Question about Kenmore Oasis HE 27062 Top Load Washer
I have a kenmore washer, he, canyon, top load washer, displaying "F" code, have tried unplugging, turning off and on with no sucess, took wet clothes out( only 1/2 load). What other things can I do to trouble shoot? thanks, Martha
  • Kenmore Master
  • 8,220 Answers
Bravos is the same as Oasis and Cabrio brands Click here for possible solutions.
Posted on May 18, 2011
Our washing machine will not drain, and keeps bringing up "LD" error code. It keeps beeping and the timer isn't going down.
  1. residential washer displays error codes. Though designed to indicate the nature of the error, to anyone without a copy of a washer manual handy, the codes might as well be Martian cryptography. Luckily, the Manage My Life website has partnered with Kenmore and made manuals for each make and model of Kenmore washer available online. The error codes are differentiated between top and front-loading machines.
  2. FH Error Code
  3. When a front-loading Kenmore residential washer displays the "FH" error code, the machine is experiencing a water-inlet problem. A water-inlet problem is the result of the washer receiving too little water to operate. The Kenmore owner's manual suggests five home remedies for this problem: Check that the water faucets connected to the washer are turned on; that the inlet screens in the washer's connection hose are not clogged; that the hose is not kinked; and that the hose is not frozen. If none of these problems are present, turn off the washer, unplug it, plug it back in, and restart the machine.
  4. FL Error Code
  5. The "FL" error code on a top-loading Kenmore residential washer indicates that the machine has over filled. When a residential Kenmore washer is overfull, it will beep every 10 seconds. The pump will cycle on and off every 30 seconds in an attempt to rectify the problem. To stop the pump or restart the machine, either disengage and then re-engage the power source to the washer, or push the overfill reset switch. If water continues to enter the machines after the "FL" error has appeared, shut off the inlet flow faucet or the machine will overflow.
  6. F02 Error Code
  7. The "F02" error code on a front-loading Kenmore residential washer indicates that the machine is experiencing a drainage problem. Home-remedy solutions for this error code, as suggested by the Kenmore manual, are similar to those for the "FH" error code: Insure that the drainage hose is not kinked, frozen, or clogged. If none of these problems are present, check that the hose is less than 96 inches, or 8 feet, above the floor. A hose more than eight feel from the floor will not drain properly
Dec 06, 2010 | Kenmore Washing Machines
Kenmore Oasis Washer won't drain. "Ld" code during
Hi
Error code LD means long drain. This error appears when the washer takes more than 5 minutes to pump out the water till point where pressure switch resets. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
What does it mean when your load stops and the screen says "F1"?
Hi
Error Code F1 means that the control is either bad or the wiring harness to the control has some issues. Please check the control board for any bad components as you might need complete replacement of the control. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Loads interrupted
interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
Sep 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore washer won't come on
I have the same problem that started today. No idea.
Aug 12, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Kenmore elite canyon capacity washer
check out the lid switch ... move it up and down slowing and see if you can hear the lid switch clicking.. lid may not be hitting just right or something... should also be under warranty
Sep 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE Canyon Capacity
Your door switch may be bad and not sensing that the door is shut which is what I see alot on those washers
Sep 01, 2007 | Kenmore 24032\24036 Top Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
