Question about Panasonic NN-SD797S Microwave Oven
I have a Panasonic microwave that is to be installed above an electric oven using a trim kit. The Panasonic # is NN-SD978S, 2.2, inverter, 1250, 24" wide. I don't know how to order the correct size kit and need guidance. Can you please help?
SOURCE: Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Posted on Nov 22, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: PANASONIC NN-SN789S MICROWAVE INVERTER. IN LOCKED
The owner's manual cover should cover this. if for some reason you don;t have yours, you should be able to download it here.
If you're outside the US, see Panasonic.net.
Posted on Jan 17, 2010
SOURCE: Need replacement microwave for 6 yr. old Thermador MBBS microwave
I have the Thermador MBBS/01 in a Theramdor oven/warming drawer/microwave unit. When I was told it would be $600 to repair it, I called thermador & they don't make a replacement. Thermador CS was even rude about it. I searched & searched for a microwave that would fit & found a GE model JEB1860M1SS at Home Depot for $259.00. My husband & I just installed it & the frame kit inside, on the old Thermador micorwave fit PERFECT! I could not believe it. I thought we would either have to settle for something looking tacky in the hole or buy a whole new unit. Looks like it came in that unit.
Posted on Mar 27, 2010
SOURCE: is there a replacement microwave for thermador
Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
  • 30 Answers
SOURCE: just had a panasonic inverter nn-cf778s delivered
No it definitely isn't. Sounds as though they got the interlocks connected incorrectly, or the control panel is defective.
Either way, you definitely need to send it back to where you bought it.
Posted on Oct 22, 2010
Can panasonic microwave oven nn-cf771s be built in to kitchen unit?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 05, 2016 | Panasonic NN-CF771SBPQ
NN-T945SFX CODE H98 RUNS A FEW SECONDS THEN STOPS
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Dec 24, 2014 | Panasonic Pansonic microwave
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
This is actually a one-year-old Panasonic Inverter NN H965WFX 1250 watt microwave. The light inside flickers and staggers a bit, and the microwave does not heat or cook properly. The first time this...
Inside is a screen which sometimes arc. These are normally available from the dealers and is not very expensive. Microwaves are dangerous and repairs are better left to trained people.
Jan 03, 2018 | Panasonic NN-H965 Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Jun 03, 2008 | Panasonic NN-T994SF Microwave Oven
Trim kit
These are countertop units. If you do enclose it, be sure you ventilate it adequately. If is not designed to be enclosed.
Dec 15, 2007 | Panasonic NN-H965 Microwave Oven
Panasonic NN-SD797S Microwave Oven Logo
26 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
