Question about Sanyo Xacti VPCS1275 Digital Camera
I can't connect my camera to this pc..it says connecting fail..is it because the pc is slow..it worked on my other 1..tried changing batteries and re-ran cd..
  • Angela Carter Mar 25, 2012
    Oh yeah it was the ports in that old computer my camera works fine in my other computer thankyou :)
    President:
  • 1,566 Answers
Hi there, I suggest you use a different port. The port that you are trying to connect to might be disabled. Hope this helps. Good luck!
Posted on May 18, 2011
Testimonial: "pretty sure you are right cos i had change the port for my cam as well but at the moment it's not working in any ports..i'll keep tryin thankyou"
  • lyzias morato Jun 13, 2011
    I hope this is all working now. :)
I suggest to buy the card reader. it is much easy to use and save time.
Posted on Mar 22, 2012
Problem transferring photos to the PC
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com )
Jun 11, 2013 | Samsung Digimax S1000 Digital Camera
My camera used to work just fine with my pc, now my pc won't find the camera when connected with the cord. I also can't delete pictures because the camera freezes up. I also get 'picture e
You should format the memory card, while in the camera. Find the built in utility. If the format fails (try a couple times first) then get a new memory card. Possibly this will help the conectivity issue too, if not try looking in the Disk Management section (Right click My Computer, Choose Manage) See if the camera, connected to pc, is showing there without a drive letter. Right click on it and assignn it a drive letter. Hope this helps.
Dec 07, 2012 | Polaroid i633 Digital Camera
I am trying to upload pictures from my ge x5 digital camera. everytime i connect it to my pc the screen on my camera reads connection failed.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
Jul 08, 2011 | GE X5 Digital Camera
I am trying to transfer pics from my camera to my pc ??? i plugged it in and card is in camera but nothing?? help?
Here are some steps to run through to make sure the camera works as you'd expect it:
  1. Ensure that all cables are properly secured from the computer to the camera.
  2. Ensure that the memory card has not been dislodged from the camera.
  3. Check the camera's memory socket and the memory card for debris. A can of 'compressed air' can work wonders (typically available at any computer store).
  4. Make certain that the port connecting the camera to the computer is not damaged. Look for any bent pins in the camera's memory slot. Try replacing the camera cable. If the camera uses a USB port, try another USB port. If you don't have another USB port available, try plugging in another USB device to verify that the USB port is working.
  5. Check the power source on the camera. If you're using batteries while attempting to transfer the pictures to the PC, try changing your batteries, recharge the batteries, or use an A/C adapter.
  6. Try reinstalling the digital camera software on your computer. In most cases, reinstalling over top of the existing software will resolve this issue.
  7. Take the media out of the digital camera and attempt to download it to another computer. If all else fails, try formatting the camera media. Most newer-generation digital cameras equipped with an LCD screen have a menu option that can format your media.
Hope this helps.
May 05, 2011 | Panasonic Lumix DMC-LZ5 Digital Camera
I can't download all my images, I have 10 images that will not download. It downloads 52 (1/52 - 52/52) but the camera set up another set of pictures 1/10 - 10/10 that will not download. Can you...
Below is the standard procedure for checking for solutions. If you have a card reader available, I'd recommend removing the memory card from the camera and trying to download the images directly from it.
Hope this helps.
May 05, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
CAMERA SAYS FAILED CONNECTION WHEN I TRY TO UPLOAD PICS TO PC.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Feb 24, 2011 | GE E1486TW Digital Camera
When i try to download my pictures it says connect failed i connect the cable to computer and trun on my camera to download pictures and it says connection failed
Feb 09, 2011 | GE A730 Digital Camera
My camera wont download to pc.. says connection failed GEx5 camera
Jan 01, 2011 | GE A730 Digital Camera
Sanyo Xacti VPCS1275 Digital Camera Logo
56 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
