Question about Fisher and Paykel Washing Machines
Code 37 and machine indicates to much suds - Fisher and Paykel Washing Machines
  • 2,510 Answers
That would be an indication of a faulty pump, a heavy load, too much detergent or the incorrect type of detergent.
Posted on May 18, 2011
How do I fix the "sud" code
The Sud code indicates that the washer is seeing excess suds coming into the drain pump. This can be caused by using the wrong (non-HE) or too much detergent. It could also indicate that the pump filter is clogged. Sometimes, it indicates something that is partially blocking the pump's impeller.
Since you didn't indicate the model, you will need to look for your drain pump filter. Have a bucket handy to catch the water that is in the unit. You'll need to take off an access panel or probably the lower back panel of the washer. Open the filter and remove any foreign objects. Look into the area and check for debris that got into the pump area. Remove any objects and check that the impeller isn't damaged.
If you used too much detergent or a non-HE detergent, run the washer empty without adding more detergent. Do this until you do not see suds in the tub during the wash cycle.
I hope this helps. If you need a better idea of how to access the drain filter on your machine, please add a comment with the make and model.
Jul 31, 2017 | Washing Machines
My maytag 2000 series has a code E1 and SD
These codes indicate you have used to much detergent and there are excessive soap suds in the machine, use an approved detergent and use the right amount. Unplug the washer from the wall for 5 minutes after the suds are drained out. if codes return call for service.
Jun 28, 2016 | Maytag Washing Machines
While in the middle of wash load, an error light appears. Sd, what does this mean? kenmore top load washer model 8567165
A code of "SD" indicates the washer has entered its "Suds Routine." That happens when an excessive amount of suds is detected in your washer, and the machine changes operation to remove the suds for proper rinsing of your load. The code will clear itself once the "Suds Routine" has finished.
If it keeps doing this each load, try lightening up on the detergent.
Oct 08, 2013 | Kenmore Oasis HE 27082 Top Load Washer
SUD AND F-35 PROBLEM
SUD= The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future
As far as F35. Check your owners manual to see if its in there. Also if you remove the top lid ( a couple screws in back hold it in place) and check inside you will get the technician diag sheet which will have codes.
Jul 28, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
Dec 09, 2010 | Kenmore HE3T Washer
WHAT IS ERROR CODE 35 OR ERROR CODE 37? ON MY FRONT LOADER.WFW9600TA00
does it say f35 and sud?
you need a new pressure switch
sounds like a new washer is it 1-2 years old?
Jan 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Too many suds
Most probably a blocked or partially blocked pump.
Sep 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Problem with LG washing machine Model number wm1480fhd. The machine drum reluctantly turns and in about a few minutes it displays error code LE (flashing).
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 22, 2008 | LG Washing Machines
Lg wm2277hs
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
