Question about Garden
Need Instruction Manual for American Farm Works Electric Fence Controller Model SP 4000, 6 volt solar power low impedance
  • 76 Answers
SOURCE: I just bought a Parmak 6 volt solar electric fence
I WOULD THINK SO BUT THE BLACK MAT BE THE POS. AND YOU MAY BURN UP THE CHARGER IF HOOKED UP WRONG BUT OTHER THEN THAT YOU HAVE GOT I THINK
Posted on Jun 24, 2009
atomicflash
  • 17 Answers
SOURCE: Controller has no voltage output when connected to fence
You have a dead short to ground somewhere along the fence circuit.Disconnect the leads again,and use a resistance checker to check resistance to ground.(Push a metal rod into the ground to connect one of your leads to,and connect the other lead to the fence.)One or the other fence circuit ends will have a lower resistance to ground.That fence end is closer to the short to ground.Follow that part of the circuit until the resistance to ground is as close to zero as you can find.(taking the ground rod with you as you go)Somewhere in that area you will find your short.
Posted on Jun 27, 2009
SOURCE: need instruction manual Miracle Maid electric skillet from 1970's
Miracle Maid Instruction booklets can be found on ebay. I've seen them several times, in fact there are several on today 7/29/2009. Just go to ebay.com and search for Miracle Maid. You may have to search daily, but you'll find them. You'll have to pay a little, but you can send in all your pots and pans and get replacements with one of those books. I had my pots and pans for 30+ years and now I have the new ones that replaced those. I'm thinking they will last 30 years too! Good Luck!
Posted on Jul 26, 2009
aloha27
  • 695 Answers
SOURCE: Could i i please have
No problem!
Here's the link to your owner's manual:
http://www.marksrv.com/brake_control/voyager_manual.pdf
Hope this helps.
Posted on Sep 12, 2010
dj_relly999
  • 4070 Answers
SOURCE: need instruction manual for G-Shock
Hi! Please try to click the link to download the g shock tough solar manual. Please rate g shock to start download. Hope this helps and thank you for using FixYa! Please click here http://safemanuals.com/314159.php?k=95c6ac8f6b4a3a308be54da06a4ea1ab&ID=526088&q=CASIO G-SHOCK TOUGH SOLAR GW-1401-2
Posted on Sep 14, 2010
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
I have a paramark solar charged fence model number df-sp-li it dosen't click anymore how come? Is the click important
The click is the transformer carrying current. If the unit doesn't click, unhook the fence from it and turn it on. If it starts clicking it is a short on the fence. If it doesn't then the unit is not working. contact parmak and they can service it or sell you a replacement circuit board which is the most common failure.
Sep 24, 2012 | Parmak Solar Fence Charger
No charge, is it battery or solar panel, how do I tell
if the unit is not produceing a charge during daylight then it is the unit. the DF-SP-LI will produce full power under sunlight alone. test the unit with the fence unhooked.
Jun 01, 2012 | Parmak Solar Fence Charger
I have a Parmak Model DF-SP-LI. With a volt meter it reads 2.3 on the fence, but the performance meter is always reading beyond the green.
It depends on the type of fence tester. the common light-o-meters are a resistor ladder, calculated not only for voltage but current. the DF-SP-LI uses half the lowest current most are designed for. no if that is a digital or analog meter, then it would be time to check the out put from the charger with out the fencer connected. if you get the same reading it maybe defective unit. if you get a better reading then you will probable need to upgrade your ground system. insuffencient ground will show its self as a low out put on the fence but not on the charger.
May 20, 2012 | Parmak Solar Fence Charger
Need battery
We have one of these, it's great.
See these links:
http://www.parmakusa.com/Battery_Maint.htm
http://www.parmakusa.com/service.htm
I would try removing the battery and charging it with a proper low-amperage charger (1 amp). Your battery will either be 6 volt or 12 volt, just be sure the charger matches.
Also check the ground rod and all wiring connections.
May 13, 2010 | Parmak Solar Fence Charger
Installing instructions
You can download and print your PARMAK manual here:
http://www.agfence.com/fence/Assets/documentation/parmak/InstallationManual.pdf
Dec 19, 2009 | Parmak Solar Fence Charger
May 15, 2009 | Zareba Electric Fence 600 - 7,000 Volt...
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
