I am using some old and new hard drives through a USB Kingwin Dockmaster. The drive is Western Digital WD800JD. This particular drive was purchased by me and never installed. I formatted the disc and it is now not seen by device manager or WD diagnostics. I can hear it spin so I assume it is properly connected but need it seen by the computer before I can install the driver. This has happened to other used drives that were recognized before formatting but not after. The Dockmaster brige device is still seen. What am I doing wrong?
  • djm5657 May 19, 2011
    Well detailed. Thanks!
  • 6,993 Answers
Is this your first time of using this external drive with your computer?
Connect the external drive to another computer and observe if it's going to work perfectly on that computer.
Which ever the case ma be, here is what you need to do on your computer;
Insert the external drive into your computer
Go to device manager.
Go to the name of the external drive.
Right click on the external drive and click 'Uninstall"
Allow the external drive uninstall from your computer.
If possible uninstall every other device under the "Universal serial bus controller (usb).
Once this is done, disconnect/remove the external drive from your computer.
Restart your computer.
Wait a while for the computer to boot computer. Also whatever you have uninstalled from the device manager, might install automatically. Which ever the case maybe, make sure your computer has finished booting or installing any device before you attempt to insert the external drive into the usb.
Now insert the external drive and wait for the computer to install the external drive, then observe if it will open this time around.
By now it should open. But if it doesn't open, please let me know so that I may direct you further on what next to do.
I wish you good luck.
Regards.
Posted on May 18, 2011
Wdc wd800jd-75msa3 not reading disks
A Western Digital WD800JD-75MSA3 is a 80GB hard drive.
The usual cause of read failures of a DVD ROM is dirt in the device.
Try a cleaner disk.
Jan 21, 2014 | Western Digital WD800JD-75MSA3
Installing used WD800JD into external disk enclosure
The case must be designed for SATA drives. Once the drive is installed in the case, use a USB cable to connect it to the computer. Connect the power supply to the case and start the computer. There will be a new drive letter present.
Nov 25, 2012 | Western Digital Caviar SE WD800JD SATA...
I have a WD800JD hard drive which was on my old computer in which I want to recover data to my new computer. I have installed it in the computer with the one ribbon (only one available). The master has...
Hello Joe,
Please visit the link provided below :
http://wdc.custhelp.com/app/answers/detail/a_id/981/p/288,95/c/123/session/L3RpbWUvMTMxMzU4ODkxOS9zaWQvN1JOSzdNQms%3D
Aug 17, 2011 | Western Digital Caviar SE WD800JD SATA...
It dousnt show in windows at all
test all leads from "motherboard to hard drive" include electrical extensions if its an ide with flat ribbon 40 pin type make sure its securely seated at both ends this will be the first to fail
hope this helps
Jul 08, 2011 | Western Digital WD800JD (wdc-wd800jd) 80...
I am trying to use a WDC WD80 0JD-00MSA1 scsi hard drive through a DOCKMASTER Kingwin USB connection and device driver sees it and a BELARC Advisor scan sees it but not My Computer. The drive is unused...
You mentioned that you have never formatted this hard drive. Has this been FDisk and Partitioned? If the hard drive has never been Fdisk / Partitioned / Formatted, this will not be recognized in the windows environment.
You can use DISKPART in command line to manage and partition your hard drive. After formating it in your preferred format (NTFS is recommended). Your hard drive should display properly in windows explorer.
Hope this helps.
Apr 30, 2011 | Computers & Internet
I am going to purchase 1Tb HDD, I don't know how it is. If am getting any problem how can i replace, bcz i planned to purchase in ebay .com shopping. Kindly suggest me. Thanks & Regards Mahesh. H N
If you are going to make an online purchase, you should purchase directly from Western Digital's E-commerce web-site. This will assure that you will have a "warranty" that has good value.
Note that Western Digital has a "Customer Loyalty" program -- if you are the owner of any Western Digital disk-drive, you should qualify for a discount on your online purchase of a new disk-drive, if purchased through their web-site.
Dec 16, 2010 | Western Digital Caviar SE WD800JD SATA...
I bought a Dell Optiplex 745 with no hard drive. I bought a second hand WD800JD SATA hard drive with no CD's and installed it. The computer does not recognize it so I cannot load an OS. Can you help?
make sure that the leads are in there correct slots
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 04, 2010 | Western Digital Caviar SE WD800JD SATA...
Western Digital Caviar SE WD800JD SATA Hard Drive Boot: Couldn't find NTLDR could this be bad drive installed xp a couple times now works ok but when i shut it off Couldn't find NTLDR comes up
Yes it looks like a Hard drive problem.
This error means that NTLDR is missing somehow from your computer,hard disk problem usually or virus.
You can go to that page and follow the instructions exactly as he says and will not have to install windows over and over again
http://www.tinyempire.com/notes/ntldrismissing.htm
Jan 02, 2010 | Western Digital Caviar SE WD800JD SATA...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
