Question about Miller 903777012 SPECTRUM 2050 PLASMA CUTTER
Miller Spectrum 2050. No arc. Plenty of pressure. Checked trigger button and cable and contacts. No warning lights. Please help!
2 Suggested Answers
  • 5603 Answers
SOURCE: spectrum 2050 plasma cutter will not arc
Possible failure of the trigger switch and or the cable back to the unit. Use an ophmmeter to check that the trigger and cable are good,
Then with the ohmmeter check the continuityu of the cable to the electrodes,
Connectors are always suspect.
These are starting ponts to check.
Posted on Mar 04, 2010
Spectrum thunder plasma cutter will not cut steady, keeps stopping and have to pull trigger to cut
Check the contactor contacts for pitting. if severly pitted, replace contactor. If a death grip on the switch makes it work better then a light touch- replace the trigger switch.
Aug 17, 2012 | Miller Spectrum 375 Cutmate Plasma Cutter...
It runs when u press the trigger theres no fire or air comes out
Is the compressed air pressure in the limits for the unit to work. try turning the pressure up.
Aug 01, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Spectrum 2050 plasma cutter will not arc
Mar 04, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
It runs but when you press tha trigger theres no
go to miller.com they have downloads for most everything they make. it sounds like you might have a ground problem or a bad connection in the tip
Jan 24, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Arcing before pulling the trigger
does this unit have a high side and a low side if it does plug it into the low side and try it.
May 27, 2009 | Miller Welding Tools
Miller 2050 that will not spark.
This is relative to 3 causes , contol board , pwm board or torch
Feb 28, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Plasma cutters problem
Depending upon the design of the torch (e.g., orifice diameter), electrode design, gas type and velocities, and the current levels, several variations of the plasma process are achievable, including: * Plasma Arc Welding (PAW) * Plasma Arc Cutting (PAC) * Plasma Arc Gouging * Plasma Arc Surfacing * Plasma Arc Spraying
Aug 27, 2008 | Miller 903777012 SPECTRUM 2050 PLASMA...
Miller 903777012 SPECTRUM 2050 PLASMA CUTTER Logo
112 people viewed this question
Top Miller Welding Tools Experts
Kory Ronning
hubiam
hubiam
Level 1 Expert
John Trevino
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
