Question about Danco Faucet Stem
Is there a picture to show how the 9s-4h/c danco stem goes back together?
2 Suggested Answers
  • 297 Answers
SOURCE: how does a 9s-4h/c danco stem install.
the spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of takeing off.
Posted on Jul 27, 2009
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
How to install a danco 10472 4z-24h/c hot & cold faucet stem
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Feb 09, 2014 | Danco Faucet Stem
Tub handle stem wont come out- 9c-23H/C 3 handle Danco for american standard
I had a similar problem when looking to replace my shower valves with 9C-23H/C units. The old ones were very hard to get out, I imagine that they were the original ones that came with the house.
Do NOT cut into the wall, that will not get you anywhere. There is a nut that fits around the plumbing end of the stem; this is likely what is stuck. I had to put my foot on the wall and pull hard on the vise grips to get the stem out. You may want to use a flashlight and see if there is any scale build up which is getting in the way. Try to scrape that away if possible. Pull straight out on the stem very firmly, but don\'t yank on it, use constant pressure and avoid up and down movement as the nut has a tight clearance to make it out.
Going behind the wall should be an absolute last resort.
Jan 15, 2013 | Plumbing
I bought the Danco replacement stem for a milwaukee faucet(part 4s-6h/c) it is leaking from the handle... do I need to replace the plastic part that runs back into the pipe? Is there an easy way to remove...
Sometimes on the stems on the side the handle attaches is a nut that can be tightened. Inside this nut is a rubber or other type of seal. tightening this nut stops the water from coming out of the handle. If the nut has already been tightened then possibly need to replace this rubber seal.
Sep 02, 2010 | Danco Faucet Stem
I have a Danco 9C-23H/C stem for an American Standard shower stem replacement. I'm trying to identify where the friction ring is supposed to be placed. I've seen it in pictures going on the end where the...
there is never a fiction ring at the washer end, sometimes there is a cup shaped part that holds the washer but nothing else so it must be intended to go around the stem
Jun 27, 2010 | Danco Faucet Stem
Where does washer go for 12h-6h/c stem from Danco for faucet?
Is it brass, stainless, plastic or rubber? I think a stainless one might be for the knob screw, I don't think there is one inside, it might just have fallen into the pack. We get weird stuff all the time that doesn't belong. Hope this helps.
May 31, 2010 | Danco Faucet Cartridge
How to insert a hot cold ste, 3Z-6H/C FAUCET REPAIR
#1 THE FAT PART OF YOUR SPRING GOES INSIDE THE FAUCET ,AND SIT ON THE VALVE BODY(SEAT)
#2 THE LITTLE BLACK WASHER SIT ON TOP OF YOUR SPRING
#3 PUSH THE STEMS IN THE CORRECT SIDES HOT ON LEFT.CAUTION THERE IS USUALLY NOTCHES ON THE SIDES OF THE STEMS TO HELP YOU ALIGN THEM IN THE VALVE BODY,
4 PUT THE NUT BACK ON ,TIGHEN SLIGHTLY,TURN ON THE WATER TO CHECK ,IF OK RE INSTALL YOUE HANDLES
Apr 06, 2010 | Danco Faucet Cartridge
How does a 9s-4h/c danco stem install.
Apr 08, 2009 | Danco Faucet Stem
Danco Faucet Stem  Logo
244 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
