Question about NEC LT245 Multimedia Projector
I have three NEC LT 245 projetors, one of them is dim compared to the others even though all setting are the same. How can I correct this?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Check the lamp of the projector. around the filament of the lamp, you might notice dark corrosion building around it. this what normally cause dim image.
Posted on May 27, 2011
Nec v260xg image alignment problem
Try the Keystone correction function to correct the trapezoid distortion.
May 02, 2016 | NEC Display NP-V260X Dlp Projector - 3D...
NEC LT260 Projector - Picture is dim - Not the lamp
Yes you may clean it, you don't have to replace the parts first
Feb 23, 2008 | NEC LT 260K Multimedia Projector
2001 ford e-250 tire size
The problem with the 245 is it is taller then the 225 and wider so your speedo will be off 5 to 10 miles per hour unless you have it reset. This will also put a strain on the trans because itcauses more heat to build up in the transmission. Ford and the other warrantee companys will also void any warrantee that you have.
Aug 14, 2014 | Cars & Trucks
Nec ndh80 has dim display
NEC NDH80 is a DVD Burner with a built in DVR. Check settings on DVD setups, if not. I'd recommend looking up the part and replacing it.
Feb 28, 2012 | Televison & Video
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
My headlight is dim but i changed out the bilb but it still is dim y is that i have an 2002 buick century
What he said but in more common terms. The ground connection to the headlight is bad. Three wires run to the bulb. One is ground, one is for the high beam, other is for the low beam. The ground wire sometimes is a short wire run to a connector screwed into the body creating the ground connection. Commonly on GM cars the black is the ground, the tan is the low beam and lt green is the high beam. You can correct this by running a wire from the black wire in the heaclight connector to the battery negative terminal or chassis ground. Hope that helps
Jul 16, 2010 | Buick Century Cars & Trucks
When I had XP, my webcam on Skype worked fine. I recently upgraded to 7, however, and downloaded Skype. It says that a webcam is not present. I have the Gateway LT Series 1004U, and have tried downloading...
Did you download the drivers via model or serial number. Generally the webcams drivers that come with Gateway are in three. Be sure you unistall the one that doesn't work before installing the other, restarting your computer each time. Also check the dates of the drives compared to the time you purchase the machine, some driver may be old or updated. Lastly, which i am sure you've done, make sure you have chosen the correct Operating System if you are not downloading the file from the web cammed computer.
Mar 31, 2010 | Gateway LT2021u Netbook
Slip Control Coming on Infinity G35 6 Speed Coupe with New Tires
you have a computer for your control on your car. It is set up so only the factory front and rear tires sizes will work, any change, it picks it up. this should solve the problem.
Aug 28, 2009 | 2002 Cadillac Deville
I have a nec 200 Projetor Found out tivo series 2 doesn't send a digital signal to the projector" How do I get an hd picture on the wall without paying an arm and a leg. Jim
Have a Cable Co. HD box or Outside antenna with a converter box, or Satellite all using Component Output to projector component input.
Apr 28, 2009 | Televison & Video
Wireless won't work on our NEC versa E3100
If you are using some Wireless client utility, disable it and try to connect with standard Windows wireles connection.
Is Wireless Zero configuration service running?
(Control pannel -> Administrative tools -> Services)
Set it to Automatic and start the service.
If there is some ecryption on your router, check if you have correct encryption settings on your WL device.
Check/set your WL network adaptor. Has to be set to automaticaly IP and DNS.
Regards.
Mar 28, 2009 | Computers & Internet
NEC LT245 Multimedia Projector Logo
288 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
