Question about Whirlpool Heating & Cooling
Not draining from the hose. Pail filling up with water
    Brigadier General:
  • 4,736 Answers
You need to check the hose and the outlet it's connected to on the dehumidifier for clogs.The dehumidifier will divert the water to the bucket, if the aforementioned is clogged.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 18, 2011
Lg wf-t9230tp is not pumping
Open small door at bottom front of washer. get a pail and put small black hose in pail and remove plug. After machine is drained remove large screw cap. probably a sock or something in trap remove and put back in place.
Apr 23, 2014 | Washing Machines
How to thaw turkey quickly
I put it in a 5 gallon pail and set it in a bathtub or shower area with a hose filling the pail and overflowing. I use warm water takes about 3 hours
Nov 27, 2013 | Refrigerators
My Kenmore 90 series washer will not drain my water or spin...please help
remove drain hose put in pail at grd level if flow check pump if no flow connect waterhose to drain pipe apply water pressure stop check for drain flow at ground level if okay drain in tub must be blocked
Jun 12, 2011 | Washing Machines
It won't drain away water.
take drain hose put in pail at ground level if it drains trouble with pump
if no drain try
put a hose in drain pipe hose force water back into machine then see if it drains the plumbing of machine has to cleaned spin tub shall have to be remove to clean
I want to learn how to drain and flush my radiator. I need help on how to do so without making as mess
well its bound to make a little mess but you should have a drain plug on the radiator at the bottom towards the engine side on one of the 2 tanks (sides of radiator ) unscrew drain plug and let drain into a pail or pan ( 2 gallon ) after it drains remove lower radiator hose. use a garden hose and fill radiator and let it flush for a little, hook lower radiator hose back, tighten drain plug and fill with a 50/50 mix new antifreeze,
Feb 07, 2011 | 1996 Ford Taurus
Was draining slow, now not draining at all
Suggest if you hear motor running and no draining while in drain that you unhook the hose under the sink. The drain hose is the hose coming from the center bottom of the dishwasher to the drain stand under the sink or the side of the garbage disposal. Have a pail and see if it pumps it into the pail, you may have a plug or a kink, you will see what I mean when you try this..........
good luck
(also saw one plugged at check valve once where drain hose is connected to dishwasher, it is a small opening with a one way flap to prevent drain water from going backwards, but it is a small opening)
Feb 28, 2010 | Whirlpool 24 in. GU1500XTLS Stainless...
Jenn-Air dishwasher will not drain
Hello there:
I am assuming it washes OK
First remove the kick plate.on the front bottom
Is the pump running when it should be draining?
Is The solenoid (Wash/drain) pulling down when it should be draining? (If visable)
Left hand side attached to the pump housing.
If yes then you probably have a blocked drain hose or house drain blockage.
Undo the drain hose at the sink, often stuff can collect where the hose fits over the drain fitting and cause a plug. and also the hose can get clogged on the inlet side of the pump too ok?
If OK. Try to drain it into a pail. Be sure to hold the hose there firmly and put a rag/towel over the top of the pail or you will have water everywhere.
and fully inspect the hose all the way up to the pump .
Hope his is very helpful for you
Best regards Michael
Dec 31, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
DISHWASHER DOES NOT EMPTY WATER COMPLETLY
Sometimes the drain hose will get partially clogged where it hooks into the drain under your sink. Take the hose off and put it into a pail. Advance the dishwasher to go into a drain cycle and see how fast the water comes out. If it comes out really fast check where the hose goes into the drain. Clean out with a screwdriver and refasten the hose and clamp.
If the water comes out slow the problem could be in the pump or drain hose.
Very common problem.
Dec 29, 2009 | GE Nautilus 24" Built-in Dishwasher
Washer leaks when filling,fill by pail no leak
Pat it sounds like you pressure switch or hose to it is bad.your washer isnt leaking its overflowing the tub right?I dont understand the rest of your question so ill leave it alone..
Nov 15, 2009 | Washing Machines
Drain not working
yes there is. get a container of limeaway and follow the directioins.
Jul 18, 2008 | Danby DDR586R Dehumidifier
Heating & Cooling Logo
75 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
