Question about Dishwashers
The machine will not refill, I did the water softner yesterday and have been having problems since. Now the machine will not fill at all and turns itself off.
  • 4,323 Answers
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back if you need more information.
Daniel
Posted on May 19, 2011
The water isn't filling into water softner for setting up
Depending on the washing machine, it is supposed to have a gizmo inside the softner housing that triggers the water during the rinse cycle to flow into the softner dispenser. Sometimes, they go missing or are clogged with hardened softner. Open the door fully open and carefully prize the entire housing out. Clean it with hot water and put it back in. Some machines require the slide in tray be raised about 70 degrees (most common) and then pull out, others require a downward angle.
Mar 12, 2015 | Washing Machines
Fabric softner dispnser filled with water
Try siphoning it out or pumping it out .
Feb 06, 2013 | Washing Machines
Softner Compartment won't drain
this may be a faulty valve that allows the water to fill the softner compartment.to check the draining capability remove the drawer and take it to a sink make sure it remains level you you sink tap or a cp of water and fill the compartment almost to the top and it should start draining once it starts to drain stop putting water in and watch it. it should finish draining by itself there will be some water left in it but only a small amount. if it does not drain clean it out.
Sep 24, 2009 | Samsung WF337AA Front Load Washer
The fabric softner dispenser is clogged. it fills
Pour really, really hot water into it and that should disperse the fabric softerner...then run the washer with NO clothes in it...good luck
Aug 11, 2009 | GE Washing Machines
Washing machine faberic softner try fills with water when in use.
hot water valve inside unit may be faulty ck it to make sure that it is powering up and then make sure it is operating. the cold and hot valve are one unit on most washers so the unit is replaced as one. if its a front loader than there might be a one way ck valve malfunctioning or the unit keeping intoducing water into the unit even though it is at the level it should be at. top loader then the level sensor is jacked and needs replaced.
Jun 12, 2009 | Frigidaire GLTF1670A Front Load Washer
Kenmore Elite front load washer filling up while turned off
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 30, 2008 | Kenmore Elite 45986 Front Load Washer
GE front loading washer softener dispenser does not dispense
After you put your normal softener into the dispenser, top it with water. The remaining water the machine will pour in. You can even try cleaning it with a toothbrush first.
Nov 29, 2007 | GE WSXH208A Front Load Washer
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Jun 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
