Question about Philips SA5125/37 MP3 Player
What wrong with my mp3 player
When i plug in my usb cable it want connect it say it conneted then it disconnect
My mp3 player do not play to its menu., it turn off after the welcum page go gear.
Posted on Sep 01, 2008
When i conneted my player with computer then i
1.Try resetting the Walkman by pressing the RESET button located on it. It looks like a small hole. You can use any pin or any sharp pointed object to reset it.
Then connect back the Walkman to check whether it works.
2. Use the supplied USB cable to connect the Walkman to the Computer.
3. Disconnect all other USB devices if you have connected to avoid conflict.
4.Connect the Walkman to the other USB ports on the Computer.
5.Check whether the USB Driver is installed in the Computer or if it is corrupted.
You can check whether the USB Driver is corrupted or not by following steps below(only for Windows Operating System).
Right-click on MyComputer icon and select "Manage".
Then, select Device Manager at the left plane.
Then check whether any "Unknown device" or "?" or "!" is listed under Universal Serial Bus Controllers at the bottom of the right pane.
If there is so, then right-click on it and select uninstall.
This will un-install the USB Driver.
Then, un-plugg the USB cable and plug-it in.
Now, the Walkman should be recognized as a removable device in My Computer.
If the issue persists, then connect the Walkman to a different Computer to check whether the issue is with the Computer or the Walkman.
If the issue persists even with different Computer,
If the issue persists you may try using a different compatible USB cable.
Jul 27, 2010 | Sony Walkman NWZ-B142 MP3 Player
How do i put music,pictures ect in the device
Connect your MP3 player via USB cable to the Computer.
when you connet mp3 player, it will automatically running.
If not running go to My computer - Select Removable Device and Open -
Copy Music File or Picture from your computer and paste to your mp3 player.
Feb 08, 2010 | Audio Players & Recorders
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    Mp3 not recognized by the computer
    try re installing the cd program of ur mp3 or if you dont have any... try this. (for windows computer only)
    1- plug your mp3 in the computer using your usb.
    2- go to my computer.... in the left task pane. click view systems information.
    3-the system properties dialogue box will appear.
    4-click the hardware tab then click the device manager.
    5-the device manager tab will appear.
    6- click the portable devices then you will see the name of your device.
    7-click the name of your device .
    8- you will see in the general tab in the dialogue box that will appear 'device usage'
    9- enable it.
    thats all..
    Jun 07, 2009 | SanDisk Sansa E280 MP3 Player
    Help!I cant charge my Mps with the USB cable...
    Ok, wich USB you are conectting? Cause if you are connectting in the front, it don´t have enought current to recharge the mp3, but wether you connect in the back USB , it will works very good. If you have a Notebook, connect in other USB until you find the correct one. I Think that i Help You, Good Luck.
    Feb 05, 2009 | Sony NWZ-E438F Digital Media Player
    I have no idea how it happened, but i plugged it into my computer to charge. and then i just saw my mp3 player and the screen froze and it says usb connecting and when i plugged it out it still said usb...
    1. Connect the USB cable to your computer.
    2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
    3. When the display shows USB Connected, release the menu[0].jpg button.
    4. The device is now in USB mode.
    5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
    1. Upon disconnecting the device, it will return to MTP Mode.
    Nov 28, 2008 | Samsung YP-U3 MP3 Player
    The mac and the mp3 player
    You must have an ilo player or any related one which will synchronise all your songs and show your prescene
    Jun 23, 2008 | iLO (2 GB) MP3 Player
    Iriver problems
    you have to download the most recent firmware updater
    and save it to your computer
    Jan 19, 2008 | iRiver H10 MP3 Player
    Hey
    It is easier to reformat the mp3 player. When the mp3 is plugged in to the PC, go to my computer, the double click the mp3 player there. You will see internal storage, right click that and click format. You will lose all the stuff on the mp3 player.
    Oct 26, 2007 | RCA Lyra RD2765 MP3 Player
    I dont know what's wrong !!!!
    I had to roll back to Windows Media Player 10 and then plug into different usb ports until my iriver was recognized.
    Sep 22, 2007 | iRiver iFP-880 MP3 Player
    Philips SA5125/37 MP3 Player Logo
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
