Question about Philips Audio Players & Recorders
My go gear wont charge what can i do - Philips Audio Players & Recorders
    President:
  • 1,566 Answers
Hi there, I suggest you transfer the files to your computer then have it reset. try to reformat your mp3 then put the files back.good luck!
Posted on May 18, 2011
My can wont charge my battery and it wont rev about 2500 rpm in any gear. i have replaced cam sensor and crack sensor and put new timing belt and tensioner on?
My car won't charge my battery ? Check the alternator (charging system) . You put new cam & crank sensor an timing belt on for a charging system problem ? Or after you did this stuff ,now the charging system isn't charging the battery ?
Nov 10, 2015 | Cars & Trucks
My galaxy gear wont charge
Seems like the charging capabilities of the battery have been exhausted.
Try another cable/ac adapter. If same results, you might think of a possible battery replacement
Dec 03, 2014 | Samsung Galaxy Gear Smartwatch- Retail...
Ctm hs580
5 flash code indicates your brake. Check your free wheel lever and ensure it is in drive.
Aug 26, 2014 | Health & Beauty
Battery is fully charged but wont start just grinds
this sounds like your starter drive (pinion gear) has had its teeth sheared of and become rounded.Another and more costly problem it could be is your ring gear on the engine itself.Hope this helps. :)
Dec 31, 2013 | Grizzly Big Bear Atv Maintenance Free...
My philips go gear 4GB wont turn on even though it is charged
There is a small hole on the side of the player through which you need to use a small office pin to reset. press it for some 5 secs and release. the playerr would have hung up earlier and is now reset. you can now switch it on. Hope this clears. Good day
Jul 02, 2010 | Philips Electronics - Others
My mp3 go gear wont charge, i've tried to charge it on the ubs port and i've tried to synx it again and nothing is charging it
try getting an old usb phone charger and using that if that wont work then your battery may be dead and its time for a new one
Sep 20, 2009 | Philips PSS110/17 MP3 Player
Bike wont change into gear,
The bike has a bent shift fork. Major repair and major repair cost. Your dealer will probably charge $1300 to $1500 to fix it. Don't try to fix it yourself because the shop will charge an extra $500 or so when you bring it to them in pieces. Besides, you would need some special tools to even begin the job. Sorry, someone had to tell you.
A “very helpful” rating for this answer? Thanks! < < And it doesn’t cost anything!
Jun 26, 2009 | 2006 kawasaki ZZR 1400
Wont charge
Have you tried to reset? The reset button is right by the lock switch. It's small so use a pin or something small like that.
Apr 11, 2009 | Philips GoGear SA3020/37 MP3 Player
My philips go gear mp3 wont turn on to charge
Take something really skinny like a saftey pin and press the little reset button thts next to the lock switch
Dec 17, 2008 | Philips GoGear HDD075/17 MP3 Player
1997 dodge caravan wont shift out of first gear
Yep ,sounds like limp mode ,should be in second gear.
Try,key on engine off,depress accelerator to floor 3 times within 5 seconds.Should reset trans.
Dec 13, 2008 | 1996 Dodge Caravan
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
