Question about Dryers
Dropped a chapstick down into the filter - Dryers
  • torytales Aug 14, 2008
    Much thanks for the quick response. Why do these things always happen at the least opportune times?! And the chapstick...my daughter can be thankful that's all she has to replace!!!
  • 706 Answers
Shouldn't hurt anything... but if it gets dislodged and makes its way into the blower.. will make a racket.. If you can see it.. you should be able to extract it with a vacuum cleaner hose of coat hanger with the end wrapped in tape ( tape put on sticky side out)... Otherwise.. I wouldn't worry about it...
Hope that helps.. and you may want to purchase another chapstick for your needs...
Posted on Aug 14, 2008
My lips have discolored due to constant picking and they look very ugly. can the color be restored
I would recommend using Burts Bee's chapstick. It's one of the only chapsticks that does not have an ingredient that will INCREASE chapped lips. Upon applying, it's not the most moist of the lip balms, but you will notice a difference over a couple of days. Try the different kinds, and find which one is for you. As for the discoloration, for a quick fix, you can use a lipstain (close to your natural color). I like using NYC's lipstain because it's cheaper, AND stays on just as long. Another tip, try applying a good amount of chapstick and take a dry toothbrush and rub the excess skin/dryness away that way. It will enhance your lip color and scrub away the dry mess. Afterwards, reapply the chapstick.
Hope this helps!
Jun 08, 2011 | Blistex Medicated Lip Balm 0.15 oz Stick
New phosphate free dishwasher detergent does not remove chapstick residue from glassware. What are my alternatives?
Phospate Free Diamond Brite by Melaleuca . Also is chlorine free, no lye or bleach. It uses three powerful phospate free anti film agents with Opti-Shine Spot Eliminators which really work as I've seen from personal use. I'm amazed how shiny and clean. It is part of their eco sense line of cleaning products, all of which are highly concentrated, earth friendly/people and pet friendly with only 1/4 the amount needed to look fantastic. To Join Melaleuca visit Melaleuca.com password melaleuca and email me for membership inquiries. gloriazehr@rocketmail.com...independent marketing executive...membership 63702363
May 19, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
How to remove and replace water filter on a french door/bottomn freezer frig?
filter should be in upper right hand corner there should be a drop down tap that will drop down that cover that hides the filter once dropped down u will see filter u can remove it be turning it out ,,,,,,there is no need to turn off water supply as unit does it internally,,remove filter probably a ukf8001, look for a part number on it and purchase one most local appliance stores would stock that filter,,,replace it and u should be set hope this helps
Feb 06, 2010 | Maytag Refrigerators
Our glasses are coming out with chapstick/lipstick
Is the water being heated properly within the washer? If not, the element may be open or not being powered properly. Open the door after the wash cycle has begun--the water should have steam rising from it.
Oct 18, 2009 | Dishwashers
Crosley Gas Dryer-small plastic object fell into blower (?)
you might have to take the back off then off to the left take the screws out of the blower houseing and carefully pull it apart and then you should be able to take what ever is in there out
hope this helps
please rate this help
Feb 09, 2009 | Crosley CDG6000 Gas Dryer
The little red frog/lizard gets stuck on my daughters fisher price Rainforest Bouncer. How do I fix this?
It's hard to say without seeing it, but often the cause of a sticking component in a mechanical moving part is caused when the part in question becomes misaligned, like a sliding door that gets jammed when it's opened hard or lifted while opening.
One thing that often helps sliding components to move freely is applying a bit of chapstick. I have used Chapstick on slicing windows, drawers, bicycle cables and probably other things. The wax acts as a clean, non-oily lubricant that doesn't smell or stain. Use with discretion since this is a baby toy!
Did this help?
Nov 07, 2008 | Fisher Price Deluxe Perfect Support Baby...
Drop Down Menus
Click on Data (Top menu), Choose Filter from the drop down list, Choose Auto filter from the shown list. Now you get filter list on each column. Choose the filter condition on the column(s) you want and the data get filtered based on the condition you have given.
Fixya?
Feb 28, 2008 | Microsoft Excel for PC
DropDown menus in Excel
The quickest and easiest way is to go to the data menu and choose filter and then autofilter. This will allow drop downs on all columns which can be picked to filter one or more columns. Custom in the drop down list will give you further options.
Feb 27, 2008 | Microsoft Excel for PC
Dryers Logo
60 people viewed this question
Top Dryers Experts
