Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
HP Officejet 6500 only a couple months old...everytime I try to copy or scan it leaves a black line down the middle of the page. Doesn't do it when I print from the computer. Theresa
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
The part of the printer that scans the paper is probably dirty, hence the line only on things that have been scanned/copied.
Take a look at the floowing link which takes you step by step through the cleaning process.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=3795309&prodTypeId=18972&objectID=c01658811
Hope this helps.
Posted on May 18, 2011
Scan and copy produce a black page
Scan head faulty(which is moving while scanning & copying) , replace it..
Nov 16, 2011 | HP Officejet 6500 Wireless All-in-One...
I have an HP Officejet 6500 wireless printer. If I scan or copy a document through the feeder the scanned or copied document has vertical lines from top to bottom. If I lay the document on the glass and...
Lift the scanner top, then look at the narrow pane of glass. There probably is a spek of dust or ink on it. Clean it with alcohol. I've had to remove the glass, due to the speck being on the undersaide of the glass.
Also, lift the ADF cover and clan the rollers with a damp cloth.
Jul 17, 2011 | HP Officejet 6500 Wireless All-in-One...
I always have a black line down the middle of the page when i scan. help
If there's a black line when scanning but not when printing, you need to clean the scan bed. Either the glass has something on it or check the paper path if you're using the ADF. A single ink spot either place will print a line down the whole length of your scan.
May 12, 2011 | HP Officejet 6500 Wireless All-in-One...
There is a black line down my pages when i copy or scan on my officejet 6500 all-in-one
Hello there,
Try this link,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455482&cc=us&lc=en&dlc=en&product=4083871&tmp_track_link=ot_search
This document will provide you a step by step solution to fix your issue.
The good thing about this is that it also provides full illustrations
Please don't forget to leave a feedback and testimony if it works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP Officejet 6500 Wireless All-in-One...
When I use the feeder either for scanning or copying, the page has a black vertical line . When I make normal copies or print outs it is fine, only the feeder makes the black line. Thank you
Under the Automatic Document Feeder is a small glass.
This glass becomes dirty, creating lines on the page.
open up the scanner cover and clean the glass
Feb 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
Apr 03, 2010 | HP Officejet 6500 Wireless All-in-One...
When receiving a fax there is a black line down the middle of the paper
If you can copy or print and there is no line, the line is coming from the fax machine of the sender.
Dec 24, 2009 | HP Officejet 6500 Wireless All-in-One...
On sending a fax the receiver copy has a black
You must clean the glass strip that the origional passes over to be scanned. You may have White-Out or an Ink smuge on it. Another way to determine if it is your FAX is to put in an original and make a copy. If the line is on your copy than it is your scanner **** (glass).
Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Line down middle of copy Officejet 6110
have you check with new cartridge. if the problem is still there with new cartridge then your printer needs cleaning from inside.give it to service.
Apr 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
435 people viewed this question
Seeker5211
Seeker5211
