Question about Welding Tools
I HAVE A LINCOLN WELD PAC 100.ALL SYSTEMS SEEM TO BE FUNCTIONING BUT WHEN THE ELECTRODE IS GROUNDED IT JUST SPARKS .NO WELD NO AMPS.I HAVE HEARD REFERENCE TO A DIODE ON THE ALUMINUM PLATE.I AM WELL VERSED IN SEARCH AND DESTROY REPAIR BUT EVERY THING APPEARS OK ON INITIAL INSPECTION
    Sergeant:
  • 281 Answers
I checked the Miller web sight and it shows an easy way to check out the trigger.
http://www.millerwelds.com/resources/communities/mboard/showthread.php?20348-Weld-Pak-100-Problem
Hope this helps.Thank You for choosing FixYa.com & Good luck.
Posted on May 18, 2011
My Lincoln 120 mig wont weld just sparks it feeds the wire n gas but wont weld wat can be wrong wot my weldi g mechien
look for a bad ground wire connection ---in the plug , clamp, position of the ground clamp surface,cleanliness( paint, rust etc) place the ground clamp as close as practicable to the welding point
Apr 03, 2016 | Lincoln Welding Tools
Welder is not sending strong arc
maybe its your volts too. make sure you are grounded properly and clean from debri's, strike the electrode like a match and keep the arc close to your work-piece. dont go too fast and make sure your not wearing to strong of a lens in your hood. gold lens number 10 are the best for 7018 rods.
Jan 27, 2013 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Weld-pak 100 Hd Problem
There is a reset button located in the wire feed spool compartment,
check to see it stays in when pushed. It is a safety when the machine
overheats, it normally resets when machine cools off. If it is working properly I suggest contacting Lincoln Electric Dealer for service.
Mar 03, 2012 | Lincoln Welding Tools
ARC 100, 115v, 60HZ, 20A. When I run a beed, the
With these smaller machines you have a common problem. The way to get the weld to hold is on thicker material you have to sometimes pre-heat the metal in order to get it to stick. Also if ther is no flux nor gas the material has to be clean, free of dirt, oil, and rust. These machines are for very light use only. For welding material over 8 th inch, I suggest investing in a welder with at least 100 amps
Jul 25, 2011 | Lincoln Welding Tools
I have a lincoln weld pack 100 hd, and i want to weld aluminum but i dont know how to start. i buy a 4043 fil d aluminium mig and i dont know if my welder it ill be fine to weld,
you can weld aluminum with the lincoln but you will need to change the liner in the wand to a nylon one and swich the gas to 100% argon and of course change the wire to an aluminum roll. and practice-practice-practice it is much more difficult to weld aluminum then steel and requires much more control.
Feb 03, 2011 | Lincoln Welding Tools
WHAT IS RESISTANCE WELDING?
Electric resistance welding (ERW) refers to a group of welding processes such as spot and seam welding that produce coalescence of faying surfaces where heat to form the weld is generated by the electical reistance of material vs the time and the force used to hold the materials together during welding. Some factors influencing heat or welding temperatures are the proportions of the workpieces, the coating or the lack of coating, the electrode materials, electrode geometry, electrode pressing force, weld current and weld time. Small pools of molten metal are formed at the point of most electrical resistance (the connecting surfaces) as a high current (100-100,000 A) is passed through the metal. In general, resistance welding methods are efficient and cause little pollution, but their applications are limited to relatively thin materials and the equipment cost can be high. although in production situations the cost per weld may be as low as $.04 usd per weld depending on application and manufacturing rate.
Feb 02, 2011 | Computers & Internet
Some proplems face in welding aluminum
Are you asking about what the problems would be? First for mig welder, you can't push small aluminum wire through a very long cable. You need a teflon liner for it to work at all. A spool gun works better. Be sure to use correct gas for aluminum. Usually 100%argon, but some people use Argon/helium or helium. Use direct current reverse polarity (electrode positive) from constant voltage (CV) power supplies. If shallow penetration is required (i.e. for weld surfacing and cladding) straight polarity (electrode negative) can be used
Sep 27, 2010 | Lincoln Electric Welding Tools
Not forming a continuous bead on the inside of a 3'' carbon steel. set amps at 85/ 90 argon at 10, what am i doing wrong. please help me
I need more info, you are Way too vague.
What type of weld are you trying to do? A Fill weld?
Are you trying to fill a V in-between two pieces of hard steel, (Carbon), that is 3 inches thick?
1. If you are, the electrode should be held at a 90 degree angle to the metal. Straight up, and down.
Moving the electrode too fast will cause a intermittent bead. Slow down. TIG welding takes time. It isn't like ARC welding.
If the electrode burns off to one side, you don't have the electrode in the correct position.
2.Too little heat, (Amperage) will make a 'Cold' weld, and you won't have the penetration that you need. Too much gas (Argon) will do this also. Too little gas, and you'll burn through.
Nov 08, 2009 | Welding Tools
Lincoln mig pac-100 low heat on highest setting.won't weld 20 ga.
if you are using flux core that might be why, flux core burns hotter, try using 75/25 or more argon than co2, as your gas, the gas will keep it a little cooler, keep your amps down and match the wire speed to the amps, which would be slower wire speed
Apr 15, 2009 | Lincoln Welding Tools
I lost the owners manual to my lincoln weld pac#100 welder
hi mack:if you call or emal lincon customer care department theyll be happy to send you a owners manual to give you your gas shield capablitys ,thats what there there for.the customer. hope this helps jojogunne
Mar 10, 2009 | Lincoln Welding Tools
Welding Tools Logo
276 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
