Question about Garden
I have an allied 3 ton floor jack. The jack will not raise. I can lift and lower the jack arm but the lift will not rise. There is oil in the jack. I purged the piston to no avail. Would appreciate some help I really do not want to buy a new jack, this jack is approximately three yewars old ands has not been used very much.
  • 89 Answers
SOURCE: Sears model # 875.501390 floor jack will not raise at all.
IT SOUNDS LIKE IT IS CAPABLE OF MOVING FLUID FROM THE RESERVOIR TO THE CYLINDER. CAN YOU SEE THE SMALL PUMP PISTON POP BACK OUT WHEN PUMPING THE HANDLE? MOST JACK PROBLEMS BELIEVE IT NOT IS AIR. THEY GET AIR POCKETS IN THEM AND CANT PUMP THEM OUT. TRY REMOVING THE FILL PLUG ( TYPICALLY A SMALL RUBBER POP-IN CAP ) FROM THE CYLINDER AND JACK IT UP. IF THIS WORKS DO IT FEW TIMES, THEN REINSTALL THE PLUG. YOU COULD ALSO HAVE A SMALL CHECK VALVE PROBLEM INSIDE. IF YOU DISASSEMBLE, BEWARE OF SMALL SPRINGS AND CHECK BALLS. MAKE NOTES. HOPE THIS HELPS.
Posted on Apr 07, 2009
erickg
  • 116 Answers
SOURCE: Floor jack will not raise even without load
sounds like either pump piston seals or check valve on pump.
Posted on Apr 16, 2009
erickg
  • 116 Answers
SOURCE: floor jack needs sevice or seal replacement
you can do it two ways remove and match up the seals with a local distrubuter or try to find your make and model and order them.check your oil level also and the valve for dropping.
Posted on Apr 17, 2009
  • 75 Answers
SOURCE: Floor jack will not lift car off jack stand
It sounds like you have MAXED out the absolute HEIGHT that the jack is CAPABLE of extending to.
Try this to test this theory; Remember though before you !!EVER!! attempt to raise a vehicle with a jack, make sure that the vehicle is on FIRM LEVEL ground and that the JACK is likewise. Even if you have to slowely drive your vehicle a short distance in order to attain level ground, DO IT. THIMK! It could mean the difference between whether or not you live to tell about the flat you changed.
Get yourself a piece of 'treated' 2"x10"x 2' lumber which you will put in the trunk of your vehicle with your jack. It is now 'married' to your jack.
Chock the Tires on the opposite side of the vehicle that you will be working on. The weight of your vehicle will be redistributed when you jack up the vehicle. Even though you will have it in 'Park' you do NOT want it to move any at all. The chocks will prevent this.
Place that piece of lumber beneath your vehicle below the 'jack point'.
Place your jack squarely on this piece of lumber and slowly crank the jack up, keeping your eye on the jack point where the jack is in contact, until the tire is off the ground about 1/2 inch, any higher and you are just wasting energy and time. Once the tire leaves the ground it is high enough to remove from the vehicle. You may have to raise the vehicle up a bit more in order to replace the flat with a good tire. Be SAFE, Start low and work your way higher.
The REASON for the piece of lumber under the jack is to distribute the weight that is now bearing on the jack so that it does not depress into the ground. It also provides you with a stable platform to begin with and gives you TWO more inches of height to use with the jack if needed. Use it even if you are on asphalt because depending on the consistency of the asphalt material and how HOT is is from the current weather, the jack could settle a bit into the asphalt and this procedure could prevent this and keep you safe.
If you are using jackstands, use a piece of treated 3/4"x10" square, plywood under it as well to keep it from settling into the ground. Raise the vehicle only high enough to slip the jackstand under the portion of the vehicle where you will be placing it and still allow the tire to be removed.
Be SAFE and live to tell the tale. :)
Posted on Apr 26, 2009
SOURCE: hi i have a 3 ton sears floor jack i can not
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Gary
Posted on May 02, 2009
How to replace motor mounts on 2003 hyundai sonata
You really need the car on a lift or tall jack stands to do this. You will need a full set of hand tools, a good hydraulic floor jack, a set of Jack stands (AKA Safety Stands) and a 1.5 Ton bottle jack. Raise the front of the car as high as possible and unbolt the old mounts from the engine and engine cradle, then Carefully using the bottle jack (put a piece of wood on the plunger of the jack to avoid damage to the oil pan) raise the engine off the mounts and remove them, and reverse install new mounts, time about 2-3 hours to do the repair.
Oct 12, 2016 | Hyundai Motor 2003 Sonata
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
What is a jack lift?
"A jack lift is a mechanical device used as a lifting device to lift heavy loads or apply great forces. Jacks employ a screw thread or hydraulic cylinder to apply very high linear forces.
A mechanical jack is a device which lifts heavy equipment. The most common form is a car jack, floor jack or garage jack which lifts vehicles so that maintenance can be performed.
More powerful jacks use hydraulic power to provide more lift over greater distances. Mechanical jacks are usually rated for a maximum lifting capacity (for example, 1.5 tons or 3 tons)." (Wikipedia)
Oct 07, 2013 | Hoisting
How to replace oil pan gasket on 05 Kia Sportage LX 2.7L?
Hello
Yes you can do the job at home but the engine must be lifted off the engine mounts to have enough room to access and remove the oil pan, a very difficult job on the ground, fairly easy on a car lift. The job at home is about a 3-4 hour job if you are an experienced car person and have the right tools, you will need a good 2-21/2 ton hydraulic floor jack (not the cheap little ones Autozone sells) and jack stands as well as a wooden block to raise the engine up so you won't damage the oil pan..
Nov 30, 2011 | 2005 Kia Sportage
How to replace control arms on a 93 protege
Raise the front of the vehicle and support it by the frame with jack stands. Remove the front wheels using the air gun and a socket.
  • 2 Place the floor jack under the lower control arm as close to the ball joint as possible. Raise the jack until it begins to lift the control arm. Make sure that the floor jack is positioned where it cannot slip off the control arm.
  • 3 Remove the cotter pin in the upper control arm ball joint using the wire cutters. Remove the nut on the bottom of the upper ball joint using a wrench. Separate the ball joint using the ball joint separator tool. Insert the tool between the spindle and the upper control arm and hit it with a hammer until it comes loose from the spindle.
  • 4 Remove the upper control arm by removing the nuts on the engine side of the arm holding it to the frame. Use a wrench for this, but as the bolts are loosened, keep the alignment shims together that are behind each nut. It will be necessary to replace these on the side they were removed from for the alignment.
  • 5 Lift the upper control arm off and remove the upper ball joint using the ball joint installer kit. This procedure is only necessary if the new control arm does not come with a ball joint, which would be unusual.
  • 6 Place the receiver over the bottom of the ball joint and the smaller pusher cylinder on the topside. Place the large C-clamp from the kit over the cylinders. Use the ½-inch drive air gun and socket to push the ball joint out. Reverse the process to install the ball joint. Install the upper control arm in reverse order of removal.
  • Oct 27, 2011 | Cars & Trucks
    My Sears 3 ton high lift floor jack will raise but it won't lift any weight. The jack is only 3-4 years old and it has not had much use. I can't find my owners manual, and I want to know what I...
    Sounds like it needs some hydraulic fluid added.Look for a rubber plug or screw on the side of the hydroelectric cylinder where the ram comes out.Buy a zoom spout oilier and save the oil.Use some solvent and clean it out.Add some hydraulic fluid and fill until it starts to come out.You may be able to find an oil can that will work for you. Leave the jack in the closed position when you fill it.
    If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
    May 19, 2011 | Garden
    I have a 3 1/2 ton floor jack it is a craftman it will lift, but whene i put weight to it it will not lift anything where do you put the oil in to it. thanks gerald
    Hi, Gerald -
    You either need to top up the oil, or change the oil. Both of these are easy to do.
    You'll need some high-grade jack oil, an Allen wrench, a rag or two, and a funnel.
    1.) Relieve the pressure and lower the jack arm all the way down.
    2.) Remove the tool tray from between the two rear wheels.
    3.) Wipe the oil fill plug clean. (You don't want any gunk or debris falling inside.)
    4.) Remove the plug with the Allen wrench.
    Look inside. If the oil level is at or below the inner cylinder wall, you'll need to add oil. Don't go more than 3/16"-1/4" above the inner cylinder wall.
    With the pressure still off, gently raise & lower the arm two or three times. Check and adjust your oil level again. Then screw the plug back in & tighten it with your Allen wrench.
    Everything OK? Great. If not, repeat 1 through 4, then lay the jack on its side & drain ALL the oil out (into a container). When it's empty, set it upright & fill it. Again, raise & lower the arm several times.
    Replace the plug, tighten it, then test. Raise the jack all the way up, then lower it all the way down, without any load on it. Repeat this two more times. (This helps to dissipate the air bubbles in the oil.) It should now be ready to use.
    Mar 02, 2011 | Plumbing
    I need to replace my rear sway bar endlink bushings to pass inspection. any directions/assistance?
    (Caution ) sway bar end is under pressure.
    1.go to AutoZone get new linkage bars or just the bushings depends on wether the bar has grooves wore into them from use and new nuts. 2. Raise and safely support vehicle,3. remove tire, 4.using floor jack safely support the lower suspension arm and raise to remove pressure on the linkage bar between swaybar end and lower arm 5. remove the nut under the lower suspension arm that retains the swaybar linkage ,6. loosen and remove nut at swaybar end. 7.at this time only lower the lower suspension arm enough to remove the linkage bar. install new bushings or bar to the swaybar end don't completely tighten nut at this time.8. install new lower bushing then jack the lower suspension arm back up aligning the lower end of the linkage with the hole in the arm once pressure is lifting the swaybar install the lower nut and tighten at this time Torque top nut to35-47 Ft lb and bottom nut 8-10- Ft lb lower the jack from under the lower arm and install tire lower vehicle ready to go Appx 1 Hr per side
    Feb 20, 2010 | 1996 Ford Thunderbird LX
    No diagram
    These instructions are for the 3.1 L engine with serpentine belt. To change the belt, you need to remove the engine mount first. But before you do that, you must support the engine so it won't tilt after you remove the engine mount bolts. You would also need at least one helper. Here's step by step: 1. Use a jack and a long enough wooden block to cover the oil pan. Larger block will distribute the forces better. Don't use only a jack or a small block, it might crack the oil pan. Note: normally, you shouldn't lift engine by the oil pan, you should use an engine hoist, but carefully support with wooden block works. 2. Slowly raise the jack to support the engine. 3. Unscrew (Counter Clock Wise) the 2 bolts and 2 nuts of the engine mount. It's on the passenger side right next to the serpentine belt. 4. Loosen the tensioner bolt, and remove the old belt. You may have to raise the engine a bit to get a big enough gap to slide the belt through. 5. Put in the new belt and route it according to the diagram, you may have to leave it off one of the pulley because the tensioner is so tight. Don't worry, you'll slide it on later. 6. Put tighten the tensioner back on. Make sure the round metal pin goes in the appropriate slot. 7. Here's the hard part, putting the belt entirely on the pulleys. You have to either: a) Put a 3/8" ratchet in to the slot near the tension pulley that says "LIFT" and pull really hard to compress the spring, while putting the belt on the one of the pulley. Unless you are Arnold, you will need help. b) Pull a rope behind the tension pulley arm and pull while pushing with your left arm on the pulley arm to compress the spring; then get another person to hook the belt on one of the pulleys. 8. Put the engine mount back on. 9. Test run the engine to make sure you didn't mess up. Turn on accessories like A/C. If the temperature goes way up, you messed up. The water pump might be spinning the wrong way. Note: If you don't have a good floor jack, you can jack up the car, place a support under the oil pan, then slowly lower the car until the engine is supported. In this case, jack-stands or blocks under the frame are a good idea to avoid lowering too far
    Dec 10, 2008 | 1998 Chevrolet Malibu
    Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
    I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
    1-800-221-9705
    John
    Sep 27, 2008 | Plumbing
    Garden Logo
    79 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
