also, check the nut to see if the grooves aren't too deep. This could cause buzzing by allowing less distance between the string and the first fret.
Make sure all the frets are seated correctly and not slightly out of kilter at one end.
That should give you enough to keep you busy for a while. There are plenty of reasoins why a string will buzz. I've covered a few mecanical ones but without sounding rude there are also player caused buzz. Depressing the string too far behind the fret can cause it whereas too close to the fret can kill the note. But that's not my field in this situation. Check all the above and then try your fingering. One way or the other that buzz will stop. The best way to check if it's you is to get someone else to try your guitar out and see if the buzz buzzes off :-)
good luck
Apr 07, 2010 | Epiphone Les Paul 100 Electric Guitar
Truss rods and dead frets- how do I adjust the guitar so the strings are close to the neck without getting dead frets?
I own an Epiphone Casino and if I needed to adjust the truss rod I would take it to a luthier (stinged instrument repair person). There is a good write up on it here. http://www.fretnotguitarrepair.com/trussrods.htm
Hope this helps.
Bob
Oct 31, 2009 | Epiphone Les Paul 100 Electric Guitar
String buzzing
Dont give up on the neck. One tec you saw may not know what another that has had many years in the repair of gtrs knows !. But for the time being you can fix this your self. Find a alan wrench that came with your Gtr.thats your ntail pice. This is the bridge that each string cross,s over. Now slowly rase up the height of the string untill its high enough to stop the buzzing. Just half turns at a time. . All so if you keep the humitdy up near your gtr. it may correct its self, no **** just like magic. keep on playing DFD
Apr 10, 2009 | Yamaha Electric Guitar
Ibanez S5470 Prestige Electric Guitar Logo
165 people viewed this question
Top Ibanez Music Experts
Michial Gueffroy
obsteiner
Eric
Are you an Ibanez Music Expert? Answer questions, earn points and help others
