Question about Grundig GU19WDT 19 in. LCD TV
My Grundig GU19WDT has had problems for sometime with receiving the Freeview channels - it stays on the blue DTV please wait screen for ages. Sometime the Freeview signal comes though sometimes it does not. I have checked with my neighbours and the are getting the signal without problems. I hope you can help the TV is 4 years old.
  • Danny
    Danny May 18, 2011
    when you connect the tv to the cable from outside you are supposed to be able to view channels, but it is only possible on tv's that support those channels. For example: I was not able to view the freeview channels on my old tv, until i brought and new tv and the freeview channels were not 5,7,11, instead they were 5.2, 7.2, 11.4. Thats the way the new tv's view the free channels. Does your tv have these options?
SOURCE: grundig cuc2058
bin it
Posted on Dec 31, 2007
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
SOURCE: how to tune my digital chanels in my bush lcd tv
i just saw a post which I believe will solve my problem (I connected to the wrong coax antenna plug). I haven't tried, but I'm pretty sure that is the problem.
Here's the post from akai_owner from 2007:
Look at the back of your TV. Make sure your cable is hooked up to connector on far right, NOT the far left. (For analog cable TV.)
Push "source" button on remote or side of TV to cycle through TV inputs. Wait one second between pushes. You want to stop just before the source that displays "AV" on TV screen. It should show a number, for the current channel number.
If you are using an analog cable box, try setting the TV channel to 3 or 4. If you use no cable box, try changing channels on TV to find an active one. If no luck, make sure your cable service is active (subscription active). Cable companies disconnect it between residents of an apartment/house.
Posted on Jan 30, 2009
SOURCE: Freeview channels (DTV) on a Sharp Aquos TV
I have a Sharp Aquos 26-D44E. The factory preset PIN on this one is 1234.
Posted on Feb 10, 2009
dave1645
  • 834 Answers
SOURCE: My Alba 32 inch Freeview DTV seems to be stuck on
have you tried running setup again? if not try it if you cannot get it to respond then you will need a mainboard replaced
Posted on Nov 24, 2009
Channel search on Grunding 19WDVDT
Please follow guidelines in operation manual, step by step.
Aug 04, 2012 | Grundig GU19WDT 19 in. LCD TV
I have grundig lenaro 32"tv
Sounds like you're only viewing analogue channels.
Go into Menu and find Inputs and select & choose DTV. This will restore reception of Freeview (Digital TV) channels.
Mar 30, 2011 | Grundig Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Freeview
go to menu settings, channel settings, set tv to CATV for cable, AIR for analog, or HD for high def.
Make sure you have the correct cables depending on your connection
Sep 16, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
How to delete unwanted channels off freeview
go onto the menu and enter the pin.then go to child lock and
select the channels you dont want your kids to watch so when they go to the bad channels they will have to enter the pin whitch they will not know.
Jul 29, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
ITD 58, 59, 60, 61
press info button on the remote then goto tuning on the blue screen menu. say yes to auto tune then save.
Jul 28, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Grundig GU19WDT 19 in. LCD TV Logo
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
