Question about John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter
I have a John Deere GX75 mower that is not starting. Because there is no indication of electrical current at all, i am assuming it is a safety switch. The previous owner said that when they had issues starting it they had to wiggle the shift lever in the neutral position and then it would start. This leads me to believe it is the neutral safety switch. Anyone know where it is located on this mower or how i can bypass this safety so i cna determin if it is the problem or not.
SOURCE: in neutral cannot move tractor, rearend acts like its locked up
are you sure the parking brake is releasing
Posted on Mar 25, 2009
  • 130 Answers
SOURCE: my john deere jx75 lawn mower won't start up.
There's a lot of safety features on tractors. Your owners manual would be the best place to check. I'll throw out a common spring time start up issue: dead battery. If you didn't have it on a trickle charger over the winter, tractor batteries die in 2 or 3 years. If it has started recently, check for a blown fuse.
For safety features, make sure you're sitting in the seat, brake on, clutch fully depressed, and any attachments (blades) disengaged.
Posted on May 02, 2009
panilling9
  • 284 Answers
SOURCE: john deere 2305/ the throttle lever goes back to
remove throttle lever assembly and if it is put together with a rivet?
take vise grip pliers and put in its jaws where it is connected or pivots at the rivet and squeeze it tighter at that point as it has worn with use. You will have to put out on it to make a difference
or if it is put together with a bolt ? its obvious
or if the throttle has indentations built in at certain points of travel then be sure the throttle assembly is tight enough to hit those and stay in that position
Posted on Jun 09, 2009
  • 5 Answers
SOURCE: John Deere LA110 mower blades got disengaged
does it engage manually with a lever, or is it electronic with a push pull switch? if electronic, check the wire that goes to the electric clutch, it might have come off when unplugging it. do all this with the engine off
Posted on Jun 27, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere 2010 utility tractor, lights come on
1) Battery condition and clean cable connections
2) Check the voltage & connections at the solenoid
*Is full battery voltage found at the solenoid?
3) Does the small wire that activates the solenoid from the ignition switch/safety switches have voltage when the key is in the start position
a) voltage yes, but it does not start; suspect solenoid
b) voltage no, inspect and check all safety switches for voltage to and from each switch
c) safety switches do NOT have voltage to them: inspect connections on ignition switch and check for voltage coming into the switch from the battery.
Posted on Nov 10, 2009
John deere srx 75 starting with key doesn't work why
if u wiggle the gear shift lever , holding key to start does it work ? if so then u need a new or adjustment neutral safety switch (also key does have running deere on it ?) as non factory keys don't work to well either
also this machine is listed on jd tech site as one that has been noted for an "starting improvement kit " part # - AM107421 jd has made it plain that they know it doenst start so well ,so they have released this kit to install that improves its starting
May 25, 2016 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
Rx 75 electical system seem dead. Engine will not turn over. Found a 2 wire plug under the back of the machine that was not plugged into anything.
The two wire connnector has fallen off of the neutral start safety switch. This keeps the machine from starting while in gear. Go online or to a dealership and get a pic of the NSS switch location,it a bear to reconnect so clean the wire connector well first; with an open connection like this, the electrical system to the starter is effectively dead.
Jul 01, 2014 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My john deere gx75 don't go into reverse and when i put forward gear i hear a noise like a tic tic tic...
It sounds like the spider gears inside transaxle is worn or broken causing noise and causing reverse not to work.
Oct 16, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
GX75 won't key start
you will have to follow the line from the switch through the safety switches and see where the break is.use a continuity tester you will find the fault
Aug 04, 2013 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My John Deere srx75 was running good I shut it off and now can't get it restarted. The battery is fine and when I turn the key there is no sound at all.
Hold key in the start position and move or wiggle the transmission lever a little; you'll hit the sweet spot and it will fire!
Sep 08, 2010 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
John Deere Gx75 Rx75 Srx75 Sx75 130 9hp Starter Logo
693 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
