I have a copier Ar M155, but gives error E100...what can I do?
  • 3 Answers
SOURCE: ImageRUNNER 1600 E100 System Error
if a little part of drum is broken the door of laser is closed. J am sorry for my english .
Mario. (Rome-Italy)
Posted on Feb 07, 2008
  • 117 Answers
SOURCE: Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Posted on Mar 26, 2009
  • 16 Answers
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Posted on Jul 15, 2009
xptareq2000
  • 1447 Answers
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Posted on Jan 20, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for SHARP AR 5127 error U2-40 call for service
U2 40 CRUMchip communication error
Posted on Apr 12, 2011
How to fix replace toner cartridge problem when there is enough toner in the cartridge.
Remove from the printer, give it a good shake over the sink, (you may find toner leaking and it is hard to cleanup...then replace it. That may do the trick but if it does not you may be best off replacing the cartridge. Sometimes old electronics misreport the condition of components ....it could be that the machine is getting old and going wrong. But you will only discover whether this is the case after investigating further)
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
AR-M155 keep complaining of change the ink cartridge.while the cartridge is working perfectly with another printer. pls what step should i take please what is the next step to take
well some times you do get bad cartridge is this third party if so replace the cartridge with a OEM. Is there a chip on the cartridge if so clean with alchol also clean the contact inside the machine where the chip connects, buy a new one OEM do not use one from other machines there chips already have data about that machine not the new one
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SHARP AR-M155 system error[H4-00]
H4-00,is a fusing troble.maybe the heater lamp is basted, or the thermistor and thermofuse are deffective.or try to cancel by a simulation 14
Jul 05, 2012 | Office Equipment & Supplies
Apr 13, 2011 | Office Equipment & Supplies
HELLO I NEED SHARP USER MANUAL FOR DIGITAL AR-M155 PHOTO,PRINTER,SCANER,AND FAX. PLEASE SEND AS SOON AS POSSIBLE
Here's the manual: http://safemanuals.com/user-guide-instructions-owner-manual/SHARP/AR-M150-M155-_E
Click on the "Download the complete user guide."
Fill out the four question survey or put in the security code to download file.
I tested to confirm that this is the right user manual.
Thanks for using FixYa.
Mar 16, 2011 | Computers & Internet
Error E100
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Dec 31, 2008 | Canon PC-1060 Black and White Copier
REPLACING THE TONER
HI! I HAVE BOUGHT THE SHARP PRINTER/COPIER/FAX/SCAN MODEL AR-M155, WHEN I INSERTED THE NEW TONNER AND MAKE THE PHOTOCOPY TESTING I GOT THE OUTPUT COPY WHICH SHOWS THE HALFED COPY IN VERTICAL ON RIGHT HAND SIDE WHEN YOU READ THAT PAPER SO WHAT COULD BE THE PROBLEM ON IT WHILE IT IS NEW MACHINE???? AM SCARED!!!. PLEASE IWOULD BE VERY HAPPY IF YOU HELP ME TO SOLVE THIS MY REQUEST PROBLEM.
THANKS,
Aggrey34
Sep 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
Printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
May 03, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
