Question about JVC HD-61Z786 61" Rear Projection HDTV
HOW DO I REPLACE THE LAMP - JVC HD-61Z786 61" Rear Projection HDTV
    Top Expert:
  • JVC Master
  • 74,136 Answers
Hello
To replace lamp in JVC projection TV follow the steps below.
[1]. Order a compatible replacement lamp from JVC. Order a replacement lamp from JVC's Accessory Store or a local authorized parts distributor to ensure that you obtain a compatible replacement lamp. To order a replacement lamp, you must have the lamp type and lamp code of your JVC projection TV, which can be found on the rear of the television.
[2]. Turn off the television and allow the bulb to cool. For safety reasons, turn off and unplug your television before accessing any of its internal components. Wait at least 20 minutes before attempting to replace the lamp so that it has time to cool down. If the back of the television is not warm or hot to the touch, it is safe to begin removing the lamp
[3]. Unscrew and remove the lamp door. The lamp door on JVC projection TVs is located on the rear left of the television and is shaped like a square. Several warnings related to the lamp will be printed on the door. Use a Phillips-head or flathead screwdriver to remove the large screw, then remove the door
[4]. Unscrew and remove the lamp assembly unit. After you have removed the lamp door, you will see the lamp assembly unit. Use a Phillips-head screwdriver to remove the two screws. One screw is on the top right corner of the unit and the second screw is on the bottom left corner of the unit. Detach the lamp assembly unit from the compartment by lifting the handle and pulling the unit away from the television
[5]. Install the replacement lamp and secure the lamp door. Hold the replacement lamp assembly unit by the handle and insert it straight into the compartment. Reinsert and tighten the two screws onto the lamp assembly unit with a screwdriver. Place the lamp door back onto the television and tighten the screw to secure it to the television
[6]. Reset the television's lamp timer. Press "Menu" on the television's remote, then scroll to and select "Lamp Timer Reset." Press "OK" to rest the timer. A prompt will appear notifying you that the timer has successfully been reset
Posted on May 18, 2011
Can you do from side of tv button lost remote. Reset timer please help
Posted on May 26, 2013
To replace a blown turn signal light on a 2010 dodge avenger ?
This info is in your owners manual. For the rear lamp assembly, you open the trunk, pull trunk liner back a little from lamp assembly, remove two wing-nuts, pull on the lamp assembly and push on the wing nut studs to remove lamp assembly. The bulb socket twists out of the lamp assemble. Replace the bulbs. replace lamp assembly.
Dec 28, 2014 | 2010 Dodge Avenger
Tip
Lamp vs Ballast
This is to help explain the short lives of Lamps.
WARRANTY: If a lamp fails within the first year replace Lamp and Ballast.
If Lamp explodes do not replace Ballast only lamp, but if lamp didn’t explode replace both.
If you experience more than one Lamp failure within one year of use replace the Ballast.
The Panasonic Brand offers a Ballast repair kit (LSUC0022), it only works about 20% of the time.
I would not recommend this replacement kit. It will get you past the 30-45 day warranty period in most cases but it will not be the proper FIX to the customer’s unit and they will only call you back or (most important) call another Service Center.
I have experienced maybe 100 customers that had other Service Companies come out and only replace the Lamp. When the Lamp and Ballast should have been replaced.
I hope this helps the Customers and the Technicians in their judgment.
If I was redundant I apologize, just trying to help.
Good Day, big IRISH
on Dec 09, 2009 | Televison & Video
How to reset lamp hour of panasonic pt d6000se lamp
the lamp hour timer on the lamp housing, you can replace a new timer,
Apr 19, 2014 | Panasonic ET-LAM1 Projector Lamp for...
Said replace lamp, now doesn't turn on
if it was working before lamp replaced "replace lamp" appeared on the screen either lamp somehow not in correctly, new lamp bad, or something happened during lamp installation--have you tried to put the old lamp back?
Apr 08, 2012 | Televison & Video
TV shut off and won't come back on. It has been showing message to replace lamp. Is the lamp the problem?
Hello
The life time of the lamp may have gone out. That is why it showed you that messege. Replace the lamp. The procedure and description of the lamp will be in its user manual. Follow it up. Replace the lamp with the original number only. OK.
Jun 25, 2011 | Panasonic PT-52LCX66 Projection Television
Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
Lamp Replace Counter
Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
Move the pointer to [Yes] and then press SET button.
3. Another confirmation dialog box appears and select [Yes] to
reset the lamp replace counter.
This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
 Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
 If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
 A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
lamp are being used.
IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
accident or injury caused by pieces of broken glass.
Dec 24, 2010 | Canon LV S3 Lamp
How do i replace the lamp
remove the lamp door on the bottom, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 27, 2009 | Sanyo PLC XU35 Multimedia Projector
remove the lamp door, remove the old lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 15, 2009 | Sanyo PLC-XP55 Multimedia Projector
Lost the manual - I am replacing the bulb
remove the lamp door, remove the lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 08, 2009 | Sanyo PLC XU35 Multimedia Projector
Replaced lamp; still have no video yet have audio
Did you replace the lamp because the picture went out (black)?
May 21, 2009 | Panasonic Televison & Video
JVC HD-61Z786 61" Rear Projection HDTV Logo
413 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
