Question about SanDisk 2GB microSD Memory Card
Connect to a system error occured formetnow please give me solution
    Problem Solver:
  • 19 Answers
If u have a card reader put the memory card in the card reader slot connect it to the computer and a removable drive will appear right click it and select the option format and format it.
Posted on Jun 05, 2011
SPC222SF IS GIVING ERROR ""PLEASE REBOOT SYSTEM ""
It is in auto reboot mode when a failure occurs. You need to take note of the SC Code that appears before it reboots. That will tell you what is malfunctioning. If it boots up with that - as in immediately - unplug the machine, remove the hard drive, plug in and reboot. Does it still occur? Yes? You need a service tech to check it out. No? Replace the HDD.
Oct 18, 2014 | Ricoh Aficio SP-C222SF Flatbed...
I have an error code in the install operation tell me how to fix it
Common PS3 Error Codes and required Network Ports.
Additional PS3 Error Codes:
80010514 - Dead BD lens.
80010516 - Dead BD lens (happens at different occasions, code above is more common).
80710092 - Connection error (usually the connection is dropped), you will be signed out of PSN.
8002AD23 - Unidentified error (cause unknown), happens in Burnout Paradise (when game starts) and sometimes SARPBC.
8002A227 - PSN account suspended.
8002A212 - error returned by the PSN servers during authentication (invalid version).
80029945 - Can't playback burn BDr movie (error in picture above)
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
(workarouns is to transfer files to ps3 via TVersity)
(added 24th Sept 2007)
80029301 - An error occurred during the delete operation (attempting to delete some ps2 homebrew from virtual mem card) (added 15sept2007)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3 processes - have to sign in to use them) (added 04-sept-2007)
80710A06 - An error occurred during the install operation (error when downloading game from PSN - network error occured (added 30thAug2007)
8003041F - An error occurred during the copy operation (using media server) (added27aug2007)
80010006 - An error occurred during the start operation (added 22aug07 - corrupted folding install)
80010007 - An error occurred during the start operation (added 17aug07 - during disc swap tests)
710102 - DNS Error; No DSN server available.
8013030 - System Error due to failed update download
80010001 - Major Error , Game ability stopped
80010017 - Can't start Blu-ray Game
80010510 - Will not play hard drive games - Cause unknown
80010516 - An error occured during the start operation; Ps1 game swapped using the eject function and then play pressed quickly - ps1 game inserted again
80029023 - Exchanging Key Information exchange has timed out
80029024 - "Cannot Obtain an IP address".
80029564 - Downloaded Game will not install - Cause unknown
80030920 - An error occurred during the copy operation. The file may be corrupt or there isnt enough memory. Try copying data from original source.
80031150 - System Settings Fail to Save - Possible Blue Screen "Setting information is corrupted.Pre
80031601 - Error Creating Account
80130203 - PS3 connects to internet but not to network - Typically means that the required ports are
80410418 - DNS Error
80710016 - Playstation Network is down.
80710092 - "An error has occured. you've been signed out from the ps network" -(connection dropped?
80710101 - Conneciton error
80710102 - IP conflict , PS3 Cannot connect to the router with current IP information - Try rebooting your router
80710541 - The connection to the server timed out. press the x button to repair and restore default"
80710723 - Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
81019002 - Error copying saves from location A to location B not open to connect to store but PS3 can connect to internet.
8001050B - Will not play demo hard drive games, when blue-ray disc is inserted - Cause unknown
8001050D - An error occured during the start operation; Ps3 game swapped using the eject function and then play pressed quickly - ps3 game inserted again
80028EA5 - Unknown?? User cannot connect to PS3 network. Sony told the user to send the machine in.
80028ea6 - Connection error , Possible Proxy error power cord. Then shut off your modem/router, for about 5 mintues, then turn the modem back up first and let it sync, then turn the router back on(if using one) and let it sycn.
Reconnect your power cable and flip the back swtich up again. Then make a new network connnection.
80028F10 - Go to Display Settings then HDMI (or whatever your connection is) and choose Automactic,
80028f17 - Ps2 disc Boot Error , An error occured during the start operation; Ps2 game swapped using the eject function and then play pressed quickly -Backup ps2 game inserted again
80028F18 - Ps2 Disc Error, unsupported disc; eg. Utility discs, BB discs, IQ Remix game etc. ode).
80028F19 - PS2 Disc Error , fsck; the internal PS2 disk got corrupted and I guess that you can use HDD utility disc to fix it
80028F1A - Ps2 Disc Error , invalbnnetcfg; network config error
80029C68 - Corrupt data usually on external device
8002A10D - Unable to Add friend in XMB
8002A4A6 - Cannot load game to play online
8002A515 - Error Signing in
8002A548 - Unable to remain logged in - either to game or server
8002A705 - Unable to connect to server/host. Check router port configuration.
8002a71a - Possible NAT Error , Can log onto Game Server but can't join game and can't host game
8002b241 - DVI has no audio
8002F994 - To many people downloading the update just sit back until the morning around 5am - 11am and you should be able to get it.
8002F997 - Trying to Update the Firmware, copying to a file and installing from a USB drive falied".
8003051E - Game will not Save
8013013D - "A connection error has occurred" - May be to do with the SSID of the Router or signal strength if the conneciton drops Putting the PS3 into DMZ may help - otherwise check WPA key Ps3 can't handle WPA2 only
WPA or none
8013013E - WEP Key error, change WEP key to all numbers (on router homepage) and try agian, or which to WPA. - Otherwise disable security
8013030F - Check Router Page, SSID Broadcasting possibly off.
8013030F - Access Point not detected
80410A0B - Internal PSP error, hardware fault. Send back to be replaced/fixed.
807101FF - An error occurred during communication with the server. This is a DNS error This is a DNS error
8071053D - Hard boot the PS3, turn off the PS3 to stand-by, flip off the back swtich and remove the
80710B23 - PS3 Network is Down or PS3 Network is too busy to respond
80710D23 - Turn the PS3 off for a bit (30 minutes give or take) with the power toggle (not standby mode)
80029513 - Copyright Violation when attempting to install game
8003200D - Server side issue, much like the trophy syncing problems.
8001050F - System Clock Error.
8002A227 - You account has been banned, either temporary or permanently, (Check here for reason why you may have been banned).
80029780 - Unable To Activate System - You have reached the maximum downloads for an unactivated system. This will not affect systems that are already activated on your PSN account.
80010002 Invalid argument.
80010003 Invalid syscall number. A lot of the addresses in the syscall table at 0x2EB128 point to a function that only returns this value.
80010009 Operation not permitted.
8001002B Filesystem mounting failed.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
I cannot connect to internet...is is giving me an error code 0x80300113
The error code Ox80... can rectified by following ways
Step 1:
This error usually occurs when the date and time in the your system does not coincide with the actual date and time. Check if your system clock time is set according to your timezone.
Step 2:
If the time is set according to the timezone and yet does not connect to the Internet, I'd suggest you use the Ethernet cable and boot your machine insafe mode with networking and check if you are able to connect to the Internet.
Note: Make sure you have a wired connected while performing safe mode with networking.
Check out these link for more information about the other type of error regarding connecting internet to go online
http://windows.microsoft.com/en-US/Windows7/why-can-t-i-connect-to-the-internet
Please revert me, if you need more assistance, i would be very glad to assist you more.
If you were satisfied with the solution please rate this sollution.
Thanks For using FixYa!
Vinod Kumar J
Let us know if it works in safe mode with networking.
Dec 04, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I disabled the error reporting in my computer properties, Advanced. But still I am facing the same "don't send" error. Please help in solving this problem.
In system properties go to advance option and select error reporting in that window give select the option that "disable error reporting" and unchecked "But notify me when critical error occur".
Aug 05, 2010 | Microsoft Windows XP Professional
Cafe World Connection Problem Help pls!!! Thx
First of all please restart your system once. Then also its not to play please try these ;
  1. Update your browser. If you are using Internet Explorer you try a new browser such as Safari 4, Mozilla Firefox, or Google Chrome.
  2. Clear your browsers cache.
  3. Reboot your System
  4. Download the latest flash player,adjust your Flash Settings to give Flash permission to store information on your computer
  5. Verify that Javascript is enabled.
Feb 25, 2010 | Facebook Social Network
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Windows Error Recovery - ''an unexpected I/O error occured''
Hi
This seems to be serious problem. Please share the exact error message. If there are any external devices connected to the system please remove and then try to boot the system again.
Also post the brand and model of your laptop so that we can be more specific in terms of the steps.
Thank you
Rakesh
Dell Expert.
Jan 06, 2009 | Computers & Internet
ERROR Scanner error occurred. please see documentation
Hi
Open the glass cover on top of printer, check a switch for lock and unlock on left or right hand side of the printer. toggle it to unlock position, turn it back on and check if there are errors still.
Keep me posted.
Nov 14, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Nokia 3230 mobile camera problem
change memory card and try with a new memory card.
Aug 25, 2007 | Nokia 3230
SanDisk 2GB microSD Memory Card Logo
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
