Question about Sony Audio Players & Recorders
My sony mhc-s9d goes to 'push system protect;
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 18, 2011
Sir my MHC-RV900D is disply shows push power protection again and again.plz solve my problem. thank u
There is most likely a short in the amplifier that will need to be repaired before the unit will power on normally.
Mar 12, 2013 | Sony MHC-GX40 CD Shelf System
How To Remove Push Power Protect To My Sony mhc-dp1000d?
You can't. There is a short in the amp that needs to be repaired before the unit will power on normally.
Mar 07, 2013 | Sony MHC-DP1000D System
"Protect" Blinking on Sony Stereo
may i see a diagram showing where the ic goes?
Nov 03, 2012 | Sony Mhcec909ip Mhc-ec909ip Mini Hi-fi...
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Dec 19, 2008 | Sony MHC-RG30T Shelf System
Sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Dec 17, 2008 | Sony LBT-LX50 CD Shelf System
1,451 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
