Question about Gateway GT5656 Desktop PC
I forgot my login passwords i removed the jp3 from pins 1&2 to 2&3 and in the bios i changed the passwords but when i restart the computer it still asking for the old passwords and i dont know how to disable it
  • 134 Answers
Login pasword and bios password are totally diferents....for login password use hirens boot cd..
Posted on May 19, 2011
I can't reset my bios password
BIOS password can be removed using either of these two ways:
1) Take you BIOS cell out for a while and then plug it in again and your BIOS password shall be removed.
2) You can also change your BIOS Jumper Setting. Generally the BIOS jumper resides on pin 1 and 2. You simple take it out and then plant it in on pin 2 and 3. Power on your computer and then power it off. Then change the jumper to default setting that is pin 1 & 2 and then once you shall power on your laptop the BIOS password shall be removed.
The BIOS jumper resides on the motherboard and there is a marking on it stating "BIOS" which shall help you identify the correct jumper.
Oct 30, 2012 | HP Compaq Business Notebook 2230s
Tip
TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS WHENEVER YOU FORGOT THE PASSWORD
BIOS PASSWORD ARE USED TO SECURE YOUR COMPUTER BY PREVENTING OTHER USERS TO ACCESS YOUR COMPUTER'S BIOS SETTING OR MAKING IT UNBOOTABLE REQUIRING PASSWORD.
But in some cases, some people forgot the password.
HERE ARE THE TRICKS AND TIPS ON HOW TO ACCESS THE BIOS/CMOS SETTING WHENEVER YOU FORGOT THE PASSWORD.
SOLUTION1. RESET THE BIOS PASSWORD USING DOS COMMAND PROMPT.
1. Go to start menu and choose RUN. For other operating system like Windows 7 and Vista, just use the search bar and type the command prompt. Right click mouse and run as administrator.
2. type the word "debug" and press enter
3. type the code "-o 70 2e" and press enter
4. type the code "-o 71 ff" and press enter
5. type the letter "q" and press enter
6. type the word "exit" and press enter
7. try to restart your computer and it will remove the bios password.
SOLUTION 2. TRICK THE COMPUTER TO GENERATE BIOS PASSWORD.
Some computer can generate bios password when you enter 3 different incorrect bios password. Below message will appear:
Password check failed
Fatal error...System halted.
CNU9117K31
Use the last line as password. CNU9117K31
SOLUTION 3. USE BACKDOOR PASSWORDS
AWARD BIOS
AWARD SW, AWARD_SW, Award SW, AWARD PW, _award, awkward, J64, j256, j262, j332, j322, 01322222, 589589, 589721, 595595, 598598, HLT, SER, SKY_FOX, aLLy, aLLY, Condo, CONCAT, TTPTHA, aPAf, HLT, KDD, ZBAAACA, ZAAADA, ZJAAADC, djonet
AMI BIOS
AMI, A.M.I., AMI SW, AMI_SW, BIOS, PASSWORD, HEWITT RAND, Oder
OTHER PASSWORDS:
VOBIS & IBM - merlin
Dell - Dell
Biostar - Biostar
Compaq - Compaq
Enox - xo11ne
Epox - central
Freetech - Posterie
IWill - iwill
Jetway - spooml
Packard Bell - bell9
QDI - QDI
Siemens - SKY_FOX
TMC - BIGO
Toshiba - Toshiba
In TOSHIBA BIOS, just hold left shift key during booting process.
For IBM APTIVA BIOS, press both mouse repeatedly during the boot.
SOLUTION 4. CLEARING THE CMOS JUMPER OR DIPSWITCH SETTING.
Go to your motherboard and look for jumper should be located near bios chips or near the battery. THere is usullay 3 pin switch two of them covered with this jumper.
Procedures :
1. Turn off your computer.
2. Unplug the power cable from the power supply unit.
3. Wait for 30 mins to be safe that your motherboard is fully discharged.
4. Locate the jumper.
5. If there is 3 pin switches, the jumper shows would be in 1-2 position. Just place it in 2-3 position with a few seconds and then return it back to normal position 1-2 position.
6. If there is only 2 pin switch, just remove the jumper with a few seconds and then place it back to normal.
7. Connect all the connection and restart your computer. It it will reset the bios setting.
SOLUTION 5. REMOVING THE CMOS BATTERY
If the jumper switch solution doesn't work, try this solution by removing the cmos battery.
Procedures:
2. Remove power source cable.
3. Go to your motherboard and remove cmos battery.
4. Wait for 30 mins or more before returning it back.
5. Place the battery back correctly
6. Plug your power cable and start your computer and it is done.
GOOD LUCK AND I HOPE THIS WILL BE HELPFUL FOR OTHERS.
on Dec 19, 2010 | Computers & Internet
Tip
Forgot Windows Vista Password - How to Reset or Recover It?
No matter you use a Mac or PC, no matter your operating system is Windows 7, Windows Vista or Windows XP, computer security can be a common topic for you. For PC protection, a Windows password is often regarded as the first line of safeguard. But there is a little problem as Windows password can be easily forgotten. Forgetting Windows password could also be dangerous if your only have one windows account or others.<br /><br />In that case, you can use a password reset disk to reset or recover the forgotten Windows password. Here we introduce a simple tutorial for you when <a href="http://www.windowsloginrecovery.com/forgot-windows-vista-password.html">forgot Windows Vista password</a> - Burn a password reset CD/DVD with Windows Login Recovery. This method can be applied to all situations, no matter you can log on PC or locked out of computer.<br /><br />Windows Login Recovery enables you to create a password reset CD/DVD. When you forgot Windows Vista password, you can use the created CD/DVD to reset the forgotten password in just 3 simple steps:<br /><br /><span style="font-weight: bold;">Step 1: Burn a password reset CD/DVD.</span><br /><br />1. Run the program and insert a blank CD/DVD to computer.<br /><br />2. Select to Reset Local account password, and click Next.<br /><br />3. Select CD/DVD and click Burn to start burning the CD/DVD.<br /><br />4. Click OK when the CD/DVD is burned and take it out of computer.<br /><br /><span style="font-weight: bold;">Step 2: Set your locked computer to boot from CD/DVD.</span><br /><br />1. Insert the burned CD/DVD in the locked computer that you forgot Windows Vista password.<br /><br />2. Press F2, Delete or F10 to enter your BIOS Setup when the computer is booting.<br /><br />3. Choose Boot on the taskbar, select Boot Device Priority and press Enter.<br /><br />4. Make the computer to boot from CD ROM firstly according to the prompts on the right.<br /><br />5. Press F10 to save settings and your computer will restart automatically.<br /><br /><span style="font-weight: bold;">Step 3: Reset forgotten Windows Vista password.</span><br /><br />After restarting, you can reset Windows administrator password and standard user password under DOS.<br /><br />1. Choose the installation path of Windows, and enter the NO. of the path.<br /><br />2. All Windows account user names will be displayed for you. Enter the NO. of a specified User Name to remove its account password.<br /><br />3. Enter y to confirm and continue your operation.<br /><br />4. Enter y to remove another Windows account password or enter n to finish your operation when the selected windows account password is removed.<br /><br />5. Take the burned CD/DVD out of computer and press any key to restart your computer when you enter n to finish your operation.<br /><br />The password has been successfully reset and now you can log on your computer without password.<br /><br /><span style="font-weight: bold;">Notices for Windows Vista password reset</span><br /><br />1. When you forgot Windows Vista password and locked out of PC, with Windows Login Recovery, you can create a password reset CD/DVD in any accessible computer with any OS, like Windows 7/Vista/XP and Windows Server 2008/2003/2000.<br /><br />2. The computer used to install the program should have a CD/DVD burner; both internal and external CD/DVD burners are OK.<br /><br />3. After <a href="http://www.windowsloginrecovery.com/windows-vista-password-recovery.html">Windows Vista password reset</a>, no computer data will be lost.<br /><br />4. This method can not only help you when you forgot Windows Vista password, but also help you regain access to computer when you forgot Windows passwords on Windows 7, Windows XP and so on.
on Nov 11, 2010 | Computers & Internet
BIOS PASSWORD RESET
Hi
You need to open up your computer to access inside.
By this process,please be warned of potential ESD [Electro Static Discharge].
On the computer motherboard locate the BIOS clear/Password jumper or Dipswitch and change its position.Its mostly located on the edges of the motherboard,by the CMOS battery or even by the processor.
Its usually labelled,CLEAR,CLEAR CMOS,JCMOS1,CLR,CLRPWD,PASSWD,PASSWORD,PSWD or PWD.
Its currently fixed on two pins i.e.pin 1 & 2 a third pin is not covered.
Now remove it and fix it on pins 2 & 3 leaving pin 1 uncovered.
Turn on the computer let it load and the password is cleared.
Turn it off.Re-fix the Jumper to its original position i.e.on pin 1 & 2.
Turn your machine on now.
Solved?
Remove the CMOS battery [a round 3v Lithium battery on the motherboard] for like 15 minutes.This makes the system to loose all CMOS settings including the password.
Hope this helps.Thanks!
Ken.
Mar 05, 2012 | Dell Computers & Internet
Can not sign in
if you mean that you cant login to your computer because you forgot your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change fist boot back to your hard drive) Hope this helps
Apr 02, 2011 | Computers & Internet
I forgot my funjitsu labtop BIOS password how can i remove.
OPEN IT REMOVE THE BATTERY ON THE MOTHERBOARD THEN REPLUG THE BATTERY.
YOU ARE DONE.
Feb 05, 2011 | Computers & Internet
My kids changed my password and now i have no idea how to get in it now
You may crack the password and login your computer again.
Windows Password Recovery is right what you need in your case. The password recovery tool is designed to reset Windows login password once you accidentally forgot it or have no access to your system including Windows 7, Vista, XP etc. By burning a bootable CD, you can enter almost any computer with Windows administrator login password protected within a few seconds. Here are the step by step tutorial, pretty easy, I am sure you can handle it!
Step 1: Download Windows Password Recovery and install it on another computer.
Step 2: Prepare a blank CD/USB and run the software and use it to burn the ISO file to it.
Step 3: Put it into the CD-ROm and restart your locked computer. Change the BIOS setting of your locked computer to make it boot from the CD-ROM or USB drive. Note: start computer and press F2 or Delete to enter BISO setup
Step 4: Boot your locked computer from the created disk and remove your forgotten password. GOOD LUCK!
Jan 14, 2011 | Toshiba Satellite A135-S4527 Notebook
How can i reset my bios password for an acer aspire laptop?
IF YOU KNOW THE BIOS PASSWORD YOU CAN GO TO BIOS AND CLICK ON CHANGE PASSWORD AND IF YOU FORGOT THE BIOS PASSWORD YOU NEED TO OPEN THE SYS. AND ON MOTHERBOARD THEIR IS A SMALL JUMPER THAT SAYS BIOS JUMPER ON IT YOU NEED TO REMOVE IT AND PUT IT IN PRONK 2 &3 AND RESTART THE SYS. AND THEN AGIN TURN OFF THE SYS. AND PUT THE JUMPER BACK TO PRONK 1 & 2 AS IT WAS EARLIER. AND IT WILL REMOVE THE BIOS PASSWORD.
Oct 25, 2009 | Acer TravelMate 2300 Notebook
I forgot my Password to the Login of my Laptop
Have your HP laptop login password forgotten? Do you have another administrator? Have you created Windows password reset disk on your HP computer when it is available? Or whether you have installation CD?
If you have administrator, just change HP login account to this administrator and access HP computer with it. At this time, no matter which account, you can easily change or remove its password on Control Panel.
If you have password reset disk, on Windows login screen after you type incorrect password, there will be a message "Reset Password" prompting you to reset forgotten Windows password with reset disk. Just follow password reset wizard to do.
If you have installation CD, it will help you to restore HP computer or repair computer. But it is still dangerous for us to use it because it will delete some important data on your computer.
In consideration of data safe on computer, Windows Password Genius provides a safe Windows password reset environment WinPE. With it and in such password recovery environment, you will don't need to worry about data lost or damaged.
This is a video showing how to use it.
http://www.youtube.com/watch?v=quxuEqpG6f4&feature=youtu.be
Jul 11, 2008 | Computers & Internet
Foxconn F845DA jumper settings
JP1 PIN 1-2 = On board audio disable
JP1 PIN 2-3 = On board audio enable
JP2 = Temperature Sense connector
JP3 PIN 1-2 = Normal
JP3 PIN 2-3 = Clear CMOS
1. Power off the system and unplug the chassis AC power cord.
2. Short JP3 at PIN 2-3 for a few seconds.
3. Set JP3 back to it's normal position at pin 1-2.
4. Plug the AC power cord to the chassis.
5. Power on the system and load the BIOS setup default.
Mar 25, 2008 | Computers & Internet
Gateway GT5656 Desktop PC Logo
144 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
