Question about Microsoft Xbox 360 Controller
I have a brand new controller which came with my new xbox 360 and i have put the batteries in the correct way as instructed but when i press the xbox guide button nothing happens. I have also tried to sync the controller to console and that doesnt work either
  • 64 Answers
The guide button won't work until its synced,you need to push the button on the console to look for controllers then the button on the controller and it will sync it and then it should work fine. If that doesn't work then try hitting the button on the controller first then the one on the console.
Posted on May 18, 2011
Ho w to fix x box from controller to x box is really slow how to make it normal
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
My 360 control won't turn on I ve switched battery pack and still won't turn on with brand new batteries
Are you batteries correctly inserted into the battery pack and fully charged?
Have you tried pressing the smaller "connect" button on the controller as well as the "connect" button on the console?
May 04, 2011 | Microsoft Video Game Consoles & Games
MY CONTROLLER WONT CNNCT TO MY XBOX EVEN WEN I SYNC IT . ITS BRAND NEW.
You might have to replace the batteries in the controller, as if the battery life is low the controller will have issues syncing to the xbox 360. Just in cause, To sync the controller to the xbox 360, you must turn on the controller using the xbox guide button and then press the Wireless Sync button right next to the Controller Charging Port. Then you must press the sync button on the xbox 360. You must do this semi-quickly, or the sync process will not complete.
Lastly, You also might have a faulty controller, I suggest you go back to the store you got it from and see if they will replace the faulty controller.
Jan 20, 2011 | Microsoft Xbox 360 Controller
I can't get my wireless controller to sync to the console. I just put brand new batteries in it. The green light just blinks. I can't even power the controller off. I have to remove the battery pack to...
hi, have you tried pressing the sink button on the xbox as well.
when you turn the xbox on wait for it to come on all the way then press the little round white button on the xbox this is down and to the left of the start button then press the sync button on the control this should then pair them up and get it working for you
Dec 04, 2010 | Microsoft Xbox 360 Wireless Controller
Xbox 360 controlle not working
Have you tried pressing the sync switches on both devices, its the little white button on the top of the controller and the one on the 360 is near the memory card b slot (round white one) press the one on the controller and the lights shoudl start flashing then press the one on the 360 while the lights are still flashing they should then flash on one light about 3 times to indicate success. if this doesnt work you may have a faulty RF(radio frequency) unit, this is the wireless device which communicates with the controllers, if this is the case you can get this replaced at your local pc shop for around £20 to £30.
Hope this helps
Paul
Apr 02, 2010 | Microsoft Xbox 360 Controller
Xbox 360 guitar wont work
That is a syncing Issue, Try this, it may take a few tries. Press the Sync button on the Xbox 360. Then press and Hold the sync button on you Guitar for 1 Second. The Xbox and Guitar Should Sync.
Jan 31, 2010 | Microsoft Guitar Hero: Aerosmith with...
My Xbox 360 wont sync any of my wireless controllers and the powe
if your wireless controllers wont sync to your xbox, it could be one of 2 things.
assuming your batteries are fully charged, and that you're using a certified xbox controller, it could be that the controller itself. it is really rare that the wireless receiver inside the xbox itself, goes out, but soemtimes, it happens.
the easiest thing or you to do would be to either pick up an after market controller, or another certified controller, and see if they'll work. if you try other controllers, and they STILL dont work, verify that your system settings are correct, or are set to default, and make sure that your xbox isnt sitting close to something that could be interfering with the signal....like a wireless router for example
if this doesnt work, then it's a problem with the xbox, and you should send it back to the service repair center.
Sep 24, 2009 | Microsoft Xbox 360 Wireless Controller
Xbox 360 wireless controller wont work
Did you try syncing it into the 360? If you did and it didn't work get a new controller.
Dec 27, 2008 | Microsoft MS Xbox 360 Common Controller...
Microsoft Xbox 360 Controller Logo
802 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
