Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Kodak AiO home center software
This is my 3rd Kodak ESP-3.  Last one would not print, but scanner worked just fine.  Now I can print and I can't get scanner to work correctly.  Called Kodak and they were no help.  Said my issue was my home center software -- for whatever reason I guess I don't have it or it doesn't function correctly on the MacBook OSX 10.5.4 --  hmmm scanner scans lower 2/3 of a 4.5 x 3.5 snapshot no matter what I do.
Help!
  • thescenic Sep 22, 2008
    Scanner works but printer will not connect asked to print Mac OS 10.5.5.  Just put in new ink cartridges for the first time.  Feels like I bought produce instead of a printer.
Inatale mi nueva impresora kodak esp 5 pero no la puedo comparitir con otras impresoras y no se usar el escaner no tienen un manual o instructivo que me pueda servir ayudenme please
Posted on Sep 13, 2009
    New Friend:
Cant get into kodak home centre
Posted on Sep 08, 2010
I persisted in finding a solution with the help of Kodak but the solution was that the scanner was flawed and the printer is being replaced - AGAIN.  The first tech I talked with was clueless and absolutely no help.  The second person went through some steps with me and determined, once again, there is a flaw in the printer -- the 3rd replacement.  The first printer had a print-head problem out of the box, so it was returned to the store & exchanged for another.  The replacement worked for some 3 months without a hitch and then stopped working - just would not print, but the scanner worked.  So I just rec'd my Kodak ESP-3 number 3 on Tuesday this week.  Printer worked, scanner didn't.  Now I am waiting for my 4th replacement.  It is ridiculous, but when it does work, it is a nice little printer -- quality of photo printing is great, and you can't beat the cost of the ink refills. And so it goes.
Posted on Aug 15, 2008
SOURCE:
Am I correct in thinking Kodak ESP 3 AIO is not compatible with Windows 7 XP x64? I can print and copy but cannot scan either directly from the button on the printer button or via Kodak Home Center
Hi There,
If you've installed the software at the link below already...
http://support.en.kodak.com/app/answers/list/p/5/session/L3RpbWUvMTMwMTM1NjI3NC9zaWQveldEWnY1cWs%3D%2Fselected%2Ftrue/selected/true#s=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..
then the answer would be yes. If you haven't install the software and see how things go.
Regards,
Selk
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My scanner icon for my ESP 3 has disappeared. My
Kindly download trhe latest Kodak all in one home center software from www.kodak.com/go/aiodownloads .the scanning and printing drivers are embedded in the software itself.
Jan 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Our kodak esp-3 is printing a blank page with new ink cartridges.
go to www.kodak.com/go/printheadsupport.click on 3rd link on how to replace a printhead. then take cartridges out and printhead out, after 1 minute,insert printhead back into the carriage and install both cartridges, go to kodak aio home center on ur desktop and from there on maintenance under help and select printhead cleaning. then try to print.ur problem will be resolved
Jul 17, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp-3 unable to scan from home center,but able to print
If you are getting a 1-2036 error then there maybe an conflict between the Kodak TWAIN driver and another TWAIN device, most of the time it is with a flat bed scanner. If you have another All in One printer or scanner connected unplug it and uninstall its drivers. If the issue continues uninstall the Kodak software and unhook the kodak printer. Then download the kodak clear utility from HERE
After the utility runs and you restart your computer Re-install the Kodak Printer software and select WEB install to get the latest version.
Hopefully that will solve your Home Center scanning issue.
Jul 13, 2009 | Office Equipment & Supplies
Need to clean the heads but can't find instructions to do it.
To clean the printhead press: COPY and CANCEL at the same time.
To print a test page press: QUALTITY and CANCEL at the same time.
Go to Kodak AIO home center, click on the"?" and open the "user guide" for the complete manual. Wish they put in a printed version, put they don't. Good luck with the printer, mind has been nothing but problems. And keep trick of what you print. You will be shocked at the low output. Report it to Kodak and they might sent you new inks.
Bob D.
May 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak AiO home Center will not open
My son has the same model and issue. I had him go to http://www.kodak.com/global/en/service/downloads/dln_ekn034524.jhtml?pq-path=12667 and get the latest software and firmware update.
Make sure to use the dropdown to select your operating system. The page defaults to XP.
The software is a new version of the AIO home center.
The firmware installer updates the physical printer. Before you run this program be sure to read and understand the instructions.
If both ink cartridges have good levels of ink, and you keep getting the clean the print head issue after updating both the software and the firmware, then call Kodak support. 1-800-421-6699, 7 A.M. to midnight Eastern time, 7 days a week. They will ask you if you put in new cartridges and installed the updates for the firmware and the AiO centre software. Be patient. They will get a solution for you.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
1,567 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
