My Maytag top-loading washer works very well but usually makes a buzzing sound while it's being initially filled with water - at the warm setting and cold setting but not at the hot setting. My handyman says not to worry, but I'm worrying anyway. Should I be?
  • 4,059 Answers
I'll tell you why you don't need to worry. You have a dual water inlet valve on the back of the washer where the water supply connects to the washer. There is a solenoid on each valve. one for hot water and one for cold water. Both of them open to mix the water for warm. So your cold water valve is the one buzzing while it's open. This noise is common and there is not danger of a water leak.
Posted on May 18, 2011
Maytag top loader not working
check water supplys okay and lid closed properly to activate lid switch....
Jul 01, 2012 | Washing Machines
I was going to wash a load of towels and the washer filled up but I realized it wasn't enough water in it so before I could set the dial for more water, it stopped filling up so I set the dial for more...
Look around at outlets that are close by and make sure you didn't trip one of your GFCI breakers or plug in something to the same outlet and make sure you have power at the outlet where the washer is plugged into.
May 30, 2017 | Maytag Legacy Series Top Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Kenmore 70 Series will not load hot water
It sounds like need to make some voltage checks on this job. When you set the fill cycle to hot & start the machine do you hear the valve buzz? If you do then the valve is causing the problem.
Feb 06, 2009 | Kenmore 22422 Top Load Washer
Washer's warm setting alternately fills hot and cold
Call for wty svc- the temp switch is bad; they had many of these built like that Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Washer
Sound like you have something stuck in the pump check the hose going into from the tub
Jan 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Dec 26, 2007 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
