Question about Fiskars Brands Hand Tools
My Fiskars pruning stik was jammed. I was able to take the head apart to clear the jam and now cannot reassemble so the stik works. How does it go back together?
  • Anonymous Aug 13, 2015
    I have the same problem. Fiskars should publish dis-assembly instructions. Much wasted time trying to reassemble. Ordered replacement head from Fiskars $17.99
lessmith49
  • 5 Answers
SOURCE: see above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Posted on Feb 12, 2009
rowdy45176
  • 2176 Answers
SOURCE: Disassembled the stapler now need diagram to reassemble
Found user manual online but no parts breakdown, I have a phone number at 1-800-343-9329 and they might be to email you the breakdown. Wish I had better info but this is all they furnish online.
Posted on Mar 15, 2009
  • 384 Answers
SOURCE: Need help to reassemble Swingline Optima desk stapler
You must have purchased the Swingline Stapler that is actually a Paper Weight. Do you have the 747 model, the one the airplane of named after?
Sometime the imbeded PC fails, preventing the robotic controls to release the staple or to reassemble automatically.
Please return for a complete replacement and a free trip to Disey Lane just pay for transportation, tickets, lodging, food, shipping, packaging, and handling. Have a nice day and thanks for flying with us.
Posted on Sep 16, 2009
  • 8404 Answers
SOURCE: REATTACH PARTS
Should slifde right together from the back. If you will go to the company web site, there is an exploded picture there for your convenience.
I hope this helps
a
Posted on Oct 02, 2009
  • 86 Answers
SOURCE: I just replaced the Fuser as well as a new Toner
The problem is in the fuser exit sensor wich is behind the rear cover of the printer.Take of the rear cover and look if the lever of the paper sensor is in the wright place(the end of the lever should be between the two diods of the sensor).If the lever is in wrong position the printer will think that there is paper jam. If you need any other help please write to me. Please vote if this was helpfull.
Posted on Oct 21, 2010
Testimonial: "Thanks, great suggestion...where's the paper sensor...?"
Any suggestions for getting the old Fiskars Extendable Pruning Head to break free of the pole? Won't budge. Thanks.
Remove the blades and spring and put it in a bonfire. Once the wood is burned out, brush it with a wire brush, spray paint it and put it back together again.
Mar 04, 2018 | Garden
Uh70100 got caught in long haired rug, now motor hums but won't turn....impeller or fan seems jammed or broke
Pieces of the carpet jammed the brush, if you can't pull them out from the front you will need to take the head apart to clear the brush.
Feb 27, 2015 | Vacuums
How do I prune a peach tree
Do you wish the tree to produce a lot of fruit or to be a pretty tree. The trimming process will be different depending on what you wish.
Oct 09, 2014 | Fiskars Telescoping Pruning Stik Tree...
Fiskars pruning stik head restringing
http://gmedia.fiskars.com/faq/9240replacement.pdf
Oct 14, 2012 | Fiskars 9840 Professional Pruning Shears,...
Shredder stopped suddenly and won't work
If you are unable to clear the jam, turn off and unplug the shredder;
remove shredder head from the wastebasket and carefully remove any paper extending
below the cutting cylinders; empty the wastebasket; reassemble the shredder and repeat
jam clearing procedure.
if still do not run follow the next steps:
1. Make sure shredder is plugged in and
switch is in automatic [I] position.
2.Wait 15 minutes for shredder to cool
down before trying again.
3.make sure that the shredder head is in the correct position, if is not it will not run
please rate the post for i to know do this is helpful if not i will know by your rate that i should post some more information
Jan 11, 2010 | Fellowes P70CM Shredder
How do i clear a nail jammed in the gun?
I may need more information but you ,should be able to take it apart like any other nail gun.
Aug 03, 2009 | Tools & Hardware - Others
After my ice dispenser jammed my ice maker stopped making ice
make sure you reassembled it correctly.
icemakers can be stubborn with their safety features and will not work if not propperly reassembled
Jul 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Even There are not papers inside the printer, at start I receive the message Paper Jam. In maintenence mode, the message is Error code 36. I tried to unplug few times, same thing. I don't know what to
Two possible causes.
1. There is paper jammed in the purge unit or on the left side of the machine. Move the print head by hand to the centre of travel and look inside at the ends of the head travel path. You might see paper jammed in there.
2. If there is no paper, you will have to take the machine apart and check the encoder strip on top of the head. It should fit into a slot on top of the head. If it is not in the slot, carefully reseat it into the slot, reassemble and test.
There are other more remote causes but those are the two common ones.
Apr 22, 2009 | Brother MFC 420CN All-In-One InkJet...
Hand Tools Logo
193 people viewed this question
Top Fiskars Brands Hand Tools Experts
Don Numinen
Don Numinen
Bill Boyd
Dan Apthorp
Are you a Fiskars Brands Hand Tool Expert? Answer questions, earn points and help others
