Question about Xerox C2424 Copier
Flashing message "service needed" code
    President:
  • 2,072 Answers
That is a jet stack heat error.
Most likely problems
Bad Ink Loader
Bad Print Head
Bad Pre heater.
The Left Jetstack is drawing less power than expected. My guess would be a bad printhead.
Posted on May 21, 2011
  • RHanson Sep 06, 2012
    where would you begin with a tester? we have one on our bench, giving the 37.002 error code & printer had bad ink spill.
What does service code message "gear selector -
Typically this means the gear selector module is faulty.
Sep 16, 2011 | 2001 Volvo S80
How do i get rid/ reset message xc90 "transmission service urgent" i have already taken to volvo dealer about six months ago. they could not pin point issue on diagnostic. Cheers
You first have to retrieve fault codes from your computer network then you have to diagnose the systems/circuits indicated by the fault codes to determine what the cause of the failure is, then you must repair the system/circuit at fault and then reset the computer system. If the dealer cannot do this, I don't know who can. Did they tell you what fault codes they were getting? If so, we can look up the troubleshooting charts for those codes as well as do a Technical Service Bulletin (TSB) search to see if this is a known problem with a known fix. Without the codes, your guess is as good as mine.
Sep 11, 2011 | 2004 Volvo XC90
I have a 61 inch samsung TV. A message flashed across the screen saying "check fan # 1 " then a few minutes later it shut down.
Hello
Not much to do by web, this message mean you most likely need a new fan, tv shuts down due to overheating. Contact service.
Aug 21, 2011 | Samsung Televison & Video
I get this message "Sorry, we
I think is about flash player 10 you need to install from the internet
http://www.adobe.com/downloads/
May 11, 2011 | Computers & Internet
I was recieving a phone call and went to unlock my phone from the passcode which i left as 12345. And it said "Code Error" i keep trying to unlock it. But it wont work?
Please try enter *#7328748263373738# from your standby screen and your phone lock will change to default 12345. Or contact the service center to looking your lock code from flash tool
Feb 23, 2011 | Nokia X3 Cell Phone
The orange "Alarm" light keeps
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. According to the service manual you will need to replace the sheet feed unit, logic board assy, purge unit.
Feb 22, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Why do i get a "ld' signal or a "co" message?
LD = Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display
I don't see an CO error. Here is a complete service manual for your washer. I am sure it will come in handy in the future. Look on page 46 for a list of the error codes.
Regards, Rich
Feb 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
How do i clear the "service engine soon"
Disconnect the battery for a minuit and turn on the light's to power down any electrical power. Reconnect the battery and that should clear the "servie engine light soon",but if there are any DTC codes, the "Service engine light" will come back on.
On board diagnostic (OBD) was designed on vehicles equipped with electronic fuel injection so you can generally retrieve the codes yourself. No need buying a scanner or running to any parts stores to check the Engine Light. This system is called obd1 and applies to most vehicles made before 1995 for domestics and 1993 on imports.
For GM domestic vehicles made before 1995, the diagnostic connector is located under the dash panel by the driver side. To get the check engine codes to flash in your dash panel, use a jumper wire or a paper clip and connect terminals A and B of the diagnostic connector. Turn your ignition key on with engine off and the codes should start to blink. All codes should start with code 12 which is one long flash followed by 2 short flashes. This code 12 means the diagnostic system is normal and will repeat itself continuously if there are no trouble codes. Otherwise, code 12 will flash 3 times before flashing the fault codes.
the codes can be erased or cleared by disconnecting the battery negative terminal for 1 minute and reconnect. Just make sure to check your service manual in case you have electronic equipment such as radio or clock that needs reprogramming in which battery disconnection is not recommended. Finally after performing repairs on the culprit code, always go for a road test to confirm if the problem is fixed.
Good luck and hope this help, here is a link to the DTC codes. http://www.gmtuners.com/OBD1_DTC.htm
May 08, 2009 | 1989 GMC Sierra
Xerox C2424 Copier Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
