I have a 9-month-old HP destop PC on which I have never been able to adjust volume. Whenever I push what seems to be a volume button on the front of the monitor, I ALWAYS get the "OSD Lockout" message. How can I increase the volume?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Down by the clock on the bottom right of the screen is a volume control click on it and you should be able to adjust the volume.
There is a nice video here:
http://www.youtube.com/watch?v=hWlVRGAwpKk
It shows you on windows xp, but it is pretty much the same on vista and 7 too.
Hope this helps.
Posted on May 18, 2011
Whenever i use software like sype to make internet calls it keeps telling me my microphone volume is low. i then ran the test hardware wizard for my sound and the microphone does not pick up any sound....
Try adjusting the volume settings in your mic.
Go to Start->Control Panel->Sounds and Audio Devices-> Click on Voice Tab->Voice Recording ->Then adjust volume
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Hey, i just bought an HP with the illumintaed volume adjustment bars at the top of the keyboard. Whenever i change the volume using it it has a continual ticking.. is there any way to disable this ticking?...
is it an entertainment pc? if it is there is a flaw with the soft crappy cover they put instead of actual buttons. you have to take it off like you were going to replace the kb and follow the wire and make sure its plugged in good and not touching any metal or any other wires and put the cover back and make sure its snapped in all the way. had this on two so far.
Aug 23, 2009 | HP Pavilion dv4000 Notebook
I cannot adjust the volume on my Samsung 42" Plasma (PN42a400)
The fact that it turns on is good. Most likely the trouble is with a data line internal in the set. It may be the remote receiver IC or a push button on the set. A stuck button or switch can confuse or load communication between internal microprocessor circuits. Take a look or feel each of the push buttons do they feel the same when pushed ? Do they have a slight snap when pushed. The tac switches used in most cases are made like a small old clicker. If one feels soft and has no snap it's probably your trouble. If so tap lightly around but not on the button and it might free itself. You should just have Samsung replace whatever is the cause.
Apr 21, 2009 | Samsung PN42A400 42 in. Plasma TV
Wireless Intellimouse Explorer Not Working.
Normal 0 Normal 0 Recheck the magnifier to see if its set right.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Sep 01, 2008 | Microsoft Wireless IntelliMouse Explorer
Senseo coffee maker
Having dismantled and inspected several of this "strange machines" my conclusion is the following:
There is an oscillating-piston pump inside with in- and outlet valve.
It is energized by a microprocessor controlled circuit for a working time depending on the button selected (1 or 2 cups). The pressure and flow are nearly constant for a perfect working pump.
The pod holder restricts the thruput by its central hole. (E.g. you get now an extra pod-holder with a very small hole for expresso type)
So if you don't get enough coffee it may be that
1) the duty-cycle (timing) of the pump has changed.(not often occurring) no repair, you have to undergo electronic and programming work
2) the pump lost efficiency (cylinder of the pump clogged, piston not working with complete stroke, spring force fadening or just one of the 2 valves leaking) ca be "repaired" after dismantling machine ,extracting pump and taking it apart, success not garanteed - grinding valves is already time spending
so my principle before starting this work is to run the machine without the coffee pod to check the water output, use a new holder with clean central hole, if this works it will be nr.
3) the central hole of the holder is clogged, may be not by limestone, but dried coffee extract (grease) clean with needle or even better with micro-drill
Aug 10, 2007 | Philips Senseo HD-7810 Coffee Maker
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
