Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma iP4200: Main black cartridge will not function - all others work perfectly. Have deep cleaned etc.
    Brigadier General:
  • 3,917 Answers
Hi
Check for blockage in spray tubes. Also just hold the stop/reset button for 5 seconds and this should get you up and running. The ink level won't reset though, but at least you'll be able to print without problems.
Also try this:-
1. Disconnect the power cable
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode... (Wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Also check this related links for your problem:-
http://www.ehow.com/how_6786950_canon-pixma-won_t-print-black.html
http://www.ehow.com/how_6769200_black-work-canon-pixma-mp130.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 18, 2011
I'm trying to get my Canon iP4200 to print in BLACK ONLY
Hi . I think the print head may be is clogged. If cleaning didn't correct the problem . Print head need to be replaced
Jun 25, 2017 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
The black ink will not print on my canon pixma ip4200
printer head problem remove ink put about ten drops of alcohol in where the ink goes in run clean cycle ten times
Mar 29, 2009 | Canon Office Equipment & Supplies
Canon Pixma IP3500 prints B&W with white streaks
as i can suggest you that it can be the problem of head clogged internally where you insert your black cartridge .and the other main cause is while you give a head cleaning command to get the cartridge cleaned it sucks or pulls  the ink from the cartridge in such a huge quantity that 3-4 cleanings make the cartridge totally empty .due to this the ink gets very low and the printouts come with streaks.many a times setting the print mode in best makes the copy perfect.but the printing gets too slow in that best mode.
Feb 26, 2009 | Canon PIXMA iP3500 Printer
Canon pixma ip4200 colours are yellowy orange on teh photos - dont match on screen colour nozzle check shows the second of the cyan lines as very faint
(Had already done two deep cleans)
1. removed all print cartridges keeping them together and upright
2. qtip (cotton ball on a small plastic stick) soaked in generic nail varnish remover {alcohol based)
3 cleaned print head where cartridge sits repeatedly until no more ink came off on the cotton wool
4. did a deep clean twice
printer then functioned properly
Dec 04, 2008 | Canon Office Equipment & Supplies
Canon ip 5200
Did you run cartridge cleaning service from your computer after replacing the cartridges? If not, run cleaning once. If the nozzle check is not clear, there another option for deep cleaning, but i think it will take a lot of ink. Do it for best results. This will work. Are you using photo paper for Photo printing? if so give some time to dry the ink on paper.
May 12, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Printing Problem
Look for ink clogged on the printer head. Run cleaning or deep cleaning after installing the new cartridge before printing. Take nozzle check print.
Apr 30, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma Ip4200 Ink Smudges
1. Do you use refilled or genuine Canon cartridges?
2. Anyway, try to clean the printheads, because they seam to leak.
3. Verify if the cartridges are correct alignet (in maintenance software you have soewhere an "align cartridges" function
Feb 11, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Inaccurate error message
mine does it with the cyan and it worked for awhile...if I take a cartridge from another ip42000 cyan, it works. Any ideas?
Dec 12, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
52 people viewed this question
old marine
old marine
